10-23-2021, 02:05 PM | #1 |
498
Rep 697
Drives: Alpine White 2020 BMW M2C
Garage List 2017 BMW X6 M [0.00]
2020 BMW M2 Competi ... [0.00] 1993 Mazda RX-7 [0.00] 2006 Mitsubishi Evo ... [0.00] 2005 BMW M3 ZCP [0.00] 2016 Ducati Panigal ... [0.00] |
Tick when turning the wheel?
My X6M has developed a ticking sound when I turn the wheel all the way to the right. I noticed it when doing a u-turn today. It only happens when the wheel is turned all the way to the right. Less than full turn, or turning left doesn't make the sound. It sounds like a metal tick, and a slight rattly tamborine kind of sound...
Does anyone have any idea what that might be, and could possibly point me in the right direction on how to figure it out. What to look for... etc.. This is going to have to be a DIY repair. |
10-27-2021, 12:33 AM | #9 |
498
Rep 697
well hell. this seems super simple. thanks for the info/links!
so this is resolved by putting a washer in between the hub and the rotor? that seems too good to be true. hehe is there any way to tell if this is the problem before I go buying parts? |
10-27-2021, 07:06 AM | #10 |
F86, G05, E91
455
Rep 778
I had the fix last year and it still seems sporadic. Hub is fine with no play. Only comes out under lateral load. It seems to goes away when I put winter wheels on. It really sounds out at autocross events. Only LF clicks.
12-29-2021, 08:34 PM | #13 |
Rep 90
Going through my service records mine had this same issue described by the prior owner. Dealer replaced both front axle shafts and front struts.
12-29-2021, 09:30 PM | #14 |
Rep 1,024
Gone for good, or did it come back?
Here is the issue I'm having, was yours the same? Front Driver View. https://ulozto.net/file/wNO1oLjq6K9S...3-231336-1-mp4 Side on View, (This one i was nearly full lock both directions.) https://ulozto.net/file/4bT3evyjq62a...3-231739-1-mp4 |
12-29-2021, 09:39 PM | #15 |
Rep 1,340
Front axles?? This is the first account that I've read of that repair for the ticking noise. Do you mind posting your repair order? I'd be curious to see if there's new info/TSB for this issue.
12-29-2021, 10:00 PM | #16 |
170
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
Do people with spacers exhibit the same issues?
2023 GMC Denali Ultimate
2021 Porsche Cayenne GTS 2019 Ford Raptor SuperCrew 2015 Porsche GT3 2004 Ferrari 360 Spider 6M |
12-29-2021, 10:34 PM | #17 |
Rep 1,024
This was the TSB i was talking about the lube, https://static.nhtsa.gov/odi/tsbs/20...48221-9999.pdf
Is there a way to see the precedence of TSBs for BMW? |
12-30-2021, 06:55 AM | #18 | |
224
Rep 377
bmwx5er359.50 |
12-30-2021, 07:01 AM | #19 | ||
Rep 1,340
12-30-2021, 07:13 AM | #20 |
224
Rep 377
The spacer TSB was never mentioned. Not sure if it was done prior to my ownership. I just described my issue and this was their fix. Will be interesting to see if the clicking comes back if the spacer is the true fix.
01-16-2022, 08:48 PM | #21 |
Rep 1,024
So Just looking at this TSB (https://static.nhtsa.gov/odi/tsbs/20...48221-9999.pdf) and lubing up the drive flange.
just going through the instructions for this, and am wondering if I am reading this correctly. The TSB says follow instruction set
Also the TSB says to use this grease (83 23 0 417 754 - Castrol Optitemp HAT LF1). Has anyone been able to find it, outside of BMW? Last edited by Chilled; 01-16-2022 at 09:43 PM.. |
01-16-2022, 09:28 PM | #22 | |
Rep 125
