06-08-2018, 04:19 PM | #177 | ||
Rep 7,162
KOMBI 3000 KL_PREDRIVE_F17_STA - aktive KOMBI 3003 STA_ENABLE - aktive but I have coded all of these and still get the TJA error and steering wheel error on my display.
06-08-2018, 04:40 PM | #178 |
Rep 120
06-08-2018, 05:31 PM | #179 | |
Rep 983
The existing button set that came with ACC S&G works just fine. The bottom right button is re-purposed to activate TJA. The top right button now just toggles through the ACC distance settings, instead of only providing the "decrease distance" function. It functions just as the manual describes (congestion assistant in the manual) Last edited by spike5150; 06-08-2018 at 05:41 PM.. |
06-08-2018, 05:38 PM | #180 | |
Rep 983
Without the Quidzel chip, you need touch enabled steering wheel, touch module and wiring harness. Optionally you can also buy the correct button group, but it isn't necessary for TJA to function. |
06-08-2018, 05:45 PM | #181 |
Rep 983
Did you do the BDC_BODY and ICM coding? I also VO coded the KAFAS2 module, but not sure that was necessary.
06-08-2018, 06:30 PM | #182 | |
Rep 120
06-08-2018, 08:24 PM | #183 | |
Rep 7,162
06-08-2018, 09:08 PM | #184 |
Rep 983
06-08-2018, 09:31 PM | #185 | |
Rep 7,162
Now I let it sit and all the lights on the dash went out despite NOT being able to clear them with BimmerLink. I'll give it a whirl again tomorrow now that the lights are all out.
06-10-2018, 07:55 PM | #186 | |
Rep 983
06-10-2018, 08:48 PM | #187 |
Rep 7,162
Nope. Still get the malfunction. But I didn't check all the coding. Will take a look after work tomorrow.
06-14-2018, 08:03 PM | #188 |
Rep 983
06-14-2018, 10:32 PM | #189 |
Rep 7,162
Nope. The guy from the company asked me to unplug and replug in the chip from the harness with the car on and see if the orange triangle goes away in hopes to "sync" it with the car
06-15-2018, 10:18 AM | #190 |
Rep 983
06-15-2018, 08:08 PM | #191 |
Rep 7,162
Ya might have to. He did say he would walk me through it if I had issues so we will see if I got time I'll tweek it this weekend
07-12-2018, 08:18 PM | #192 |
Rep 535
Can you clarify that all you eventually ended up needing was the TJA module, its cable and Quidzel chip for your DIY (basically not getting a new steering wheel)? Or do you just need the Quidzel chip only and dont even need the TJA module?
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi Last edited by sj22; 07-12-2018 at 09:09 PM.. |
07-12-2018, 09:41 PM | #193 |
Rep 983
Only need Quidzel chip. Car must also have ACC+stop and go and drivers assistance package with lane departure warning et al.
07-12-2018, 09:42 PM | #194 |
Rep 983
07-15-2018, 11:05 AM | #195 | |
Rep 7,162
I'll try and take a look tonight to get it going.
08-04-2018, 08:18 PM | #196 |
Rep 535
Bought and just installed the chip. Hope to code tonight. Was actually quite easy to install - pop airbag (did not disconnect airbag or battery), and was able to access connector without taking even a single screw off since I didn’t have the paddle shifters.
08-04-2018, 08:58 PM | #197 |
Rep 239
My car does have the ACC stop & go function and lane departure warning as well. But in order to get traffic jam assistant, we have to buy and instill this Quidzel chip?
08-04-2018, 10:56 PM | #198 | |
Rep 7,162
The coding is what gives the car traffic jam assist and yes only works if you have ACC.
perry8912101.00 |
Tags |
driving assistant, traffic assistant |
