      08-30-2013, 08:35 AM   #1
AlpWhite11
Drives: 335i
Lightbulb 2014 X5 F15 first drive reviews
BIMMERPOST
     Featured on BIMMERPOST.com
EDMUNDS
xDrive50i
At launch, the most powerful drivetrain available comes in the xDrive50i, which combines a twin-turbo 4.4 liter V8 with an eight-speed paddle-shift transmission and all-wheel drive. A 3.0-liter straight-6 powers the xDrive35i, while the diesel-powered xDrive35d model will join the lineup next year. For the first time, a rear-wheel-drive X5 will also be available with the 3.0-liter gasoline power six only.
Output in the 2014 BMW X5 V8 climbs 10 percent to 450 horsepower and torque is up to 479 pound-feet. It's enough to shave half a second from the 0-62-mph time, which falls to an impressive 5.0 seconds flat. BMW says fuel economy improves a little, too, but there are no EPA numbers to back that up just yet.
Despite all the grunt, and the traction to make maximum use of it, the V8 X5 is not the fastest thing off the line. The engine and transmission need a few moments to absorb your right foot's command before launching the BMW forward with the urge you'd desired moments earlier. It's a pause that appears when you're on the move at lowish speeds, too, although switching to Sport mode does a bit to enliven the drivetrain. The twin-turbo V8 does make a nice sound, however, providing a satin V8 beat that turns impressively muscular when the throttle is sunk deep.
Not surprisingly, the X5 chassis is more than capable of handling the V8's efforts. Or it does in the form we tested the car in, which included the $4,500 Dynamic Handling package, which adds an air-sprung rear suspension, adjustable dampers, active antiroll bars and cross-axle torque-vectoring. The standard setup is rather ungenerously specified with steel springs, conventional shocks and passive antiroll bars, a combination we didn't get a chance to sample.
Even so, we would recommend the upgraded setup for two reasons. The first because this is a big load carrier in need of self-leveling, the second because we suspect the ride will need softening for broken tarmac moments. Dialed in to Sport mode, this X5 proves satisfyingly agile through bends both tight and sweeping. It's a vehicle that feels smaller than its bulk implies, and certainly nimble enough to entertain. It's also stable, steers accurately, stops convincingly and rolls enough to let you know what you're doing without turning remotely floppy and uncooperative.
A shame, then, that the new electrically supported steering takes the edge of this accomplishment by coming over curiously vague through the first few degrees of its movement. This faintly disconnected feel applies in both Comfort and Sport modes, too. Happily, it does little to undermine the accuracy of the X5's steering, but it does dim the sporting appeal of this sports activity vehicle.
As for the ride, it swallows most small bumps whole as promised, although the odd clatter across ridges and potholes in Sport suggests that it's the Comfort damping mode you'll mostly want on U.S. roads. It's unfortunate that in this setting the steering is a little too light — and you can't mix and match the steering, drivetrain and suspension settings to achieve an ideal blend.
There's no shortage of electronic driving aids in other departments, however: lane-keeping, radar-controlled cruise that extends to traffic jam stop-and-go, and (from December) a lane-keeping traffic jam assistant, too. Night vision and BMW's excellent head-up display also appear on an expensively lengthy options list.
At its heart, though, the X5 is still the sporting SUV that it was back in 1999. Perhaps too much so aesthetically, as this restyle is certainly short of imaginative flourishes. BMW would doubtless argue that the existing formula is very successful so there's little reason to make drastic changes.
It's certainly more polished this time around with its mix of big cabin comfort, luxury trimmings, sporting performance, all-weather security and accomplished manners. The 2014 BMW X5 is slightly spoiled by the V8's lazy step-off and that flawed steering feel, but neither shortcoming is pronounced enough to dampen the average buyer's enthusiasm for it.
Full review: http://www.edmunds.com/bmw/x5/2014/road-test.html
AUTOCAR
Muller’s toughest mission was tackling criticisms of the outgoing model’s ride, refinement and aura of quality, without adding heft. He's done well, with reductions to the bulkhead, glasshouse and wheel-well noise transmission improving refinement by a useful 2.5dB, while new seats have reduced vibration, and the subtly softened suspension smothers sharp bumps more effectively.
You’ll also enjoy this oil-burner’s much-improved manners, its clatter and growl now buried in background hum. Lots of low-rev urge and the eight-speed auto’s excellent anticipatory skills make for authoritatively brisk and effortless performance that, at lower speeds, shades the petrol xDrive50i.
So the essence of the 1999 X5’s mini-revolution is preserved intact, and this latest edition is pleasingly nimble and precise when the going gets twisty. The keen will enjoy such roads in sport setting, which enlivens the drivetrain, girds the dampers and weights the occasionally uncertain steering to produce a well-resolved driving experience.
And the ride? It swallows most small bumps whole, as promised, although the odd clatter across ridges and potholes in sport suggests that it’s the comfort damping mode you’ll mostly want on Britain’s roads. Given how well the rest of the system performs, it’s unfortunate that in Sport mode setting the steering turns over-light - and you can’t mix and match the steering, drivetrain and suspension settings.
Full Review: http://www.autocar.co.uk/car-review/...t-drive-review
AUTOEXPRESS
Verdict
The all-new X5 is now more handsome than before, better-built and more refined to drive. The 3.0-litre straight-six diesel remains at the top of the class for refinement and punch and the cabin is spacious, classy and superbly comfortable. In search of a more supple ride and improved on-road manners, it’s marginally less sharp than it once was, but it’s unlikely core customers will notice the change. It’s a successful update then that puts the new X5 neck-and-neck with the more expensive Range Rover Sport.
Full review: http://www.autoexpress.co.uk/bmw/x5/...#ixzz2dRDigBzV
Name:  Screen Shot 2013-08-30 at 6.46.21 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.46.31 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.46.40 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.46.48 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.46.56 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.47.06 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.47.15 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.47.24 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.47.35 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.47.44 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.47.53 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.48.03 AM.jpg
Name:  Screen Shot 2013-08-30 at 6.48.13 AM.jpg
      08-30-2013, 09:07 AM   #2
dan99
Drives: 01' 330xi / 15' M235i
it's so gorgeous
      08-30-2013, 09:12 AM   #3
newbimmerx5
Drives: BMW X5
Thanks for posting. I was about to post AE review. The pics are nice too. I see the UK model has different running boards compare to US model. Looks like its going to be a winner.
      08-30-2013, 09:12 AM   #4
btbossman
Drives: 2013 335xi M sport--2014 M6
Loving it the more and more I see it! At first I was worried
      08-30-2013, 09:14 AM   #5
Ghetto2315
Drives: 16' BMW i8
Looks like the current E70 X5 had a baby with the F25 X3 and the F15 X5 is the result...
      08-30-2013, 09:16 AM   #6
Luminor513
Luminor513's Avatar
1243
Drives: 2020 G07 x40i BSM/Blk Merino
Front bumper is too busy. Looks like they tried to morph the M4 front bumper onto X5. I don't understand these new busy front bumpers. Just like new F10 LCI non m-sport.
2022 Audi E-tron S Mythos Blk/Blk Valcona
      08-30-2013, 09:28 AM   #7
kdbryce
I have to return some video tapes
kdbryce's Avatar
Drives: e70 X5M
it looks terrible with those tiny wheels
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
      08-30-2013, 09:31 AM   #8
MRV99
MRV99's Avatar
2017 BMW M3 ZCP  [0.00]
There is one line in that review which makes me cringe.
"The fact that BMW has dialled down the dynamics slightly and upped the comfort levels"
Aka... Lets deviate away from the heart of what makes a BMW a BMW and become a Audi, Merc, Lexus homologation.
--RIP--
      08-30-2013, 09:39 AM   #9
Patarix
Drives: Bmw X5 30d
Beautifull!! That will be the exact exterior color and rims I will get when I order.
      08-30-2013, 09:44 AM   #10
Judah
13
Drives: Black E46 M3
"These things are relative though and the X5 will still dance rings around the Audi Q7 and Mercedes ML-Class."
      08-30-2013, 09:51 AM   #11
Phatcat
Drives: BMW M5, X5M
5kg lighter overall? So it's still a fat ass.....haha
      08-30-2013, 10:03 AM   #12
ATX78703
Drives: 2014 335i
i like how the f15 has shaped up, but.....
AE is wrong about the pricing.... a comparably equipped f15 is now neck-to-neck price wise with a RRS and Cayenne. It has exceeded past M-class, GX 460, Q7; and is a full 15K higher than a loaded MDX (still by many considered to be a class sales leader).
I know - i just cross-shopped all these and was thinking about ordering a new f15 to replace our e70. ultimately, my wife had so many complaints about the ride quality and we were not going to be able to test drive until october and needed a decision sooner. we ended up going with a pretty loaded ML350, which is right at 60K MSRP. A comparable f15 was about 68K, RRS HSE was about 68-70 also.
2014 335i RWD: ZMM, ZDA, ZDH, ZPP, ZTP, 2NH, 2TB, 5DL; Z4A MPPK; AW ext / VB int
      08-30-2013, 10:14 AM   #13
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
In line with everything BMW has built recently.
When I read reviews of the new 3 series compared vs the Audi and they say 'The BMW would not be your choice for a romp in mountain roads' I facepalm.
So sad
      08-30-2013, 10:32 AM   #14
760Lifan
760Lifan's Avatar
451
Drives: 2022 4xe Summit R & Trailhawk
I don't think the X5 shown in the pictures has any running boards. They are optional in Europe (even on the xLine).
      08-30-2013, 11:40 AM   #15
Blindside_137
Blindside_137's Avatar
Drives: 2011.75 SSII E90 M3 ZCP
Man that looks ugly. The previous X5 had such a better body shape.
      08-30-2013, 12:01 PM   #16
GOLFFRR
GOLFFRR's Avatar
10817
Drives: GOLFFRR cart
I think people are going to be 50/50 on the looks of this SUV but it will grow on them. I personally like it. I know in person it will look better as well.
the interior looks great as well!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      08-30-2013, 12:08 PM   #17
KellyK
Lady Driven
KellyK's Avatar
Drives: AW 2011 128i
i wish the fogs were lower. it would look alot better
      08-30-2013, 12:30 PM   #18
BMWDavid
Drives: MSport F30
2011 BMW M3 Sedan  [0.00]
2005(sold but not f ...  [10.00]
2006 X3  [0.00]
1984 633csi  [0.00]
It will look better in person for sure. I like the interior a lot. The drive and handling characteristics will be great as well.
      08-30-2013, 12:53 PM   #19
e85sbm
Snow Wizard
e85sbm's Avatar
Drives: F10 & E89
+1
      08-30-2013, 01:16 PM   #20
hellrotm
4143
Drives: F80
No thanks...new Range Rover Sport.
But if they offered the X5 M50d here, then that would change things.
      08-30-2013, 01:21 PM   #21
Lorde
Ya ya ya, I am Lorde, ya ya!
Lorde's Avatar
266
Drives: E90 M3, 2015 SQ5
2008 BMW M3 E90  [0.00]
Originally Posted by e85sbm View Post
+1
It looks like the kidney grilles are larger than the wheels!
      08-30-2013, 01:24 PM   #22
Jason
Administrator
Jason's Avatar
Drives: F80 M3
More pics, this time of the xDrive50i.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
