12-10-2022, 02:41 AM | #1 |
Rep 17
Can only lock one side of the cargo cover
I am trying to install the retractable trunk / cargo cover.
Either the left side or the right side will lock into place. I cannot get both sides to lock, so when I pull the retractable cover one side is moving forward. What am I doing wrong? Is there a trick to get the cargo cover installed or in the "lock" positions on both sides? |
12-10-2022, 03:07 PM | #2 |
Rep 7,486
Are you following the instructions in the owners manual (or the manual embedded in iDrive)?
The lock is on the right side…but I slide the whole cartridge up to the posts…but make sure the left side goes in first, then I press the right side to lock it into place.
mike1267.50 |
12-10-2022, 03:11 PM | #3 |
Rep 17
Yes I did, but when the left side lock I can't lock the right side. I can only lock one side. It's so wired.
12-10-2022, 03:18 PM | #4 | |
Rep 17
12-10-2022, 04:00 PM | #5 |
Rep 7,486
Check the cargo cover cartridge to see if there’s something stuck where they slide into the locking posts.
How much pressure are you using to lock the cover when trying to engage it on the right side (where the lock release button is located)? And you’re positive you have the cartridge turned correctly (not installing it upside down)? Only asking because we are not there to get a visual of what is occurring.
mike1267.50 |
12-10-2022, 04:03 PM | #6 |
Rep 17
The button is on the roght side. I doing really hard to press it. There's nothing stuck on the sliding place, I just checked it. OMG 😭😭😭
12-10-2022, 04:05 PM | #7 | |
Rep 17
03-23-2024, 04:58 PM | #8 |
Rep 1
03-24-2024, 04:49 PM | #9 |
Rep 17
