      05-29-2014, 08:08 AM   #45
Diper
Diper's Avatar
Netherlands
47
Drives: BMW X5 F15 3.0d
oskee, the pictures above indicate the strikers. Take of the plastic and you can see the springs. Mine will be adjusted tomorrow by the dealer
      05-29-2014, 02:57 PM   #46
Waylo
Drives: 2014 F15 X5 Diesel M Sport
I moved up the plastic parts in the picture and the noise seems to have gone away (for now).
      05-30-2014, 03:27 AM   #47
Baboum68
France
8
Drives: X5 G05
What is the spring for? How do you adjust?
      05-30-2014, 03:35 AM   #48
Diper
Diper's Avatar
Netherlands
47
The X5 is at the dealer at this moment, I do not know how to adjust the springs my self. But the dealer had instructions printed. I'll ask them if I can get a copy, but as stated before, it's probably trial and error. And as the majority of X5's are having this minor issue, I guess they will leave the factory adjusted soon.
The issues I had so far:
- ad blue reservoir warning (solved by software update)
- steeringwheel column spring makes noise (solved today by dealer)
- rear noise (fixed by plating the plastics upwards, but adjusted by dealer today)
- the door seal problem is not a major thing for me, as it's easy avoidable
Let's hope I will not get the chassy warning.
      05-30-2014, 03:51 AM   #49
Baboum68
France
8
Drives: X5 G05
Would be great to know what they are doing with the spring. Looking forward to hearing back !
      05-30-2014, 06:35 AM   #50
Eu001939
Drives: X5 30d MSport and X3 20d
Mine rattles too and it has become worse over the last few days.
Those strikers need to be in the down position ( up is just half way to taking them off . Guess this is only for assembly)
If you take off the cap of the strikers, you can see the bolt and springs. Loosen the bolt, and you can adjust the striker. Then tighten again. I think the springs are only there to help you adjust, because once you tighten the bolt again, the striker will not move.
I tried adjusting the rubber stops, but it doesn't help either. And if the striker is adjusted too tight, the trunk will not close...(electric closing mechanism opens the lid again)
Will bring the car too the dealer next week for repairs...
      05-30-2014, 08:57 AM   #51
Diper
Diper's Avatar
Netherlands
47
As stated above is the correct procedure. Just came back from the dealer and they printed the procedure, however in Dutch and on paper so not of much use to you. But the procedure is the same as on the E70.
The whole 'thing' actually sits on a screw which need to be released slightly to get it more outwards and thus stopping the tailgate from moving. Acces to the other side of the screw by taking away both side panels.
      05-30-2014, 12:13 PM   #52
Eu001939
I am belgian and speak dutch so if you can private mail the procedure i would appreciate it !
      05-30-2014, 01:55 PM   #53
Baboum68
France
8
Drives: X5 G05
would you mind still posting? so did you adjust the bumper? or the square block with the spring inside?
      05-31-2014, 12:46 PM   #54
Diper
Diper's Avatar
Netherlands
47
let's see if this works. I tried making a pdf on my iphone
      06-05-2014, 06:52 AM   #55
oskee64
oskee64's Avatar
Drives: '14 X5M Sp/'06 M3/DD:Inf QX4
These E70 strikers looks totally different mechanism than that of the F15.
      06-05-2014, 07:34 AM   #56
cc3
Drives: 1M, GT4, M2 M140i G40
Had mine done 2 weeks ago at dealer but rattle now returned. Amazing BMW got this wrong with F15 as previous model had exactly same problem.
      06-06-2014, 01:20 PM   #57
ramsal
Drives: 2017 X5 & 2018 M3
I made an appointment have the creaking in the trunk fixed next week. Well, on Tuesday I decided to have a look at the strikers and anything else that may be contributing to this problem. I opened the hatch, cleaned them with a damp cloth and to my surprise the creaking is gone. It is now Friday and as of this morning's commute the vehicle was quiet, like it was meant to be. I fully expect that the creaking will come back when enough dust accumulates on the elements I cleaned, but I thought I would share this for those looking for at least some temporary relief.
This did also make me wonder if putting a bit of silicone grease on them would help longer term. I'll have to try that if/when the noise comes back.
Unfortunately for me, unless the noise comes back before my appointment I have nothing to show the service adviser.
      06-06-2014, 01:29 PM   #58
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Unfortunately I have to join this club, use mostly highway to work with music on, drove to the city testerday (no music) and of course now I can hear it in my sleep
      06-08-2014, 03:22 AM   #59
Baboum68
France
8
Drives: X5 G05
I adjusted the latch on the tailgate (downwards) to make remove as much tension as possible when closing. Make sure it is centered as much as possible otherwise the noise will come either left or right side.
"For now" the noise is gone. The issue is the panel adjustment between the tailgate and the rest of the car body, but is much prefer a car without noise.
Hope it helps
      06-09-2014, 08:45 AM   #60
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
Took ours in for similar noise, rattle in what sounded like passenger side of cargo area. I was told they took apart a lot of the plastic panels and just made sure everything was tight and added some felt tape to get rid of the rattle. Have only had it back since Wednesday, but so far, so good. He didn't say anything about adjusting any locking mechanism, striker, etc.. but I suppose that could have fallen under "made sure everything was tight.."
      06-18-2014, 11:48 AM   #61
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Hear dangling noise from trunk when i slam my door, tailgate
Lifted then no noise
      06-18-2014, 03:19 PM   #62
ramsal
The dealer tried to adjust my tailgate based on some measurements but even the adjustment didn't fix it. They ordered some new parts from Germany. Next update in a couple of weeks when the new part(s) get installed.
      06-19-2014, 01:08 AM   #63
Baboum68
France
8
Drives: X5 G05
Since my last fix, noise hasn't come back. Fingers crossed
      10-13-2014, 03:34 AM   #64
Baboum68
France
8
Drives: X5 G05
noise is back again-...:-(
      11-06-2014, 05:57 AM   #65
barcelona
barcelona's Avatar
Drives: X
Unsure whether the rattle is sourced from guide supports and at low speeds, if so Service Bulletin. Hopefully, rattle free by now.
http://www.allworldauto.com/tsbs/NHT...in_421770.html
NHTSA Item Number: 10056094
Service Bulletin #: SIB-33-03-14
Replacement #:
Vehicle/Equipment Make: BMW
Vehicle/Eqipment Model: X5
Model Year: 2014
Mfg Component Code: 022400 SUSPENSION:REAR:SHOCK ABSORBER
Date of Bulletin: 2014-06-01
Date Added: 2014-09-02
Summary: BMW: DUE TO GUIDE SUPPORTS BEING INCORRECT, THE REAR SHOCK ABSORBERS WERE ASSEMBLED, WHICH WITHIN A LOW MILEAGE CAUSES A RATTLING NOISE. MODEL F15 (X5). *PE
