10-15-2017, 04:09 PM | #442 |
Rep 23
Is it possible to code colors in ambient lighting in bimmercode. When I open mine, instead of color codes I see some strange values. Or I have to add new value with code of color?
10-16-2017, 04:59 AM | #444 |
Rep 23
10-16-2017, 09:56 AM | #446 |
Rep 1,011
yes, the developer. did you email him? he will provide a solution and/or status on the solution.
2017 x5 w/MPPK & MPE build thread
http://f15.bimmerpost.com/forums/sho....php?t=1427846 |
10-16-2017, 05:39 PM | #448 |
Rep 11,846
Drives: MY24 G01 AW Msport
I was successful in coding this evening.
There was one module in for some logo that had x5 and x6 ...the last option i couldnt figure it out bunch of letters.. what is that? |
10-16-2017, 08:44 PM | #449 |
Rep 3,625
Can you guys confirm that this is the VGate I need?
https://www.amazon.com/Vgate-ELN327-...+ii+wifi&psc=1 |
10-16-2017, 08:52 PM | #450 | |
Rep 102
Yes that is the one i got last week and it works. ( it comes with instruction to download the torque (google play) and some app for apple just ignore that). |
JStang562.00 |
10-16-2017, 08:53 PM | #451 | |
Rep 1,011
JStang562.00 |
10-16-2017, 08:58 PM | #452 |
Rep 102
Was able to successfully code my x5 with the app using android device. Developer has code clearing built into it and don't need additional app. Not bad at all for under $60.
Coded the following: 1. Tail gate closing with button on the driver door. 2. Tail gate closing with remote key fob. 3. Remove the disclaimer. 4. added the M in the headunit for start up display. 5. Added turn signals to HUD. 6. Fogs with high beam. 7. Tried but didn't work turn signal x 5. ( will troubleshoot this further when i get a chance this weekend). 8. Mirrors unfolding with comfort access. i couldn't find the setting where i can switch on fogs with headlights ( headlight are set to auto, but fogs don't turn on with it). My door handle lights already turn on with reverse. Probably will look into coding additional items as time goes on. |
OFFWHITEX5325.50 |
10-17-2017, 07:03 AM | #453 |
Rep 11,846
what is mpm_logo_mpm?
its under the cluster module... the codes clear itself after reboot, only time i had to do it manually. on welcoming light section... what should it be..several items "hard on" what is this feature? Last edited by nyalpine90; 10-17-2017 at 10:37 AM.. |
10-17-2017, 01:42 PM | #455 | |
Rep 23
OFFWHITEX5325.50 |
10-20-2017, 05:12 PM | #459 |
Rep 193
Well bought the adaptor and app in hopes of being able to code my angel eyes back to 100% for DRL function, but the app doesn't seem to support the location of that ECU. The TMS I believe is where I need to be. Any help would be appreciated. I had anti dazzle coded by code my car and for some reason it dimmed my DRL down. It's driving me crazy.
10-22-2017, 07:58 PM | #460 | |
Rep 3,625
EDIT: After reading through all 21 pages this seems to be common. Last edited by JStang; 10-22-2017 at 09:04 PM.. |
10-23-2017, 10:18 AM | #461 | |
Rep 1,181
That is, for older I-Step levels, the function to modify was BLINKZYKLEN_ANZAHL_TIPP in Module 3068 and it actually gave you the ability to program four blinks if you wished. Newer I-Step levels, the function to modify is PIA_DEFAULT_TIPPBLINKEN in Module 3069 and it appears you have the choice of one, three, or five blinks only. Also, if you check the box of "Triple Blink" in iDrive... it'll erase your freshly coded setting of five blinks. That's what happened to me yesterday.
10-23-2017, 10:22 AM | #462 |
Rep 155
I keep seeing "hatch open/close from the door button". My X5 does this stock. You push the tailgate button to open it and pull it up and hold to close it.
