      04-21-2023, 01:18 PM   #1
iorudzhov
Drives: Bmw x5 f15
6WB low fps
Hello everyone
I set myself a 6WB device, but the device does not work as expected, low fps at high speeds, it hurts to look at it. When you start the engine, the arrow immediately rises by one, although for many it rises smoothly. I thought it was a marriage, I went to the service, they changed me to another one, but the same thing. The firmware of the car last year, there is also a fresh firmware on the dashboard. 2014 car, 2017 cleaning. What could be the problem?
https://youtu.be/w88xKUP7NG4
https://youtu.be/UHXSLANf32k
https://youtu.be/SQqzaMyLOrQ
      04-21-2023, 02:26 PM   #2
RED_Y_
Drives: 2014 X5 3.5d
It is hard to tell from your video what exactly the problem is, I see some hesitation on the start up (first video) other two look ok to me. Assuming this is retrofitted 6WB did you do all the coding properly after your replaced it? To be specific did you CODE DKOMBI and HU_NBT?
      04-21-2023, 02:39 PM   #3
iorudzhov
Drives: Bmw x5 f15
In the other two videos, you can see how the rotation arrow does not move smoothly. As if the FPS is low, the video is certainly not as noticeable as in reality.
The device was reset to zero, after installation, the 6WB option was added and encoded across all blocks.
I-step the car has the last end of 21
      04-21-2023, 03:21 PM   #4
RED_Y_
Are you sure you are not comparing it to the newer G series cluster with higher resolution and smoother operation? I just recorded a short video for you to compare but I almost feel like yours is fine.
      04-21-2023, 03:28 PM   #5
iorudzhov
Drives: Bmw x5 f15
No. Even when you start the engine, the arrow is buggy immediately jumps by one, on other cars it rises smoothly.
Example on the video
https://youtu.be/2jENzao_600
      04-21-2023, 03:33 PM   #6
RED_Y_
Mine does the RPM jump on the start too:
      04-21-2023, 03:39 PM   #7
iorudzhov
Drives: Bmw x5 f15
I have an m50d car, how can I turn off the welcome animation of the m50d. What other encodings can help reduce the load on the processor?
      04-21-2023, 03:43 PM   #8
RED_Y_
That part is just a pre-loaded animation, doesn't really matter as far as I know, mine has a standard BMW start up logo.
      04-21-2023, 10:31 PM   #9
RED_Y_
Ok I think I see what are you talking about on your second video, there is a slight lag and your RPM seems to be choppy. Never seen such thing tbh, I will keep an eye on mine, may be I never paid close attention but I think mine is quite smooth.Also found similar problem on F30 forum:
https://f30.bimmerpost.com/forums/sh....php?t=1650962
      04-22-2023, 04:54 AM   #10
iorudzhov
Drives: Bmw x5 f15
Well, did you look at it?
There are suspicions that the firmware of the car does not match the firmware of kombi. I want to go to an official dealer and update the firmware to 23-03.
      02-14-2024, 03:59 PM   #11
Koteyka96
Drives: bmw 4
you find solution of your problem? I have the same in my bmw 4
