06-08-2017, 04:04 PM | #1 |
Rep 41
Anyone know something about lemon law?
Long story...My 15 x5 keep having issue with the GPS after they delivered the car after few months. I took it back to the shop they told me was the software issue, after a 2 days of inspection by the dealer, seems like the problem fixed. After maybe half year, the issue went back again, it's just keep losing my location on the map, its shown I was in the middle of the ocean when I was driving from Seattle to LA on the map, it drives me crazy . I took it to a different dealer where close by my place, they said was a antenna problem couldn't catch the signal from the satellite, so they replaced the antenna afterward, seems worked fine after a while. However, the fxxking disease came back again recently, I took it back to the dealer where I ordered it today, they were saying the antenna is working fine, but there is something wrong with the Idrive cannot work with the antenna, so they just decide to replaced the Idrive whole unit.... I talked with my sales, he said I can try the lemon law, but I have to give BMW NA a call to file a claim, once the case opened they can work with BMW find a solution. I just wondering is anyone in the form have any experience with the lemon law and any idea that I can proceed that? The photos I attached are the gps showing I was off the high way when I was driving on the high way...
06-08-2017, 04:23 PM | #2 |
Rep 11,891
this is the first I've ever heard of this type of issue. From the aftermarket retrofit experience, they shouldn't just replace a single part, especially if you keep having issues. They need to replace the entire idrive, unit, all the receivers, everything.
brucedu18.50 |
06-08-2017, 04:31 PM | #3 | |
Rep 41
06-08-2017, 04:52 PM | #4 |
Rep 1,181
You said the latest fix they tried was to replace the entire head unit. Are you still having the same issue now?
Lemon Law info abundantly available by searching, but in general, the same exact problem needs to be attempted to be fixed XX times (varies by state probably) along with your car being out of commission for YY days. You can def start the process with corporate to get things officially documented, pulling the info from both dealers together in one place/file.
Flying Ace4984.50 |
06-08-2017, 04:56 PM | #5 | |
Rep 41
06-08-2017, 04:57 PM | #6 | |
Rep 11,891
From what I heard, usually just a threat of "lemoning" a car with corporate usually prompts some type of major corrective action from them. So I would suggest if you're not married to the car and are open to driving a loaner until your permanent replacement shows up, then I would mention lemoning the car to BMWNA, and it'll probably get the process started on replacement.
brucedu18.50 |
06-11-2017, 11:21 PM | #9 |
Rep 663
I lemoned my Range Rover Sport.
The law varies by state so google it. In NY/NJ, the defect must impair the use, value or safety of the vehicle. I'm not sure if a gps issue qualifies. Make sure your repair attempts are well documented. Have the dealer connect you with a regional person and esclate it until its resolved. |
06-12-2017, 01:17 PM | #10 | |
Rep 865
If you are seriously considering going this route, you need to read as much as you can, including the actual law. If you still think you have a case, then contact an attorney who specializes in this area of law as they will be best equipped to argue terms like "reasonable" and "substantially". You might want to start your reading with the Washington State Attorney's Web page Hopefully all will be well after this next visit. Good luck.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016 2017 X5 xDrive35i - PCD Jan2017 |
brucedu18.50 |
