05-21-2016, 01:35 PM | #111 |
Rep 480
Great DIY! My first post here, I'm reading for some years now, but after the purchase of my recent car (BMW X5 F15 M50d) I thought it would be nice to contribute as well.
Since I've noticed the fan in the center console was sometimes active (I don't/didn't use the cradle at all), I found it pitty to loose that functioniality. I've drilled some holes and attached (superglue and silicone kit) the fan to the back of the ordered plate. See picture for details. |
05-21-2016, 01:39 PM | #112 |
Rep 18,627
Looks good. But isn't the fan is located on the top right from your picture, instead of where your holes are on the lower left.
05-21-2016, 02:04 PM | #113 |
Rep 480
That's right, but space is to tight in that area. Also the back of the blind plate had a very nice spot for attaching the fan without much effort, that's why I've placed it there. I've filled the area around the fan (between the plate and fan) with silicone kit so all air will blow out through the holes I've drilled.
05-21-2016, 02:08 PM | #114 | |
Rep 18,627
How long have you waited to find out that the fan is working?
05-21-2016, 02:13 PM | #115 |
Rep 480
By accident, I had a box of chewing gum in the center console on a hot day. Was driving for some time when I took one out and noticed that it was cold. The box had been in front of the fan and that kept it cold. Also when I wanted to do this DIY, the engine was running, and the fan was spinning, so I had to stop the engine before I could proceed. I have no clue when it starts spinning. I had to check a couple of times after this DIY to actually feel the air flow through the holes. At this point I'd say it's random!
05-21-2016, 02:15 PM | #116 | |
Rep 18,627
05-21-2016, 05:12 PM | #117 |
Rep 44
Great thread for a problem that should not be needed. I will order one for my Wife's 2015 X5, and one form my 2015 330i, and am wondering if there is a way of using the antennae extender from the piece removed, and moving it up to the area of the non smokers package plate. This is where I throw my phone, and I live and commute in an area of questionable reception.
A short antennae cable fed under the console would be cheap, and the process should not be too difficult. Suggestions anyone? Cheers, Ken |
05-21-2016, 05:52 PM | #118 | |
Rep 18,627
05-21-2016, 07:09 PM | #119 |
<3 Flat Four
215
Rep 754
Extending the coax is the easy part, it's just cut n splice together to extend. The hard part is how do u connect the coax to ur phone. I believe the coax is intergrated into the phone cradle n uses the data port connection to connect as an external antenna. Basically once u remove the cradle it renders the coax cable useless by itself.
05-22-2016, 06:20 AM | #120 | |
Rep 44
Cheers, Ken |
06-17-2016, 07:28 PM | #121 |
Rep 167
Just to confirm
Just bought 2014 X5 for my wife and that cradle is just plain joke. I also have smoker package so want to get rid of that tray too.
Just to confirm the parts I need are: cradle delete - 51169252106 non-smoker tray - 51 16 9 267 952 thanks |
HZX540e373.50 |
06-18-2016, 12:16 AM | #122 | |
Rep 18,627
07-25-2016, 12:19 PM | #123 |
Rep 1,547
Just ordered the cradle delete tray from my dealer (finally). I can't wait to get rid of that damn cradle and free up some space!
07-25-2016, 01:31 PM | #124 |
Rep 18,627
After all this time? Haha.
07-25-2016, 05:07 PM | #125 |
Rep 1,547
I know, I know...honestly, should've done this two years ago!
08-31-2016, 11:22 AM | #126 |
2020 Mineral White 30d MSport
521
Rep 2,146
Drives: 2020 Mineral White 30d MSport
Hi, if you remove the smokers package, do you lose the 12v connector? I use to take 12v from that connector for my hardwired GoPro...........so if I loose it is not worth it for me
....Life is too short to drive boring cars
08-31-2016, 11:25 AM | #127 |
<3 Flat Four
215
Rep 754
no u do not, u keep the cigarette lighter in place. the non smokers package is really just the ash tray that u r removing, replaced with a new rubber tray that does not have the hole in it for putting out cigarettes. i THOUGHT i would loose the cigarette lighter as well before i replaced mine but it did not.
2011 335is Le Mans Blue
08-31-2016, 11:30 AM | #128 | |
521
Rep 2,146
08-31-2016, 11:42 AM | #129 | |
Rep 18,627
01-02-2017, 12:58 PM | #130 |
Rep 674
Just did this today, took about 20 min. What a big difference in space.. highly recommend doing this delete. I can actually fit a tissue box in the armrest it close it!!
01-12-2017, 08:59 PM | #131 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
453
Rep 1,995
Drives: 2011 E92 M3 DCT/ESS 625 kit
Doing this on Saturday. Wish our suv's had more storage space and USB connections Instead it's full of cigarette lighters. Come BMW get with the times its 2017 and add more USB ports. I've seen the same lighters in my 1989 E30. Looking forward to this mod. Thanks for all the detailed pics.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
01-13-2017, 03:05 PM | #132 | |
453
Rep 1,995
