12-02-2016, 01:31 PM | #1 |
BimmerSF
121
Rep 533
F15 X5 optional 20in wheels
Hi guys quick question...especially for anyone in Bay Area.
Have you guys ever took your 20in performance tires on the X5 to Tahoe where there is not much snow but sometimes chains are required? we are going just once this year and I am not sure i want to spend money on new tires.... Thanks!
FOR SALE: F16 X6 Carbon Lip/diffuser/spoiler - used
CURRENT: '18 F16 + '18 i3s SOLD:///'17 i3 ///'15 F02 B7///'14 i3 ///'15 F85 x5M///'15 F15 x5 50///'03 E39 540i///'08 E70 X5 4.8///'06 E60 550i |
12-02-2016, 02:35 PM | #2 |
Rep 452
As long as you avoid driving on heavy snow with alot of inches then you shouldn't have any problem. The key is to drive at a moderate speed. I've driven my summer tires on temps close to 0 and everything is fine as long as you don't drive on snow or slush.
12-02-2016, 02:41 PM | #3 |
Rep 1,201
That's a seriously dangerous thing to do and you would be endangering yourself and other drivers on the road. At low temperatures summer tires turn into hockey pucks with or without snow and lose most of the traction, and this is worse on inclines going up the mountain. Imagine yourself slide down the hill without traction...
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
nyalpine907425.00 zinengineer206.50 |
12-02-2016, 02:48 PM | #4 | |
Rep 108
Below 50F summer tire compound gets harder and less grippy. By the time temps get around freezing, it will be like driving on 4 bowling balls - when it's sunny and clear. In the snow/ice, the car will not turn or stop much at all - if it can even get out of the driveway. http://www.tirerack.com/tires/tirete...jsp?techid=273 Rent an AWD vehicle with all season/winter tires. |
zinengineer206.50 |
12-02-2016, 08:55 PM | #5 |
Rep 2,353
This is terrifically-bad advice.
zinengineer206.50 |
12-02-2016, 10:20 PM | #6 |
Rep 452
12-03-2016, 08:31 AM | #7 | |
1148
Rep 2,426
The summer tires are fine for accelerating (due to 4wd likely), but after that you're seriously risking your life since it doesn't turn or brake at all on light snow and ice. And in case you didn't know, they do check if you have chains, so please get them.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
12-04-2016, 08:40 PM | #8 |
Rep 5,066
Same here. Summers ride fine and grip fine in freezing temps.
12-04-2016, 11:32 PM | #9 |
1148
Rep 2,426
But if the OP is going up to Lake Tahoe, I assume it's to snowboard/ski therefore there will be snow and ice the ground, so the summer tires will be very dangerous.
BMW CCA 509766 |
12-05-2016, 09:31 AM | #10 |
Rep 108
I have a friend who is a firefighter. He tells me stories. He told me of an accident where an MB AMG E Class wrapped around a telephone pole in the early morning. The road was dry and clear and a gentle curve, temps around freezing. There were no other cars involved and nothing indicating why the driver had lost control - except the AMG was riding on 4 summer tires. The car was split in half - and so was the driver.
Anecdotal data for things like this is going to suffer from survivorship bias. |
zinengineer206.50 |
12-05-2016, 10:20 AM | #11 |
1148
Rep 2,426
Also only once? I don't even live in Bay Area anymore, and I got the Epic Pass knowing I'll be going at least a couple times.
BMW CCA 509766 |
12-05-2016, 12:25 PM | #12 |
Rep 2,039
Drives: 2022 X6///M Comp
^ What he said. I wouldn't do it. I can feel the difference in handling and stopping power as the temps fall. Already have my snow tires on after feeling delayed stopping power with temps in the high 30s and low 40s. I am guilty of trying to prolong the change as long as possible but it's not worth it. Summer tires are not safe in cold temps.
zinengineer206.50 |
12-05-2016, 01:08 PM | #13 |
BimmerSF
121
Rep 533
thanks everyone... i guess will try to pick up a set of all weather tires with some wheels or maybe rent a car, but rental prices are crazy for NY weekend... thank you!
12-05-2016, 02:09 PM | #14 | |
Rep 2,353
If you spend time in the mountains you'll know that a dry sunny day means melting snow, which means ice covered roads in the evening (or if it's really cold, ice covered roads where shade exists... like around a bend/pass). FWIW, if I couldn't swing snow tires, I'd drive something less expense so I could. You have about a square foot of contact patch, do yourself (and everyone else on the road a favor) and make sure it's the right one for the conditions. At minimum, a $1,200 set of DWS06s would be a world better than the OE Summer rubber. If storage/logistics are your issue, find a local tire store, have them match (or beat) TireRack and see if they offer storage for a nominal annual fee (many do). |
zinengineer206.50 |
12-05-2016, 09:31 PM | #15 |
Rep 214
three thoughts
a. Winter DOES NOT equal Summer; they are different seasons b. Just because you "can" does not always mean you "should" c. Remember, there are others on the road besides yourself If you can afford a BMW, you can either afford the correct tires OR a rental with the proper equipment, otherwise....... |
12-05-2016, 10:06 PM | #16 |
Rep 592
Your best to rent an SUV for the weekend and make sure they have winter tires on. A couple of year ago I rented one with specific winter tire request and drove to Oakland airport to get em. I got there and guess what, none of their full size SUVs have em on. Long story short, I drove to SFO and got a 50% off of their daily rate. Good luck.
