      02-11-2024, 11:47 PM   #5831
shawnsheridan
shawnsheridan's Avatar
Originally Posted by caio123 View Post
Where can i find on bimmerutility to active 1) low beam as welcome lights 2) fog lights as welcome lights ?
Found all these options on bimmercode, but can't find it on bimmerutility.
Thanks.
Need to search BDC CAFD for the corresponding FDL Codes.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      02-12-2024, 12:08 AM   #5832
caio123
Drives: 320i
Any idea how can i do that ?
Bimmercode (on comfort mode) have all these options, bimmerutility doesn't.
      02-12-2024, 12:13 AM   #5833
shawnsheridan
It depends on if you are using BU as standalone Coding App or with E-Sys, but either way, you need to Read BDC, and it will open up in FDL Editor, where you can search and change FDL Codes.
      02-12-2024, 12:23 AM   #5834
caio123
Drives: 320i
BU standalone, on FDL editor there are to many entries with no description, don't have a clue in what to change. There are no information on XML cheat sheet either.
      02-12-2024, 12:25 AM   #5835
shawnsheridan
What is the name of BDC CAFD?
      02-12-2024, 12:41 AM   #5836
caio123
Drives: 320i
what is the name of bdc cafd?
cafd-000017be-042.100.099 - codingdata body appl
      02-12-2024, 12:35 PM   #5837
shawnsheridan
You do not see anything like this?
      02-12-2024, 11:24 PM   #5838
caio123
Drives: 320i
Yes, but without comments.
On BU should I use decimal values ?
On the drop down menu of these itens I don't see decimal values.
Thanks.
      02-13-2024, 12:03 AM   #5839
shawnsheridan
Thanks.
Sorry, I do not understand what you ask about Decimal Values. Post same picture as mine from your BU.
      02-15-2024, 09:40 AM   #5840
zillarino
Drives: BMW X5 50i 4.4L 2014
Hey shawnsheridan could you send me the link for ESYS + psdzData LITE (Assuming I don't need the full one from what the original post mentions)? I have a 2014 F15 50i and I need to flash the AAG Trailer Control Module on my vehicle.
      02-15-2024, 09:47 AM   #5841
shawnsheridan
PM sent.
      03-17-2024, 03:18 PM   #5842
Stamps
Stamps's Avatar
Drives: 2017 F85
Is it possible to code the fog lights to turn on automatically with low beams?
And/or code the fogs to stay on when high beams are turned on?
1004ron28.00
      03-25-2024, 03:19 PM   #5843
Breezer88
Breezer88's Avatar
89
Drives: '18 F15 N55 M-sport
Hi Shawn,
Can you send me the download links for e-sys and instructions for the latest. I had v 2.8 but it kept failing also stating token invalid and no certs found. Also, what are the latest PC requirements.
Thanks, Mike
      03-25-2024, 05:21 PM   #5844
shawnsheridan
Originally Posted by Breezer88 View Post
Hi Shawn,
Thanks, Mike
PM sent.
      04-13-2024, 01:03 PM   #5845
cals
cals
cals's Avatar
17
Drives: E34, E39, E60, F10, E70, F15
2017 BMW X5  [0.00]
2001 BMW E39  [0.00]
2004 BMW E60  [0.00]
2011 BMW F10  [0.00]
2007 BMW X5  [0.00]
Hi Shawn -
Could you please send me the links for the diagnostic software?
Thanks in advance for your help
      04-13-2024, 02:36 PM   #5846
shawnsheridan
Originally Posted by cals View Post
Hi Shawn -
PM sent.
      04-20-2024, 04:09 PM   #5847
Waleedheno
Drives: BMW X5
Hi Shawn, Can you please send me the latest cheat sheet? as the google doc link in the post is not available anymore.
      04-20-2024, 04:19 PM   #5848
shawnsheridan
No. Cheat Sheets fell out of favor long ago for cheat.xml files used by LauncherPRO / BimmerUtility.
      04-24-2024, 01:21 PM   #5849
chrisnmandy
Drives: BMW X5 F15
Help with AAG module
Everything seems to be flashed correctly to the AAG module but getting the following error on trailer module in BimmerCode:
802840
Power Supply KL30f left missing / interrupted
Dash screen shows:
Trailer Electrics overload:
Trailer not lit or only partially lit. Turn off electrical devices in trailier. If fault persists, consult service center.
CAFD appears flashed to AAG module
235 in HO-WORT
Used new factory retro fit wiring and new AAG module.
No trailer attached.
Any ideas. Can share any screenshots etc that may be relavant.
      05-05-2024, 06:41 PM   #5850
heavy_D
Drives: F15 35d daily, Q5 TDI wife's
I imported an F15 from Canada and am trying to add the US State Vehicle inspection CBS as well as code default units to imperial from metric (I know I can change units in iDrive, but when profiles are reset they default to Canadian metric). I can't find either settings to code in ECUs, do I need to remove the Canadian Version VO to get these features?
      05-09-2024, 01:02 PM   #5851
jimmygks5479
jimmygks5479's Avatar
Drives: BMW X5 F15
Hi Experts,
Could you guide me on how to use BimmerCode to adjust my headlight to be flat (one line without convex)like the LEFT side?
FYI. I from Malaysia.
      05-09-2024, 01:07 PM   #5852
1004ron
Drives: 2015 BMW X5 xDrive35i
I've used BimmerCode for a good few things but struggling to find how to achieve this.
