      07-25-2017, 07:47 AM   #221
ruggedcanadians
ruggedcanadians's Avatar
Drives: 2017 X5M, 2018 M2, 2020 M5CS
Yes, car running while coding was executed. It all looks good, and does what it is supposed to, except actually work!
It even reads the items I switched as ?active? when I rescan the ECU?s.
Mark
      07-25-2017, 10:08 AM   #222
sigx5
Drives: X6
What's you communication setting? You have to select slow communication, it is under setting manual.
      07-25-2017, 11:51 AM   #223
ruggedcanadians
I have it set to slow communication
Mark
      07-25-2017, 06:32 PM   #224
nicros
Drives: 2017 X5 xDrive50i
Any way to reprogram the buttons on the M Steering wheel on a 2017 X5? I would like to change the +/- from volume to next or previous track, and the spinner between them to volume...
Thanks!
      07-25-2017, 06:39 PM   #225
Kr0m3assass1n
kr0m3assass1n
Kr0m3assass1n's Avatar
Drives: 22 X7 M50i
Thanks!
Why would you want to do this when the spinner allows you to change tracks by scrolling up or down and clicking to select previous/ next track? Better yet the HUD should show the previous/next entries so you know what you're selecting...!
      07-25-2017, 07:12 PM   #226
nicros
Because a) the HUD doesn't work during the day with my polarized sunglasses, and b) the scroll and select requires you look at what you are selecting as opposed to a single click 'gimme next track' without looking.
This is how it worked in the Q5 and it was something I got used to. Might have to get unused to it, but still would like to know if I can program the wheel to do what I want and then choose what I like best
      07-25-2017, 07:22 PM   #227
Kr0m3assass1n
kr0m3assass1n
Drives: 22 X7 M50i
I doubt coding the buttons is possible. But you're better off scrolling the wheel up one click and pressing it.
Oh and there's also physical buttons on the dash. Look above the FM/AM button.
      07-26-2017, 06:14 PM   #228
wjdunn3
Drives: 2014 X5 xDrive35i
Startup in Sport Mode
Maybe I just missed this and it always been there, but I was browsing through the latest BimmerCode app seeing if there was something else I wanted to code. I saw in BDC options for Start in Sport Mode, and some others options for comfort/eco as well as saving driving mode at shut down. So I coded to start in Sport by default. It did not work though. Later when browsing through the other ECU's I found the same settings in ICM (integrated chassis mgmt) so I set them the same as I had in BDC and coded... Viola now my X5 starts up with Sport mode active as the default, instead of Comfort.
scostu1623.00
      07-26-2017, 07:27 PM   #229
Captain comic
Captain comic's Avatar
157
Drives: 2008 328xi
Sorry for off topic maybe, but I have a Gen.II Carly App for BMW (it says it has F series code ability as well). Can I use it on F15?
      07-27-2017, 09:11 AM   #230
SCA
SCA's Avatar
Drives: Multiple BMWs
Nice find!
      07-27-2017, 10:57 AM   #231
mvigod
mvigod's Avatar
Drives: 2021 X5M
Hi. I just bought the Bimmercode app and was successful coding everything I wanted except for the ability to have ALL doors auto-unlock when the ignition is turned off (or even if driver door is opened would be fine). Wife wants to be able to pull her pocketbook out of back seat when she gets out without having to manually unlock every time.
I searched around and the one code in expert mode some people mention, perhaps not for the X5, I can't find in there. Not sure if it is named something different for the F15 X5 (ours is 2015 MY).
Any guidance on what the exact option name is and what to set it to if something besides the active/inactive options.
Very much appreciated. Thanks!
      07-27-2017, 11:00 AM   #232
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Line 59/60.
mvigod181.50
      07-27-2017, 11:30 AM   #233
mvigod
mvigod's Avatar
Drives: 2021 X5M
Originally Posted by Almaretto View Post
Thanks, I just tried this. It was set to active so I just flipped it to non-active thinking the opposite would make it work possibly. Tested it out. Drove car away and let doors auto lock. Parked and shut off ignition. All other doors remained locked. Wonder if there is another setting that also must be enabled for this to work? The HUD setting is set to unlock all doors but not sure that is relevant to the auto unlock when ignition is shut off.
      07-27-2017, 11:53 AM   #234
Almaretto
Almaretto's Avatar
2374
That should have worked. You can also configure through IDrive to disable doors locking when drive away.
mvigod181.50
      07-27-2017, 11:55 AM   #235
mvigod
mvigod's Avatar
Drives: 2021 X5M
Yes I would have thought that would have worked as well. Do you think the proper setting to have it unlock when ignition turned off is Active or Non Active setting?
      07-27-2017, 12:23 PM   #236
wjdunn3
There is a vehicle setting in iDrive that toggles between unlocking only the driver door or all doors. I'm not in my car so I can't tell you exactly where but it is under setting somewhere.
      07-27-2017, 12:27 PM   #237
Almaretto
Almaretto's Avatar
2374
CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING: nur_nach_v_verriegeln
I am aware of setting, though I do not like my doors unlocking when engine stops or all doors so I leave unchecked. If I want to unlock rear or passenger doors, I use CA and touch rear driver's side door.
mvigod181.50
      07-27-2017, 02:01 PM   #238
mvigod
mvigod's Avatar
Drives: 2021 X5M
Okay maybe that is the problem. Did not have it set to nur_nach_v_verriegeln
Side question. Every time I code I notice various errors in the info and memory sections within Bimmerlink app. Is this normal after each coding? I have just been clearing all the errors after each code session with Bimmerlink. Just checking if this is normal and same procedure everyone typically follows.
thanks
      07-27-2017, 02:35 PM   #239
Almaretto
Almaretto's Avatar
2374
thanks
If you set to aktiv, then it will only auto-unlock if auto-locked. If "nur_nach_v_verriegeln," it should auto-unlock if manually or auto-locked with driving away.
I have only always used E-sys, so not sure about BimmerCode/Bimmerlink. But, false positive errors are common when coding certain ECU's, especially those that involve Drivetrain and safety functions (eg, ASCM, DSC, ICM, etc).
mvigod181.50
      07-27-2017, 11:13 PM   #240
nicros
I was playing around with this app today with my X5... I thought there was a way to show digital MPH on one of the two screens... but the settings I chose (Digital Speed in Board Computer) didn't work.
Do I need to do something else?
      07-27-2017, 11:27 PM   #241
Almaretto
Almaretto's Avatar
2374
B.C. is the button on the end of the turn signal stalk. You have to cycle through available choices to find digital speed. Personally, I find it useless on my car as I have HUD.
      07-28-2017, 09:55 AM   #242
SCA
SCA's Avatar
A little OT, but out of curiosity can the road speed limit be coded to the HUD (driver assist) even though you do not have drivers assist plus which displays the road speed limit?
