      04-20-2022, 09:20 PM   #133
-c-
-c-'s Avatar
Drives: bmw
Originally Posted by NCThreePedals View Post
reviving this thread since I refuse to pay $1k for a used B&O speaker
Has anyone else done this, should I stick with the link OP provided to purchase? I see the same speaker on the site for $100 less from different vendors, is there a difference?
The prices fluctuate and different vendors sell the same thing at all different price points.
But not all are created equal
The one you want
To make sure you get is the one that has the high quality anodization so it doesn't discolor from the sun exposure.
Some seem like super cheap knockoffs of knockoffs lol.
So make sure you do your homework!
Mines been working flawlessly now since it's purchase and after install code the B&O option on idrive to make use of the spacial sound effect the speaker gives you.
      04-20-2022, 09:30 PM   #134
blackoutF15
351
Drives: BMW X5 x35i
Originally Posted by -c- View Post
Originally Posted by blackoutF15 View Post
Originally Posted by Cranswick852 View Post
Powering from front fuse box is straightforward and, I would say, easier than the 12v lighter socket. Hardest part is pulling forward the instrument panel (plenty of you tube clips to help), then drop cables down to fuse box, close to A-pillar. Three connections, permanganate 12v, switched 12v and ground. Speaker rises (and led lights) when ignition is turned on. Speaker drops (and led off) 10-15 seconds after switching off ignition. You can get speaker to rise and fall when radio is turned on and off, but that is more complicated- I haven't tried.
Obviously your call whether to proceed or not, but I wouldn't let the power connection put you off.
Thanks. But does the kit come with a cig lighter plug at all?
No. Not sure why your so hard set on the cig lighter
The speaker took less than 30 minutes to install and didn't have to take anything apart except for the lower panel Which was a couple screws.
The hardest part was cutting the dash so the speaker could fit. After that it was super easy to run the wires and connect.
Wait..I'm confused. When you say only need to take out the lower part, you mean the radio/cd player? How about the power source? I thought you'd need to wire to the fuse box. This is the part I'm not confident and have little knowledge to do. I can handle cutting the plastic bracket and removing the trims.
      04-20-2022, 09:32 PM   #135
-c-
-c-'s Avatar
Drives: bmw
No the lower foot well panel to access the fuse panel. It's literally just a couple screws and comes off. You then fish the wires from the speaker to the 12 v and the aux. it takes literally 30'minutes and your done.
Having to remove the panels where on the 5 series and others taking a very hard rout
You need to lengthen the wires though….
If I have time I can take a pic of the fuses we jumped to in order for it to work.
Unless someone has a pic they can share.
Trust me if you connect to the 12v lighter you're making more work for yourself and you won't be happy with the operation.
      04-20-2022, 09:40 PM   #136
blackoutF15
351
Drives: BMW X5 x35i
Ok I'm convinced that it is the best way to connect to fuse box. A picture would be nice. Another question, as for the speakers, do you just reuse the harness/cable from the OEM speakers that are removed? Plug and play? Since you don't need to remove the dash trim and radio unit. Thanks for your pro tips.
      04-20-2022, 11:29 PM   #137
-c-
-c-'s Avatar
Drives: bmw
Yes you just unplug the speaker wire out of the standard speaker and then plug in the new one.
And it will work just like the OEM standard speaker.
If you want the movement and led you need to wire up to the fuse box.
      04-20-2022, 11:48 PM   #138
blackoutF15
351
Drives: BMW X5 x35i
Thanks. Now I'm clear on what needs to be done. Just need to know the details on fuse box connection.
      04-21-2022, 09:22 AM   #139
NCThreePedals
227
Drives: 981 GT4/Audi Q8/F15 Diesel
The one you want
Thank you so much for replying! The link you have on the original post has the proper anodization?
Yes I was planning on getting it coded as well, but I won't do the install I'll let a shop deal with it!
      04-21-2022, 04:31 PM   #140
-c-
-c-'s Avatar
Drives: bmw
The one you want
Yes it had the proper anodizing and is still like new.
Others will fade to gold. So sometimes the little bit of extra cash is sometimes for the better process with UV stability.
Again their may be just as good of a unit out their but it's a roll of the dice.
The one I got from this vendor was a 1 to 1 perfect replica.
Even down to the speaker design.
If you held the two side by side I don't think you could tell the difference. It's that good.
Quality is also top shelf and it's super quiet actuation where it's silent and no motor noise.
I also scored the complete B&O speaker grills off eBay and wired up the door covers for the led. Then coded it for B&O and you can here the difference, that tweeter design and angle change on the windshield seems to make a difference.
Crank it and it has no distortion so for the money I was sold.
However ask if it's got the B&O text on the cover.
Mine did and not sure if they show it missing because of copyright. The old pics use to have the B&O text but those are now gone. It's been a while.
      02-13-2023, 01:36 AM   #141
77juli77
Drives: X6
Right the fuse box connection is if you add in a relay so it goes up and down when you turn off and on the stereo. Or use the OEM amp.
The other route just connects to the back of the idrive system quad lock connector. Everything you need is their so that's what they connect to.
The easy way will have it turn up when the car turns on and lowers when you shut it off.
DO you know what kind of realy? model thanks
      04-22-2023, 07:52 PM   #142
-c-
-c-'s Avatar
Drives: bmw
Hello, All the stereo shop did was hook the speaker up the original speaker and then for the led and power up and power down just snaked the wires down and hooked them into the fuse box.
By relay I was just saying they connected it to a fuse with a “add a fuse” and tapped into a fuse block that turns on and off when the car is powered on and off.
It took them 15 or 20 minutes to power it up,
The hardest part was cutting the dash for the speaker.
I’d have to take off the fuse cover to show you whitch one they used.
But you don’t need to remove any panels.
Just remove the fuse box panel under the dash. And just fish the speaker wire from the top, Super simple
      04-22-2023, 07:54 PM   #143
-c-
-c-'s Avatar
Drives: bmw
I just connected it to the fuse. I never turn off the stereo just turn it down. So it going up and Down when I start and shut off the car is the direction i took.
The installer said he would have installed a relay or different fuse to have it the other way around and it would have costed more money so I just went cheap .
So it’s been a few years now and happy to report it still works flaiwlessly and sounds great and no fading of the aluminum.
      05-30-2023, 07:50 AM   #144
Upurock
Upurock's Avatar
Drives: 2017 X5M
Edit:
Jumped to posting questions too soon lol, didn’t realize Thread is 7 pages long and all we’re already answered.
Great job OP! I don’t care much about the HK vs BO sound wise, but had popup speaker in my m6 and got used to it, so now if it’s get f85 with HK I know what to do!
Thank you!
2015 X5 50i Msport - RIP 10/2017
2016 M6 Competition Package - lease end
2018 540i Msport - enjoying now
Thinking of F85 🙏
      03-09-2024, 12:32 AM   #145
Staszek
Schumacher
Staszek's Avatar
786
Drives: E30 325is,E93 M3,X7M50,F06 M6
I know this is an old thread, but what fuses did you use for constant on and for the ACC? Not just the fuse number but what did they run?
      03-10-2024, 02:20 PM   #146
Cranswick852
Drives: F15 X5M 40d
Constant on was OBD2 port, switched was parking sensors.
