      01-12-2024, 04:12 AM   #1
TTT123
Drives: f15
n57 egr problem code
i have n57 fault codes 280500 egr cooler efficiency too low, 331800 agr kuhler bypassklappe mechanisch defekt nahe offener position, 287500 lambda probe oxygen conctration implusibly low. i dont knoow what a problem. egr is brand new. faults with old egr was also there
      01-25-2024, 10:36 AM   #2
mig25
mig25's Avatar
Drives: 2014 X5 F15 35D
Hello,
Did you get this figured out? I have this code on my 2014 X5 35D
2014 X5 35D
Diesel Power!
      04-24-2024, 03:05 AM   #3
TTT123
Drives: f15
no
      04-24-2024, 05:19 AM   #4
mig25
mig25's Avatar
EGR Cooling issue
No, I have not figured this out. I have my check engine light on for quite sometime about this issue.
2014 X5 35D
Diesel Power!
      04-24-2024, 06:30 AM   #5
m4forum
79
Drives: M3
Some codes are directly related to component failures but others are not directly related. I am not familiar with this code but could be related to the volume of air expected from EGR to be introduced into the manifold intake. This volume is calculated based on pre-defined maps and sensor inputs so the DME knows how to correct the injection. As feedback loop the NOx sensors can tell the DME if the level of NOx expected has been achieved.
Also notice there is a particular code related to EGR bypass 331800 (remember F15 has 2 EGR coolers ... high pressure (next to exhaust manifold) and low pressure (in front of the engine ... related to recall). The bypass valve is located on top of the high pressure EGR.
I would start testing the EGR bypass valve and later the EGR valve (part of the low pressure EGR). You will need ISTA to run those tests. Search for EGR bypass ABL and run the test ... same for EGR valve. BMW has built those into ISTA to easily identify failures.
      04-24-2024, 06:45 AM   #6
m4forum
79
Drives: M3
I forgot to mention ... its very handy also to have some data inputs from key sensors on the engine like coolant temp, EGR target position, EGR mass flow, charge flow, ... the easiest way to get they is by using OBD reader like bm3 or kiwi3 (there are others but I am not familiar) ... and App Bimmerlink.
Just an example how it looks like
      04-24-2024, 08:50 AM   #7
mig25
mig25's Avatar
EGR
Actually I think it would be easier to get rid of the EGR and EGR cooler altogether.
Will it clog the DPF?
Instead of spending money to get exhaust pipes etc, can the DPF be hollowed out?
But I think getting rid of the check engine light my require tunning.
What is your thoughts on this option?
2014 X5 35D
Diesel Power!
      04-24-2024, 07:28 PM   #8
m4forum
79
Drives: M3
I dont recommend deleting emission system from the vehicle. They exist for a reason ... can be fixed.
      04-25-2024, 06:41 AM   #9
TTT123
Drives: f15
my problem is fixed. part number 11747810831 selenoid for egr bypass was wrong. was open all time
      04-25-2024, 06:44 AM   #10
TTT123
Drives: f15
      04-25-2024, 08:43 PM   #11
m4forum
79
Drives: M3
glad was an easy fix ...
