11-20-2013, 06:52 PM | #23 | |
Rep 6
Drives: X5 35i 2014, X3 35i 2013
11-24-2013, 09:24 PM | #24 |
Rep 112
I was at the dealership yesterday, and noticed this very flimsy door seal. I'm assuming that what's causing it to fold outwards is people exiting from the vehicle and brushing up against it. I'm not sure why this seal is even there at all, since I didn't see it on some of the sedans I looked at. Perhaps it's specific to the soft-close door feature.
11-25-2013, 03:28 AM | #26 |
Rep 2,699
11-25-2013, 04:56 AM | #27 |
Rep 1,417
On delivery date at home, my driver side looked exactly like Genechen22( post 25). Yup, my facial changed. I flipped it back in, so far so good. I am sure if continued there will be a fix. Reminds me last year for my F25 delivery date the bottom mould trim jutted out, I simply snapped it in, silly little things.
11-25-2013, 08:35 AM | #28 | |
Rep 428
11-25-2013, 09:11 AM | #29 |
Rep 112
When I asked the dealer about this, I was told that when summer comes around the heat of the sun will "mold" the door seals so they fit properly.
11-25-2013, 10:15 AM | #30 |
67
Rep 308
11-25-2013, 10:40 AM | #32 |
Rep 112
11-25-2013, 11:13 AM | #33 |
Rep 4,217
11-25-2013, 11:34 AM | #34 |
67
Rep 308
From the pics above, it looks like this "outer" molding is not the door's primary weather striping (which is attached to the frame along the door's outline and seals when the doors are closed), but rather some sort of cosmetic or noise reduction molding.
If this molding sits in a channel or is attached via a hole/post mechanism, BMW should be able to fix this. Can anyone confirm how the molding it attached? |
11-25-2013, 11:44 AM | #36 | |
Rep 112
11-25-2013, 11:52 AM | #37 | |
67
Rep 308
11-25-2013, 12:43 PM | #38 |
Rep 112
It would be interesting to see if these seals are actually being pushed out by someone exiting the vehicle, or if they are coming out by some other means (improper adhesive, pressure from the soft-close door mechanism).
11-25-2013, 10:31 PM | #39 |
Rep 693
Just came back from the LA Auto Show. They had a Sparkling Brown Metallic Luxury Line xDrive 50i there. Checked out the outer seal and it was coming apart (should've taken a photo, but I forgot). Approximately 2-3 mm of the seal edge that was attached via adhesive was coming loose. I'm not sure if the whole seal is attached via adhesive or there are intermittent parts that are attached with some other method (ie. plastic clips), but the area in question was definitely coming loose.
Z. |
11-25-2013, 11:48 PM | #41 |
Rep 112
According to my dealer, the official word from BMW is that some X5s did have this problem, but none of the vehicles which have been shipped recently do. Not sure what changes were allegedly made, but this does not seem to be consistent with reports of recently-purchased vehicles having defective seals. It would be nice to have some way of figuring out which X5s on the lot have this problem. I repeatedly opened and closed all four doors on the X5 I almost bought today, and none of the seals popped out. They do look very thin, though.
11-26-2013, 12:14 PM | #42 |
Passes everything but the gas station
49
Rep 795
I haven't had any door seal issues on my 2011 X5 M. What I do have an issue with is this little piece of rubber that runs along the bottom of the door and the richer panel when open.
They are loosely out on and every time I clean the car, blow dry with leaf blower they come flying off. Even if my foot gently rubs against it they come off. Already on my 2nd set from dealer and owned car since August. |
11-26-2013, 01:02 PM | #43 | |
Rep 112
Get a 3rd set. Or try to glue it yourself. If the car's still under warranty have the dealer fix it. |
11-26-2013, 01:20 PM | #44 |
Rep 132
Came out on me today. I have been trying to keep an eye on it, but I missed it this time. Co-worker pointed it out from inside the office. I don't think it is really that big of a deal, but it looks like crap with it sticking out with the door shut. I also get the "That is why I don't buy BMW" from the co-worker.
Tags |
defect, door, gaskets, seals |
