      01-25-2024, 03:41 PM   #1211
RED_Y_
Drives: 2014 X5 3.5d
Originally Posted by ocbrad1 View Post
2016 X5 x-drive 35i with the standard HID lights. Just before I rolled it over 100k miles, I noticed a lot of oncoming drivers flashing their high-beams at me. I had turned off the high-beams, verified by the fog lights coming back on. Unfortunately, whatever the mechanism is that adjusts the single HID bulb between low and high-beams (just give us the separate high-beam bulbs in the otherwise vacant inboard locations) is sticking on the driver's side. The passenger side "rotates down" (or whatever the actual function is, a filter?) but the driver's side stays in the high-beam position. But because it thinks that it's gone back to low-beams, the fog lights do come back on. Unfortunately, the driver's side lights (closest to oncoming traffic, natch) stay in the high-beam position. I can get out of the car with the headlights on, hit the top of the light housing with my fist, and it will rotate into the low-beam position. I don't know what the mechanism is that makes the shift between low and high, but presumably it is some sort of actual mechanical function that is sticking. I went to my dealer in the hopes that they would be able to find the right hinge or whatever to lubricate and I'd be on my way, only down a few hundred bucks. Nope. They said that it's broken, can't be fixed, and a new housing will only set me back $3200 or something ridiculous like that.
There has to be something mechanical that actuates the shift between low and high beams, because I can look at the light beam projected on my garage door when I hit the light housing, and I watch the beam literally angle down into the low-beam position. I don't know if there's some visor or something that normally sits over the top quarter of the projection that rotates up when high-beams are activated, or if the actual socket/housing that the bulbs are situated in itself rotates up or down based on whether high-beams are turned on or off. It seems weird enough that it's probably a common problem. Any thoughts out there?
HID lights are cheaper, you can probably just get new headlight off Ebay for $300-500 and just replace it, it sounds like the the shutter is stuck on one side.
      01-26-2024, 10:44 AM   #1212
MamiMoxi
Drives: 2020 X5
Bluetooth Apple CarPlay/Android Auto conundrum- I cannot keep my keys hanging anywhere close to the garage without my X5 stealing my phone calls if I walk past them with my phone in my pocket. Sometimes I’d also like to be able to put my bags in the car before I’m leaving and still remain on my handset until I get in the car. Is there a setting I can toggle to only activate Bluetooth once the car is started and to turn it off when the car is turned off?
The flip side is also less than ideal, with transferring calls back to the handset once turning the vechile off. There should be a button that pops up automatically to toggle back to the handset. Sometimes you want to still sit in the car and finish a call so I get it staying on after you cut the engine but there’s no intuitive way to transfer the call back and forth- or is there and I’ve just missed it?
      01-26-2024, 03:04 PM   #1213
jakeferryf87
Drives: bmw x5 f15
Not sure if anyone on here can help, I purchased an ex police bmw f15 2017, no heated seats, I have installed heated seats and the climate controller in dash, the heated seats won’t work, the passenger seats has full function, however the driver seat with memory has only function when ignition is on but not started once vehicle is started the seat function stops.
      01-27-2024, 04:50 AM   #1214
halson
Drives: BMW X5 F15 M50d
I own a 2015 BMW X5 F15 with NBT Id4 Head unit.
Lately I find on the internet (eBay) Retrofits of OEM NBT EVO ID6 Navi Systems and Screens (touch screen) for sale at quite good prices. In case of buying such a package is the overall upgrade possible / easy and also how can the coding be done for the specific car, is there someone who could safely do it remotely?
Thank in advance.
      02-19-2024, 02:12 PM   #1215
ahab_01
ahab_01's Avatar
Drives: 2016 BMW 228i
VCM Fault codes with ICM -Help!
2016 BMW x5 35d with rear air suspension, has the following faults come up with Protools. I recently replaced the right rear ride height sensor as there was a previous fault with low voltage, now just these are showing up. No other faults related to the ICM. any ideas what this might be?
VDC [VDC_25] | E69A41: Signal (vehicle ride height, 0x0E4) invalid, transmitter ICM
VDC [VDC_25] | 4828B1: Vehicle status management - active network fault lock - substitute entry
VDC [VDC_25] | E6AC64: Signal (vehicle ride height, 0x0E4) invalid, transmitter ICM
thanks!
      02-20-2024, 11:24 AM   #1216
BoyGeezyX5
Drives: 2018 X5 50i
2018 X5 50i 65-78mph vibration
Need assistance with a vibration issue I am having on my vehicle. I've changed transfer case and driveshafts and rear diff. Also swapped wheels/tires and still no change, vibration at the same point. strange my mechanic test drove the vehicle without the exhaust and the vibration is much lighter but still present. once we got to 80 things really started to smooth out.
Caveat I have BC racing coilovers, lowered approx 1.25", so not extreme. Also has magnaflow exhaust, was installed when I purchased the vehicle.
I think i may try a new front shaft from dentprotony but still testing a few things first.
      02-22-2024, 10:58 AM   #1217
freddymac
Drives: 2018 X5; 2019 X4
Oil plug on My 2018 X5
I took my car to the dealership for an oil change and was informed that the oil pan plug was stripped. I immediately mentioned that they are the only ones who have serviced my vehicle, and it appears that the technician made an error. The service advisor informed me that BMW cars have an aluminum oil pan, and this problem is quite common and is considered a technical defect with BMW. Has anyone else faced this issue? The cost to replace the pan is almost $5,000.
      02-22-2024, 09:56 PM   #1218
e90Jeet
e90Jeet's Avatar
15
Drives: 2018 X5 50i m-sports
Originally Posted by Hotflare View Post
Mine is doing this too. Ever find the problem?
What's the RPM range when it fluctuate? At cold start, mine goes up to ~1400 RPM and stay there for about ~10 seconds and drops down to ~700 RPM. However there's no vibrations when RPM drops down. I wonder if this is normal or soon i will be having similar problems? FYI Dealer recently changed all spark plugs.
      02-26-2024, 01:24 PM   #1219
RED_Y_
If dealership broke it-they fix it. Also indy shop can probably replace it for 1\2 of the price or less.
      02-28-2024, 08:04 AM   #1220
paul3757
Drives: BMW X5 2017
Anyone who can help me with how to solve the component protection?
I'm looking at this code: B7F87A HU-H: Theft-proofing mode active
I've found information about the FSC 170 patch but it seems that I also need "matching codes" from BMW? How do I get those?
Thx for your help!
      03-13-2024, 04:17 PM   #1221
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
More of the steering column blues
Originally Posted by DaveM1949 View Post
My 2016 X5's steering wheel stopped telescoping in and out. Doesn't retract when car is shut off and column switch just clicks when pushed or pulled up. The tilt works fine. I've heard that some people have found metal bits from the gears inside the column. Also have read that the motor can seize up and a couple of guys got it working by just banging hard on the wheel several times. The dealer wants to replace the steering column for $4,000! The position is fine for me where it froze. I'd just like to find a better way to get it working again for less than 4K! Anyone have any comments?
That’s what mine, and most of all the others, did when it failed. Warranty took care of mine, replaced with new not re-manufactured. Either you dig in and repair it yourself or find an Indy that will save you some $$$. Be glad it’s stopped in a position you can live with.
Good luck.
      03-16-2024, 08:21 PM   #1222
smdjshack
Drives: BMW X5 (F15)
Exclamation Rear suspension sagging
So, regularly, over the past 3 months, the rear suspension has been sagging. Air bags and lines have been checked for leaks, none. Replaced the desiccant in the pump, replaced the pressure relief solenoid (it was defective and stuck open). The sagging doesn't occur over night, sometimes it's when we come to a stop and the engine shuts off (eco). I've seen it go down on my Ring camera over a 5 minute period, first one side then the other. Once deflated, it either needs to sit for a while and reset or it will reset with removal of the fuse and sometimes the relay. The suspension can go for days, sometimes a week, without deflating. Are there any additional modules I should check? The rear position sensor arms are intact and the self leveling between the rear sensors and headlight sensors does work when the pump has to inflate the suspension. I'm concerned that either my battery is going down, some internal software issue is telling it to deflate or there's another module I'm missing in my troubleshooting. It's a 2018 X5 35i M Sport w/ 3rd row seats, 83,000 mile.
      03-19-2024, 12:10 PM   #1223
dr_greenthumb
Drives: 14' F15 X5 35i x
My oil plug stripped too when removed, it took the threads with it. Just go to Napa and bring your old pan bolt and buy a helicoil or something similar.
      03-19-2024, 05:26 PM   #1224
mrfochon
Drives: X5 F15 M package
Hi all
A few days ago when leaving and turning all the way to the righ a loud cracking noise happened.
Since then when I turn the car all the way left this time, the car vibrate as if something is loose.
Found a few thread but could not guess.
Any help is appreciated
Thank you
      03-19-2024, 06:22 PM   #1225
Chilled
Chilled's Avatar
Australia
364
Drives: F85 X5M
Originally Posted by mrfochon View Post
Hi all
Thank you
Take to mechanic.
      03-20-2024, 04:29 AM   #1226
mrfochon
Originally Posted by Chilled View Post
Take to mechanic.
They still call that silver..?
      03-30-2024, 02:45 PM   #1227
waelaburezeq
Germany
Drives: 2.0 ltr 2007 E90
xDrive50 F15 - DME & DME2 ECU Errors (Hot Film Air Mass Meter "2")
Hey folks,
I have been experiencing a very bad mileage on my V8 F15, the full tank is barely hitting 450 "km"
Plugged ISTA+, and discovered two errors on DME and DME2 with similar message for both "Hot Film Air Mass Meter 2, air filter element 2".
Later, looked into DME air mass and DME air mass 2, but readings were almost the same +13 kg/h.
Do I have one sensor, i.e: Meter 2 faultly? Should I give it a try and clean it using Air Mass Cleaner?
Or is it something else?
Attaching the screenshots of ISTA, DME and DME2
      04-01-2024, 03:14 PM   #1228
dcormary
Drives: BMW X5, Z3 and Clubman S
Hi BoyGeezyX5
I have the same issue on my 2017 X5 with 52k miles. had the transfer box replaced, new high quality Michelin tires and paid an ungodly amount to BMW for a "deep balancing". No joy, small vibration at 78 mph until roughly 84 where it disappears.
As you are highlighting, this can quickly become a parts canon situation..kindly report any progress. thanks!
      04-02-2024, 07:17 AM   #1229
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Did you have a chance to examine stored codes?
      04-03-2024, 09:52 AM   #1230
gbhurry
Drives: X5
All,
New to the forum, long time lurker, first time poster.
2017 X5 M50d owner. Owned for nearly two years and love the car. Ticks all the boxes.
Have had a previous issue with the infamous "sagging rear end" - deemed to be leaky rear bags (50k and 5 years old, seems to be around the trigger). Bags replaced with Dunlops 3 months ago - no issues since. Until last week.
Car was fine. Started her up, sat in to wait for 3/4 minutes to warm up and the rear sagged right to the floor. Almost as if the compressor wasn't working. "Chassis" warning came on screen (not the limited/restriction message, simply "Chassis - get it checked".
Took into BMW this morning and they have called stating the compressor needs replacing. Eye watering amount.
I am considering moving to springs, front and rear - Eibach seem to be the go to. A couple of questions though;
How can I confirm that it is indeed the compressor that has gone?
Can my car be converted to spring only?
If yes - is any coding required to when removing the air system?
Anything else I should be aware of?
Thanks a lot!
      04-06-2024, 12:07 PM   #1231
viktorbaffil
Drives: BMW X6
2015 BMW X6 F16 - Drivetrain malfunction warning
Hello guys,
2015 BMW X6 F16 xDrive3.5i
Recently the car is showing this warning, the warning is not happening all the time, only when I turn on the ignition (without turning on the engine)
Warning: Drivetrain malfunction
I purchased a Foxwell Diagnostic & Scanner for BMW and when the issue appeared I ran the scanner and it showed:
Power Control Unit PCU - Fault1
Error Code: D49405
Description: No message (crash control, 105.0.1), receiver PCU, transmitter ACSM
I was searching online about this error code D49405 and I found:
Fault Code Conditions:
General Conditions Supply voltage between 9 and 16 volts.
Terminal Condition Terminal 15 On
Terminal Condition PWF status: Driving
Terminal Condition PWF status: Residing
Driving Conditions Notice: The designations of terminal status or PWF status apply according to the vehicle electrical system.
At this point, I ran out of ideas how to pinpoint the module/part causing the issue.
This car has 2 batteries, the main one was replaced 3 years ago, the small one will have 10 years soon (I thought it could be related)
Any help will be greatly appreciated!
Thanks,
Viktor
      04-06-2024, 04:46 PM   #1232
gokinsmmm
United Kingdom
Drives: bmw x5 f15
TPMS
Hi everione ,having f15 30d for 2 years .on my drive having RPA flat tyre monitor.
Car comes with tyre pessure sensors and also module in the boot ,probably was decodet previusly ,how can i code it again with bimmercode .
thanks
