10-29-2021, 01:24 PM | #23 |
Rep 264
Forgive me from raising from the dead but for those that actually were able to enable the 5 blinks from expert mode in bimmercode but were not able to actually get it to work, did you go back into iDrive and see the 5 blink option to enable? I recall bimmercode telling me the same that it is no longer available/supported. In the F48 forums this is what they had to do to get the 5 blinks. I don't have my BT adapter to try myself but wanted to see if this what others did to get it to work.
2015 F15 XDrive 50i MSport
10-29-2021, 08:04 PM | #24 | |
Rep 804
MizikeTSK143.50 |
10-30-2021, 09:26 AM | #25 |
Rep 475
It was active for a while, then removed from the BMW software. One of the things I really wish they would bring back, 3 is too short.
11-27-2021, 09:57 PM | #26 |
150
Rep 349
I changed the Daten file on my E70 to give us 7 blinks. The Daten file had to be changed to allow WERT_02 to have a value of 7 instead of factory value of 3.
Now, we are spoiled. Measly 3-blinks sucks. I do not yet know how to do this on the F15 - the best we have is 5 blinks, now. Last edited by Tomcat_F15_STL; 11-28-2021 at 01:34 AM.. |
11-28-2021, 11:47 AM | #27 | |
Rep 108
11-28-2021, 01:49 PM | #28 |
150
Rep 349
05-05-2022, 10:48 PM | #29 |
Rep 144
Hi,
I'm confused, I downloaded the latest pszdata as my wife's X1 F48 had to have a software update due to replacement of some parts. I edited the relevant CAFD files and when I FDL Coded BDC_BODY, I had 5 soft blinkers and i-Drive unchecked 3 Blinkers in the menu. I pressed 3 Blinkers in i-Drive menu, the soft blinkers reverted back to 3. I then changed PIA_DEFAULT_TIPPBLINKEN back to the default Tippblinken_dreimal = 01 and FDL coded and i-Drive checked 3 blinks. I then changed PIA_DEFAULT_TIPPBLINKEN back to Tippblinken_fuenfmal = 02, i-Drive menu showed unchecked 3 blinks but when I tried, I got 5 blinks. I just have to remembers not to check 3 blinks in the i-Drive menu. Cheerz
2016 BMW F26 X4 35d, H&R spring lowered 30mm, QUAD exhausts
daytonaviolet1250.00 |
05-05-2022, 11:00 PM | #30 | |
OEM CSL Whore
1250
Rep 1,476
05-05-2022, 11:22 PM | #31 |
Rep 144
Hi,
Try the same as me, code a different value, then change to get 5 blinks and test again, worked for me. Cheerz
10-26-2022, 07:43 PM | #33 |
Rep 3
OK, I'll resurrect the dead. My 2015 F15 was easy to change to 5 blinks. I now have a 2018 F15 and I'm trying to get 5 blinks. Does anyone know how to do it in Protool? Any help will be appreciated. I hate 3 blinks.
10-26-2022, 08:05 PM | #34 |
Rep 144
Hi,
I could get 5 blinks with my wife's 2016 F48 X1 25i but my 2016 F26 X4 35d only stays at a maximum of 3. Cheerz
01-10-2024, 06:06 AM | #35 | |
Rep 17
I know this is an old thread, for me, who knows very little about coding and am just starting to kinda understand it, can you maybe tell me step by step how to do this on E-Sys. The screenshot is great, but how do I get to that screen and change the value? Thanks, much appreciated |
01-11-2024, 12:36 AM | #37 |
578
Rep 2,047
Can be done by bimmercode, for esys you will need a launcher.
lu_picciotto2.50 |
01-11-2024, 06:50 AM | #38 |
Rep 17
01-11-2024, 02:37 PM | #41 |
Rep 17
Ok, it didn't work... actually there wasn't even the option.
I don't have 3069 in the FEM or even "BDC_ Body". When I go into Expert Mode under the FEM there are various numbers (won't list them all) but it goes from 3067 LceTmsCoding2 to 3070 LciMaster. I can search for Pia_Default_Tippblinken and it does come up, but when I click on it, it gives me the following options: Einfachblinken 0x00 Mehrfachblinken 0x01 Custom Value.. If I try to insert anything in Custom Value it tells me that only 0x01 is available. I guess I need to try and code it with E-Sys, but I would need someone to kindly explain it a little clearer. Thanks anyway mate, it was worth a go |
