06-20-2019, 08:38 AM | #1 |
Rep 826
Drives: 2017 C43 AMG
Drivetrain Malfunction after new spark plugs and ignition coils
Hello, So about two months ago my car got a drivetrain malfunction while i was driving on the highway and turned out i had misfires on a few cylinders and my crankcase ventilation hose was cracked. The car stuttered and shook really bad. We replaced all 8 plugs with NGK Laser Iridium sold by BMS and OEM ignition coils. The drivetrain malfunction cleared and the car was fine.
Fast forward to this past weekend, I was at a red light and went WOT and the car threw a Drivetrain Malfunction again. I had DSC off and for some reason my car didn't upshift on it's own so it redlined and maybe even went past and hung there a second until i changed gear. So yesterday we tried swapping the mass airflow sensors to see if the banks the cylinders were misfiring on would change. It wasn't the MAF. We're gonna do the fuel injectors next but wanted to see if anyone here had any suggestions for what else could be causing this. car is a 2014 X5 50i with 63k miles and a dinan piggyback tune. I do drive it pretty hard and haven't had a lot of issues with oil consumption. In the two years I've owned the car I only had to top the oil off once.
06-20-2019, 09:30 AM | #2 |
1150
Rep 2,426
Did you gap it correctly; the NGK don't come pre-gapped at all.
My first change of spark plugs done by the dealer were not gapped correctly so I had a ton of WOT problems (I have RaceChip); after change to NGK and gapping the correctly, so far everything is working perfectly.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
r33_RGSport12971.00 |
07-09-2019, 01:17 AM | #3 |
Rep 826
I don't know if they are gapped correctly, I would assume they are but you never know. I'll have my cousins shop double check the spark plugs and make sure they're gapped correctly along with some other maintenance work. It went into BMW just today and got the fuel injectors replaced but it's still misfiring.
07-09-2019, 12:19 PM | #5 |
Rep 826
anyone know what the NGK plugs should be gapped at? 0.62mm?
also something else i wanted to mention. when we would clear the codes and turn the car on, it would turn on fine and the car would drive fine until i hit about 2.5-3k rpm and then start misfiring and throw the error. If i floored it, the error came up almost immediately.
07-09-2019, 02:21 PM | #7 | |
Rep 178
I am running the NGK 5992 / 95770 plugs gapped at 0.022".
I am running a JB4 and that is the recommendation from Burger while using that piggy back. They are a step colder than the OEM Bosch according to Burger. Quote:
07-09-2019, 03:24 PM | #8 |
Rep 299
Are there any cylinder codes present? A particular one? Reason I ask is because my 2014 just did this and I replaced with NGKs and brand new coils. Cylinder 5 kept coming up in the codes and shutting off that particular one out of nowhere.
Fast forward a month later and the car is getting a new long block from BMW. They changed injectors under the extended warranty but where still getting the code. Then they did a compression check and saw it had scoring in there and was lost compression. I don't drive mine hard at all. |
07-09-2019, 04:44 PM | #9 | |
Rep 1,434
2022 x5 m50i - Dravit grey
07-09-2019, 06:27 PM | #10 |
Rep 538
check tubings
Check the intakes, turbo tubings and charge pipe for leaks .
When the car and engine shakes during misfires those tubings can come loose. |
07-10-2019, 06:32 AM | #11 |
Rep 826
Another update - we took off the Dinan tune on the car and pulled out the NGK plugs. We used new OEM plugs, turned the car on and it's still misfiring. The car has just under 64K miles. I'm ready to throw in the towel with this damn car and I think it's safe to say this is probably going to be my last BMW.
07-10-2019, 08:44 AM | #12 | |
Rep 299
07-10-2019, 11:06 AM | #13 | |
Rep 174
I don't thinks it's reasonable to use an after market tune, drive it hard, then blame BMW for reliability issues. I know others have had no issues, but some do. You gotta pay to play. IMHO |
07-10-2019, 12:17 PM | #15 | ||
Rep 826
07-10-2019, 01:04 PM | #16 |
Rep 174
I see there is a lot of history on that engine in stock condition....
That said, companies that put out a beta product for customers to pay to develop, can expect some push back. |
