09-10-2017, 03:43 PM | #3675 |
Rep 8,364
Not sure what you mean. Instructions were linked in post above for from where to download and place. If display correctly in IE, then downloaded from wrong area; compare to existing.
09-10-2017, 10:55 PM | #3676 |
Rep 176
Thank you! That worked, some of the cheat codes made the error comes out. All good now. As always, you guys rock!!!! Thank you!
09-11-2017, 09:25 AM | #3677 |
Rep 8,364
09-14-2017, 03:36 AM | #3678 |
Rep 11
Is the Coding cheat sheet that is linked on the OP kept up to date with ALL the available codings?
I seem to remember seeing the code somewhere to remember the settings for Drive Mode when restarting...but I cannot see it in the Cheat sheet? |
09-14-2017, 09:38 AM | #3679 |
16
Rep 348
Drives: M6 Comp Gran Coupe & X5 MSport
Quick question what's the easiest to use for coding the app or using the cable & Esys ?
I've used Esys before and was always worried of messing something up when I saved the change ! |
09-14-2017, 09:57 AM | #3680 | |
Rep 8,364
Both are easy, especially if you use Launcher Cheat Codes in E-sys. For the app, you need Bimmercode and Bimmerlink so you can code and clear errors. |
09-14-2017, 03:50 PM | #3681 | |
Rep 11
Unfortunately my skills at this are still pretty basic, and can follow the settings as shown in the cheat sheet format, but not confident enough to try coding my vehicle based on the comments in those posts. I thought I had seen it shown with more specific settings details somewhere, perhaps I need to continue to search. Cheers |
09-14-2017, 04:45 PM | #3682 | |
Rep 8,364
Use ICM if you want last mode memory (choice of 4). It is FDL coding with werte changes. |
09-14-2017, 08:49 PM | #3683 |
Rep 826
Drives: 2017 C43 AMG
So I?ve been coding my vehicle section by section. So far I?ve run into one key that I can?t manage to find. I?m trying to enable sports+. So I?ve managed to get the selection menu to show sport + on my cluster. However I can not select it. I believe I can?t select it cause I haven?t been able to find the key for
ICM or ICMQL/3000/LCMKOD_B_SPORTLENKUNG I can not find that key for the life of me, I?ve even checked the other ECU?s. So again I have the option for Sport Plus on my display, I just can?t select it. If anyone has any suggestions please let me know. PSDZDATA 62.4.001 Current I-Step f025-17-07-504 (it was at dealer just last week and I know they did run some updates) This is a 2014 Base X5 xDrive50i
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
09-14-2017, 09:15 PM | #3684 | |
Rep 8,364
09-17-2017, 05:28 PM | #3685 |
Rep 7,161
hey guys, gonna try this out after giving the app a go. Want to be able to code the interior lighting which i am unable to do via the app unfortunately.
can i please get a the latest links/data to start tackling this?! Thanks!
09-17-2017, 05:45 PM | #3686 |
Rep 40,961
PM sent.
09-17-2017, 07:40 PM | #3687 |
Rep 7,161
hey all so i downloaded everything but when i open the launcher everything is like super tiny and scrunched up so i cant see all of the drop down items etc. Is this normal?
09-17-2017, 07:50 PM | #3688 |
Rep 40,961
I replied to your same PM.
09-19-2017, 10:11 AM | #3689 |
Rep 141
Shawn - can you also PM me the latest links and what I need to do the coding?
I tried to reach the page for esys on the first post of this tread and it failed. I am also trying to change the ambient lighting to red and can't seem to do that with the app anymore. F15 50i, 2014, with the latest idrive SW. |
09-19-2017, 11:25 AM | #3690 | |
Rep 40,961
09-19-2017, 11:58 PM | #3691 |
Rep 826
So I am attempting to VO code. I read the FA and hit edit. It opened the editor. I went down to SALAPA-Element and I do not see 205 there. I?m trying to code it to 2TB. Is there another value I may need to change to 2TB instead of 205? I can see sport+ come up on the instrument cluster however I can?t access it. I don?t have launch control yet and I also don?t get s1, s2 etc when putting the shifter in sport. Also in ICM coding I do not have
ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut ICM/IcmKod_B_S2TBA -> verbaut I?ve successfully changed EGS/Sportschalter, Sportschalter_alt and LC to active.
09-20-2017, 12:02 AM | #3692 | |
Rep 8,364
09-20-2017, 03:20 PM | #3693 |
Rep 141
Did you manage this, I tried esys and same thing, regardless of the werte values being updated, it wont take the change.
09-20-2017, 09:01 PM | #3694 |
Rep 7,161
Not yet. Been busy. Will give it a go this weekend.
09-21-2017, 12:54 PM | #3695 |
Rep 41
Drives: BMW X5 45e -20, 225xe -16
Hi,
Trying to code my 40e. Everything works, connection, read FA, but when I try to read SVT I get this, sorry for the picture size in attachment.. Any idea what to do? |
09-21-2017, 12:55 PM | #3696 |
Rep 41
I also checked the voltage, connection type etc, series all ok
