09-17-2017, 03:07 PM | #23 |
Rep 7,161
Interested to see where this is supposed to wire up to for power. Obviously im sure you can find any 12v source but more interested where its supposed to tie into.
please keep us informed on how it goes and where you tap in. Really want to tackle this once you have the part numbers!
09-17-2017, 03:21 PM | #24 |
Rep 7,161
ah nvm i just opened the link you add from F30 forum. Didn't realize it simply just plugs into the back of the NBT unit. I have already disconnected the center console enhanced usb thing in search for more storage space. also curious how much the cable cost from BMW as it's freaking $50 on eBay! yikes.
09-26-2017, 03:48 PM | #26 |
Rep 118
So I installed the center console USB port and connected it to the USB2 connector on the back of the nbt evo head unit and it doesn't work
Further reading suggests that the USB2 connection has limited functionality on MY2017 cars onward. To get the full functionality I need to connect to the USB1 hub. At the moment I have no idea where that's located. |
09-26-2017, 03:52 PM | #27 |
Rep 118
btw my source of info came from here....
http://www.bimmerfest.com/forums/sho...d.php?t=962585 |
09-26-2017, 07:54 PM | #28 |
Rep 7,161
Does it at least charge? What were you hoping for? Full playback functionality or something different?
Isn?t usb1 where the USB port in center console is plugged into? I thought usb 2 was we?re the enhanced usb center console would have been plugged into.
09-26-2017, 07:56 PM | #29 |
Rep 7,161
And is that package the PRT number for the small usb piece you show or the plastic face plate?
10-09-2017, 05:52 PM | #30 |
Rep 674
Bump, Trying to add this second USB, even if its only for charging.
From what I understand theres limitation on 2017 year model, so before that it should work? What parts should I buy Cable, Trim, and USB piece? Parts number? Thanks! |
10-22-2017, 12:43 AM | #31 | |
Rep 7,161
08-22-2018, 09:52 PM | #32 | ||
Rep 7,161
Usb socket: 84-10-9-237-656 Lower trim with slot for USB port: 51-45-9-389-629
08-29-2018, 06:22 PM | #34 | |||
Rep 7,161
The part also doesn't come with the cable that connects to the back of the head unit too
08-30-2018, 08:21 AM | #35 |
Rep 627
Drives: X5 F15 M package
What will you use the usb for ?
08-30-2018, 11:58 AM | #36 |
Rep 57
08-30-2018, 09:29 PM | #37 |
Rep 7,161
Charging a second phone. I don't like using the cigarette light cuz I drive a 2014 vehicle and even Hyundai's come with more than 1 USB lol. Plus I don't like have to open the drawer to get access to the cigarette lighter. I use it as a shelf go store things.
Plus I'm having intermittent issues keeping a solid connection when trying to charge due to the faulty NBT unit that BMW won't replace just for a bad usb unless I wanna pay outfight.
08-31-2018, 12:28 PM | #38 |
Rep 7,161
Ok think I found the piece I need just looking for confirmation from Jason at getbmwparts. It looks like it should slip right into the mount.
08-31-2018, 11:29 PM | #39 |
Rep 7,161
New part and CDC cable ordered and should be here next week.
09-01-2018, 07:35 PM | #41 |
Rep 7,161
I don't want to share it if it's wrong again. I'm gonna wait till it gets in next week and make sure.
sbinshihon684.50 X5D MSport18.00 |
09-10-2018, 08:15 PM | #42 |
Rep 7,161
Ok ladies and gents. Success can be reported. The part has arrived and it looks like pictures above with the correct US part number which is the one from the pics above. Not sure what happened when I put that part number in. I was a bit confused as I asked the guy which part number that baggy was for. Well turns out it's for the usb socket. Only issue now is the CIC cable I got doesn't fit properly. But I'm not returning it and will just dremel off one of the prongs and it should lock into place just fine. I just hope the other side fits into the back of the NBT unit.
CatalinP589.50 sbinshihon684.50 |
09-10-2018, 10:18 PM | #43 |
Rep 131
Keep us update on the result, thanks in advance.
Out of curiosity, are we able to enable enhanced Bluetooth function thru coding? I did that on my previous F30, not sure if it work on x5 as well |
09-10-2018, 11:39 PM | #44 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
It will.
Freude am Fahren.
