09-29-2014, 05:02 PM | #133 |
Rep 208
09-29-2014, 05:20 PM | #134 | |
Rep 3,990
I might want to try the VLD coding. Let me know how it works for you after you do it .
09-29-2014, 05:39 PM | #135 | |
Rep 18,721
It work perfectly fine. Just hope BMW doesn't remove the hardware to the cheaper one where you can't just code it.
09-29-2014, 08:00 PM | #136 | |
Rep 208
Add 6NS to your VO and then VO code HU_NBT, you do not need to remove anything from the VO first do you think we missed any steps @r33? If this is correct. I will just remove that, VO code HU_NBT and will code it again to make sure it was implemented right. |
09-29-2014, 08:02 PM | #137 |
Rep 208
09-29-2014, 08:46 PM | #138 | |
Rep 3,990
The only reason I'm holding back is because I have so much BDC_Body coding done, lol.
09-29-2014, 08:54 PM | #139 | |
Rep 3,990
09-29-2014, 09:30 PM | #140 |
Rep 18,721
@Hang0ver, as @opasha mentioned, make sure that you remove the 6NH before you added 6NS.
Also, when you about to code the HU_NBT, make sure that you re-read the FA and ECU again. Just to be sure that you are on the updated FA. Did that mistake once and was about to slam my laptop.
09-30-2014, 06:17 AM | #141 | |
Rep 208
09-30-2014, 06:21 AM | #142 | |
Rep 208
09-30-2014, 06:22 AM | #143 | |
Rep 208
10-01-2014, 04:15 AM | #144 |
Rep 424
Hi, sorry for the delay - been away for a while. I'll PM me your email address and I'll send you the CAF files assuming you still need them.
X5 F15 - gone after 5 months!
10-01-2014, 06:39 PM | #146 |
Rep 208
@opasha, @shawnsheridan, @r33 : got this error when coding CAFD after VO coding. According to VO coding instructions, it mentioned to Read SVT, but that returned error. So, I did read ECU and then coded KAFAS2, etc.
Is that the reason for this? A quick google found some results to me from Token master saying this is caused by incompatible psdzdata files. But it doesn't affect coding. Please share your thoughts. Also, if we can add these to the OP, it might be helpful as one stop shop for others. Just did my VLD coding and did a small 1/4 mile drive with expired temp tags ... Its pretty dark here and I can see the lights turning and moving during the drive thanks for your help. Also to note, when I did code KAFAS2, etc, they generated below error, but the last popup showed everything in green. Which I assume went well. Code:
Caf's suchen Tal wird generiert Abarbeitung wird gestartet TAL execution started. ExecutionID=2014/10/01-19:08:52.629 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForCoding started [] prepareVehicleForCoding finished [BDC_BODY - 40] prepareECUforCoding started [BDC_BODY - 40] prepareECUforCoding finished [BDC_BODY - 40] authenticateECUforCoding started [BDC_BODY - 40] authenticateECUforCoding finished [BDC_BODY - 40 - cafd_000017be-005_028_170] Transaction type: cdDeploy; Message: TA started [BDC_BODY - 40 - cafd_000017be-005_028_170] Transaction type: cdDeploy; Message: TA finished [BDC_BODY - 40] finalizeECUCoding started [BDC_BODY - 40] finalizeECUCoding finished [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "Finished". [C207] TAL execution finished. Duration: "10s". [C206] MSM update: Read current SVT. [C194] MSM update started. [C215] MCDDiagService<id=378649, job=com.bmw.psdz.jobs.uds.MCD3_ReadF11DataFromMSM, service=RC_GET_PARAMETER_N11 - RoutineControll GetParameter N11, description=error: negative response : requestOutOfRange, link=MSM_ETHERNET> MCDDiagService<id=378649, job=com.bmw.psdz.jobs.uds.MCD3_ReadF11DataFromMSM, service=RC_GET_PARAMETER_N11 - RoutineControll GetParameter N11, description=error: negative response : requestOutOfRange, link=MSM_ETHERNET> MCDDiagService<id=378649, job=com.bmw.psdz.jobs.uds.MCD3_ReadF11DataFromMSM, service=RC_GET_PARAMETER_N11 - RoutineControll GetParameter N11, description=error: negative response : requestOutOfRange, link=MSM_ETHERNET> MCDDiagService<id=378649, job=com.bmw.psdz.jobs.uds.MCD3_ReadF11DataFromMSM, service=RC_GET_PARAMETER_N11 - RoutineControll GetParameter N11, description=error: negative response : requestOutOfRange, link=MSM_ETHERNET> MSM update finished. [C216] VCM Update: Write FA to VCM. [C188] VCM Update: Write FP to VCM. [C190] VCM Update: Read current SVT. [C191] VCM Update: Check current SVT with TAL. [C192] VCM Update: Write target SVT. [C193] VCM Update: Write FA to backup. [C189] MCDDiagService<id=272649, job=com.bmw.psdz.jobs.uds.vcm.MCD3_WriteFAtoVCMBackup, service=WDBI_FA1 - WriteDataByIdentifier FA Teil 1, description=error: negative response : requestOutOfRange, link=VCM_BACKUP_ETHERNET> [Exception - VCM_BACKUP - 40] job failed with negative response error: code: service returned global negative response description: Service WDBI_FA1 returned a negative response with response code requestOutOfRange; ECU: VCM_BACKUP_ETHERNET severity: ERROR VCM Update: finished with error. [C196] Error in VCM Update: Write FA to the Backup Partner failed. Possibly there is no connection to the Backup Partner. [C097] job failed with negative response error: code: service returned global negative response description: Service WDBI_FA1 returned a negative response with response code requestOutOfRange; ECU: VCM_BACKUP_ETHERNET severity: ERROR [433] Abarbeitung beendet |
10-01-2014, 07:32 PM | #147 |
Rep 3,990
OP updated with reference to QUICK TIP #2 that I had forgotten to write. This deals with @Hang0ver's error post above. Thanks @Hang0ver for bringing this to my attention .
2) In order to avoid any VCM update errors (this does not affect your coding), go to the top of ESYS and click Options > Settings > Options tab. UNCHECK BOTH "Update VCM after TAL execution" and "Update MSM after TAL execution." This is what I had read a while back by @shawnsheridan for our F15 coding. I had unchecked these when I first installed ESYS but forgot to list this. EVERYONE MAKE SURE TO DO THIS so you avoid VCM update error codes like the one @Hang0ver got on post #146. Even if you get an error, it does not harm your coding; to avoid this error, just uncheck those two options I mentioned.
10-01-2014, 07:44 PM | #148 |
Rep 40,867
You should UNCHECK BOTH "Update VCM after TAL execution" and "Update MSM after TAL execution" for all chassis, not just F15.
As for Read ECU instead of Read SVT, it is like this for F15 only, and I do not have an explanation as to why. For 15, you must also increase E-Sys memory option from 512 MB to 1024 MB, or in most cases you won't be able to read BDC Module as it is so big.
10-01-2014, 08:03 PM | #150 |
Rep 18,721
@Hang0ver, there you go, you got it taken care by the master, @shawnsheridan.
10-01-2014, 08:05 PM | #151 |
Rep 208
Agree...From last couple days, I was browsing different different threads in bimmerfest coding forums and to my surprise each thread has a solution by shawn. I felt like, Man is this guy the person behind BMW
10-01-2014, 08:09 PM | #152 |
Rep 40,867
I've just had a long time figuring this stuff out. My F10 will be 4 years old the end of this year.
10-01-2014, 08:25 PM | #153 | |
Rep 3,990
Shawn's a great guy and a big help to the whole BMW community. As always, thank you @shawnsheridan.
10-01-2014, 08:27 PM | #154 | |
Rep 208
