09-14-2021, 03:07 AM | #24 | |
Rep 93
Thanks ! |
09-14-2021, 05:49 AM | #25 |
Rep 1,028
Don't mean to highjack, just found the topic of doing from id5 to 6 and am wondering if there is any functional difference between the two.
Particularly i am interested in music playback from USB with shuffle on. Currently on id5(touchscreen) there is no next/back button on screen if you play from a usb with shuffle on. Was hopping this would have gotten added. |
10-31-2021, 09:56 PM | #27 |
Rep 9
Recently I purchased a 2018 Mini Countryman, and I want to activate the Apple CarPlay Full-screen option, but I can't because the car has come with the version NBTevo_L and I need the version T or higher.
I cant find on the web a DIY for Mini Cooper like yours. Only guys that sell the upgrade service or Full-Screen Service I have Installed the Full version with the Esys 3.27 on my laptop and I download the v.4.31.31_PSdZData full. I have an Enet cable and a battery charger too My questions to you are: 1) Is it the same procedure as you did to your car, with a Mini? 2) If I follow your procedure the graphic interface change from MINI to BMW or remain the Mini interface? 3) You worked on F85 car, and you choose the F025 on the connection menu, My car is an F56, must I choose F056 or work with another type? Thanks in advance, Jose C. |
11-01-2021, 01:28 AM | #28 |
Rep 1,353
Choose F56 Without DIRECT, Follow the same exact steps you are good to go. No your unit still will be under mini logo. If any case you can code back to mini or default coding will revert back to mini. Lmk!
11-19-2021, 06:07 AM | #29 |
Rep 26
Hi All,
im having a strange issue not sure if im missing anything - NOVICE Alert I have manage to activate FA under tal calculating and read ECU as i have an X5 F15 but i have no options to set my kis/svt target i-step as its greyed out My current version is nbtevo_M i have tried enabling apple_enhancements but im guessing it wont work until im on a later version. i cant seem to create the TAL file to explore it as i cant get past setting the i-step selection therefore cant save the SVT_Tal |
11-19-2021, 09:15 AM | #30 | |
Rep 40,931
SaNGRia990.00 |
12-04-2021, 08:03 AM | #31 |
Rep 2
shawnsheridan SaNGRia
Thank you for this guide! After finding out that my Psdzdata was corrupted, I downloaded the latest, deleted the old folder, and unzipped all again with Winrar. Check dependencies, HU didn't have any. Followed the guide, all went well till the end, when I got an error that TAL Execution failed. Now my HU is stuck on 'Flashing 0%' blue screen, I get a 'Drivetrain Error' and my gearbox doesn't work anymore .... What can I do guys? |
12-04-2021, 11:48 AM | #32 | |
Rep 1,353
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
12-04-2021, 11:58 AM | #33 | |
Rep 40,931
12-04-2021, 11:49 PM | #34 |
Rep 1,353
Thank you for the update bro.
12-11-2021, 09:36 PM | #35 |
Rep 9
Recently I purchased a 2018 Mini Countryman, and I want to activate the Apple CarPlay Full-screen option, but I can't because the car has come with the version NBTevo_L.
I followed all your steps in your tutorial to do the update A few days ago I flashed the car with the v.4.31.31_PSdZData full, and the car was updated to the NBTevo_U193841 version, but this version does not support the Apple carplay full screen. Then, I downloaded the most recent psdzdata 4.32.33 full version to try to gain the most updated version for the idrive. Today After flash with this psdzdata version, the idrive still with the same version NBTevo_U193841. Does somebody know why with two differents psdzdata versions I get the same software update? Please, What I need to do to reach a newer or higher version than NBTevo_U? |
12-12-2021, 12:02 AM | #36 | |
Rep 40,931
SaNGRia990.00 |
12-12-2021, 04:55 PM | #37 |
Rep 1,353
Correct. SWFL and IBAD has to be replaced with 007_030_001.
12-12-2021, 07:42 PM | #38 |
Rep 40,931
I think you mean BTLD as I wrote, not IBAD, which is the Owners Manual (Interaktive Betriebsanleitung Daten).
007.030.001 = NBTevo_X20511I 007.037.001 = NBTevo_Y21272I
SaNGRia990.00 |
12-12-2021, 08:23 PM | #39 |
Rep 9
12-12-2021, 08:25 PM | #40 |
Rep 40,931
You have to modify TAL in E-Sys TAL Editor.
12-12-2021, 09:19 PM | #41 |
Rep 1,353
Thank you for the correction. Does the 4.31.12 contains 007.037.001? I recently got the full daten and still calculates 007.030.001 on my F85.
12-12-2021, 09:53 PM | #42 | |
Rep 40,931
You need at least v.4.32.12 to get F020-21-11-510. And Latest v.4.33.11 is F020-21-11-535.
12-12-2021, 11:08 PM | #43 |
Rep 1,353
Excellent thank you.
12-18-2021, 02:20 PM | #44 |
Rep 9
