08-06-2014, 09:17 PM | #111 | |
Rep 3,990
@r33, I currently have ESYS 3.24.3 and PSDZDATA file 52.1. I just want to make sure in case the dealer updates anything in the future. Last I checked, this was the latest software, but I could be wrong. Thanks .
08-06-2014, 09:35 PM | #112 | |
Rep 18,712
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
08-07-2014, 01:53 PM | #113 |
83
Rep 346
I had ESYS 3.25.3 + PSDZDATA 2.53.0 installed back in July...
08-07-2014, 02:12 PM | #114 |
Rep 3,990
Thanks for the update, Armen. Ben sent me the updated psdzdata .
08-08-2014, 02:54 PM | #115 |
Rep 179
What are these features that are being tested?
Sailing / Coasting Function - EcoPro Mode LED headlamp Tweaks - Work in Progress! any description in brief? |
08-08-2014, 04:24 PM | #116 | |
Rep 3,990
LED Headlamp tweaks are the parameters for the LED Lighting package where he changed the ramp time (time it takes to change from one to another) from low beam to high beam, etc. He also modified the brightness for the cornering lights. Basically, to get these features to work, you have to have the LED package.
08-08-2014, 08:00 PM | #117 | |
Rep 179
Sailing/Coasting feature -- Does this automatically change to ECO mode after reaching 40+ km/h. what was speed that we get with the vehicle? LED Headlamp -- When you mentioned cornering lights, are those the ones above corolina rings? |
08-08-2014, 09:32 PM | #118 | |
Rep 3,990
The cornering lamps I am not 100% sure where they are located because I don't have the LED package. Hopefully, someone else can answer this for you.
08-10-2014, 03:30 AM | #119 | |
Rep 424
The LED package has built in additional cornering LED's in the headlamp units. I'm not sure about the Xenons, do they still use the fog lights for this purpose?
X5 F15 - gone after 5 months!
08-10-2014, 03:41 AM | #120 |
Rep 424
Coasting / Sailing Video
This video shows the sailing function in action. I was driving at ~30mph in Eco-Pro mode, as I back off the throttle you'll see that the engine rpm drops to idle as the gearbox shifts automatically to neutral. The car continues to sail along at ~30 mph. Increasing the throttle causes the gearbox to re-select the appropriate gear again. Works really well, particularly on slight downhill gradients (obviously )
https://www.dropbox.com/s/pxu58fav5m...2008.34.11.mp4
08-10-2014, 05:23 AM | #121 | |
Rep 3,990
08-10-2014, 05:56 AM | #122 | |
Rep 424
Here's a video showing the Efficient Dynamics status screen with the coasting mods done (sorry for the poor video quality, it was made whilst driving!): https://www.dropbox.com/s/fw0svq3a3j...2020.30.52.mp4 Once this mode is enabled and you select Eco-Pro driving mode the car will 'coast' when you're above 30mph and back off the throttle. It's clever enough (in the UK anyhow) to use sat-nav / speed limit data to know when coasting should be disabled to allow the engine to slow the car down i.e. it puts the car back in gear to facilitate engine braking! I've seen several Eco-Pro 'driving tips' on the display telling me to back off the throttle since there's a lower speed limit ahead, in this case the sailing mode seems to be inhibited. Coasting mode is disabled when cruise control is enabled. This has certainly been one of my more interesting coding sessions! You're more than welcome @opasha
08-10-2014, 06:08 AM | #123 | |
Rep 3,990
08-10-2014, 06:22 AM | #124 | |
Rep 424
My mods to the led lighting transition timings were interesting, I'm noticing far more changes to the dipped beam patterns than before. The changes in beam pattern are not new it's just that they're more noticeable than when the ramp times were longer. There's a definite change takes place at around 15mph, the beams width and throw/distance changes noticeably. I think I need to make further changes to the timing parameters, I plan to increase them since my current settings are a little too abrupt! |
08-10-2014, 06:57 AM | #125 | |
Rep 3,990
Enjoy your vacation, @CatFlap!
08-10-2014, 10:11 AM | #126 | |
Rep 424
Thanks!
08-10-2014, 10:22 AM | #127 | |
Rep 3,990
You're very welcome, buddy!
07-22-2015, 04:43 AM | #128 |
Rep 81
I cannot test this
HU_NBT 3000 -> REGEN_SCHLIESSEN default: nicht_aktiv change: aktiv Sunroof Closing on Rain Detection ====== It's possible for us to have Taigate opening with foot below the rear bumper? http://www.bmw.com/com/en/newvehicle..._tailgate.html |
08-25-2015, 04:00 PM | #129 |
Member
898
Rep 2,031
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Is it possible to code the F15 to start off in Sport Mode or Eco Pro Mode?
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
08-25-2015, 04:30 PM | #130 | |
Rep 52
Tags |
2014, coding f15, f15, f15 coding |
