      11-02-2022, 10:58 AM   #177
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Haha this is great. And bummshit. Back when I was doing these all the time they didn't have the bushing separate. Had to always buy new arms. Great to see they not only have separate bushings but a whole new arm or rather bushing type to go in. Either way next time this happens I'm putting in power flex. Had to swap the passenger rear lower 5k miles back.
I'm averaging just over 30k miles per side and just hit 77k miles. Luckily wife drives it now and works from home mostly so she barely drives it during the week.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      12-03-2022, 05:37 PM   #178
ve39
Drives: 750i
Hey fellas, I replaced the lower control arm (wishbone) due to a clunk on the car's right front. Unfortunately, that did not resolve the issue.
Is there any other part I can try replacing that's known for going bad?
      01-22-2023, 07:18 PM   #179
Ianx12
Drives: BMW
i had what i think is the same problem, that many have been trying to fix. i solved the issue by replacing the sway bar after replacing every other part in the front suspension, what an ordeal every thing looked good but I replaced them anyway only to not fix the problem. even the sway bar bushings looked great but they were the problem all along
      03-07-2023, 06:59 PM   #180
M302_imola
M302_imola's Avatar
843
Drives: '15 X5 35i Xdrive Mineral Whit
Front sway bar replacement is a big job from what I hear. Did you try just replacing the sway bar end links? I'm having supsension noise which I've somewhat narrowed down to sway bar end links. Gonna replace both front and rear. Maybe go ahead and change the rear sway bar bushings since they are easily accessible.
      03-29-2023, 02:25 PM   #181
Shorty1608
28
Drives: RB F15
Hi guys,
I get a knock when I go over bumps in the road or speed humps, what should I be checking first.. control arms, anti roll bar or something else?
Thanks
      03-30-2023, 01:32 AM   #182
tlow98
Drives: 2009 E91, 2014 F15 x35i
Shocks, control arms, loose hardware, sway bar end links, bump stops
      03-30-2023, 10:29 AM   #183
M302_imola
M302_imola's Avatar
843
Yep, I've already done control arms. About to do both front and rear sway bar end links this weekend.
_ObiJon200.00
      11-26-2023, 12:12 AM   #184
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
Hey guys 2015 x5 msport. I’ve been having suspension noise in the front end. I knew the lower control arms had slight play but not enough to cause the noise it had, also when rolling and hitting the brakes thrust arms shifting due to the bushing being worn. I found that my front struts were the issue for the noise, not leaking but the rod that compresses was “shaking” causing the noise. I decided the replace all four corners and went with air ride suspension(I know it’s not a lot of peoples choice) noise(clunk/rattle) dissipated but still had a slight noise. Knowing my front lower arms had wear, I replaced both lower arms in the front and the sway bar links. Noise practically gone, but clunk/rattle on bumps slightly there but a few weeks went by and noise has gotten more persistent. Can anyone guide me at this point, I’m wondering if the front upper control arms can be the culprit as they are the only things left to replace now.
X5 has about 85k on it
Thank you for assisting me in advance
      12-04-2023, 04:19 PM   #185
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
Anyone??
      12-04-2023, 08:58 PM   #186
_ObiJon
_ObiJon's Avatar
Drives: 2015 428i xDrive
Originally Posted by Vdesai0326 View Post
Anyone??
When I had a clunk in my front suspension, it was indeed the upper "thrust" arm. Specifically the ball joint. Once I removed it, I noticed there was zero tension indicating that it was completely worn out. I could move it with the tip on my finger it was so loose.
      12-04-2023, 09:06 PM   #187
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
When you say upper thrust arm, do you mean forward lower control arm? The one I’m talking about is the upper control arm, the picture I attached
      12-05-2023, 06:14 PM   #188
_ObiJon
_ObiJon's Avatar
Sorry, I meant the upper of the 2 lower control arms. It was the source of all my problems.
      12-05-2023, 06:15 PM   #189
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
Got it thank you, I replaced both Lowers, wonder if the ball joint went bad already
      12-05-2023, 06:23 PM   #190
_ObiJon
_ObiJon's Avatar
I've read that some folks have only gotten ~12k miles out of moog/delphi arms before they started making noise again. I'm at 10k with moog arms and no issues so far.
      12-05-2023, 11:28 PM   #191
tlow98
I’m at 25k on new lemforders and they make noise.
      12-12-2023, 09:50 AM   #192
mhenry
Drives: 15' X5 50i M-Sport
Mine just started the noise again. Had them done via warranty work when I initially purchased the car back in 2019, and noise was instantly gone.
51200 kms at the time(replaced left and right front control arms, and left and right tension strut)
Noise back at 92500kms so got roughly 41,000 kms/25,500 miles on them
Just found the work order, part numbers below if that helps anyone. This was on my 2015 50i M-Sport.
Control arm parts used:
1 31-12-6-864-822 WISHBONE, BOTTOM,WI
1 31-12-6-864-821 WISHBONE, BOTTOM, W
2 31-12-6-780-480 COMBINATION NUT
4 33-30-6-787-062 COMBINATION NUT
2 07-11-9-906-898 HEXAGON SCREW WITH
2 07-12-9-908-011 HEXAGON SCREW WITH
Tension strut parts that were useD:
1 31-12-6-851-692 RIGHT TENSION STRUT
1 31-12-6-851-691 LEFT TENSION STRUT
2 33-32-6-760-668 SELF-LOCKING COLLAR
2 07-12-9-908-068 HEXAGON SCREW WITH 1
      12-12-2023, 09:48 PM   #193
tlow98
Wow, basically the same milage I got out of mine. Out of curiosity, does yours make the wooden-ship noise or the click? Mine gets worse when it rains for whatever reason…
      12-14-2023, 12:37 PM   #194
mhenry
Yeah basically the exact same! Definitely the wooden-ship noise - prob the best way to describe it as it's almost a 2-step of bumps you hear. Like ornaments in rolling around in a container almost is what I thought after putting up our tree this week lol. Definitely not a click though. Very easy to replicate as it happens on any slow incline/speed bump in road/parking lot. Any slow bump in general. Will have to have it checked again for control arm play.
      12-14-2023, 03:38 PM   #195
Honda
Honda's Avatar
289
Drives: BMW
So is the clunk in front suspension a common issue on F15 ? I havne't seen this on E70 platform
      01-26-2024, 06:47 PM   #196
Vdesai0326
Drives: BMW X5
2015 bmw x5  [0.00]
Is the noise on uneven surface/bumps? As if something’s loose/rattling? I’m also thinking it’s the front sway bar at this point, I already replaced the front links noise is still there. Other option is to remove the sway bar links and drive it to see if it makes the noise anymore.
If you don’t mind, how much did you pay for the repairs?
Thanks
Ianx12
      02-18-2024, 01:06 PM   #197
Ianx12
Drives: BMW
The sway bar I got from the dealer around $400 at the time the repair I did my self I own a shop so I had a lift it took about 3hrs Not to bad of a job.
