05-01-2023, 03:42 PM | #1 |
184
Rep 364
Drives: M2C X5M M4
could someone with a standard f85 measure...
Hi
Could someone without spacers run a tape measure across the two axles and measure the outside width from tyre to tyre. I’m looking for the width of the car at ground level I.e. what would not scrape the wheels and tyres. Thanks in advance |
05-02-2023, 08:55 AM | #2 |
Rep 7,538
Is this what you're looking for? I got this info from a PDF download of a 2017 owners manual and google search.
Since the rear is slightly wider than the front...if you need to squeeze into a narrow space...I'd use the specs for "width with mirror" to assure clearance.
05-02-2023, 11:56 AM | #3 |
Rep 95
Measurement taken from 2018 F85 with no wheel/suspension modifications.
I got 77". Note that I'm currently on my winter set 20" which are 285/40R20. I will be putting my OE 21" summer set this weekend which are 285/35ZR21 and 325/30ZR21 and can re-take these measure for you then. |
