05-12-2016, 01:44 PM | #1 |
Rep 440
Eibach springs
Hello all
I'm thinking of lowering my car Need some feedback from owners How much stiffer is the ride Body roll How low did you go Do you have adjust the geometry Thank you |
05-13-2016, 04:51 PM | #2 |
Rep 64
Hi.
I lowered mine two days ago with Eibach. It's 2cm lower. The kit came with two front springs. I don't have springs rear. I contacted BaanVelgen and they said that back should be lowered at my dealer. So had to go to my dealer and they programed rear end to be lower 2cm. I decided to put on Eibach because of too much body roll for me. Before I drove 200km/h couple of times and the car didn't feel stabile. Now it's great. And the stiffnes is not an issue in my opinion. But I do have 20" Michelin non RFT tyres. Hope it helps |
05-13-2016, 06:04 PM | #3 |
<3 Flat Four
217
Rep 754
So u just went to the dealer n told them u need the rear to be 2 cm lower n they did it no questions asked?
I wonder if this is something that can be done with a coding cable or only with a special tool. |
05-13-2016, 07:52 PM | #4 |
Rep 5,483
Same...my understanding is that you need the links to lower the rear?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
05-13-2016, 09:23 PM | #5 |
<3 Flat Four
217
Rep 754
He said the dealer "programmed" it so I assume he has air suspension in the rear. And since technically the rear air suspension self levels then it should be doable with a computer to adjust the static height... But what tools to use.
05-13-2016, 10:46 PM | #6 |
Rep 64
Hi.
Yes I have air suspension at rear. No issue with dealer for doing that. I paid for programming. The front springs were installed at home. Asked for links at BaanVelgen and they answered I should go to my dealer. The ride is great. Not to stiff and more stabile when cornering. |
05-19-2017, 05:51 PM | #9 |
Rep 42
hello,i got my lower with H&R 1.3 all around,if you car have air bag at the rear the springs kits should come with 2 front springs and 2 rear links that u can adjust it.
05-28-2017, 06:44 PM | #11 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
460
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
I also went with eibach and absolutely love the ride. Less body roll in comfort mode and even better in sport. I also have a set of H&R springs for vehicles equipped with rear adaptive suspension if anyone is interested.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
05-28-2017, 11:53 PM | #13 | |
Rep 18,716
Do you have self-leveling rear suspension or not?
05-29-2017, 09:15 AM | #14 |
Rep 79
05-29-2017, 09:48 AM | #15 | |
Rep 18,716
The kit of the spring will comes with the links set. Unfortunately though, Eibach USA didn't bring in the set for self-leveling suspension. So your only option will be AC Schnitzer spring.
05-29-2017, 04:12 PM | #16 |
Rep 1,547
You can set the rake however you like it, since the rear links are adjustable and really just "trick" the vehicle into its ride height for the rear.
