07-07-2021, 12:59 AM | #23 |
Rep 5,002
Air bags up next :-) They are showing signs.
07-12-2021, 12:43 AM | #24 |
Rep 5,002
Rear End Bananza
Alright, back into this machine. Rear-end makeover.
Installed: - Powerflex Rear Subframe bushings - Arnott air bags - Curt 2" hitch - 25mm wheel spacers - Compressor maintenance Pushed for a minute: - Rear shocks (Bilstein B4s) - OE BMW Hitch wiring (installed outside, but left the inside for some time when I can concentrate for more than 30 minutes) - OE towing Module Curt Hitch Install - Use the stealth hitch installation directions. https://cdn.shopify.com/s/files/1/21...f?v=1619703873 - Use the BMW hitch install instructions for the wiring. Bumper removal tips. These are supposed to be push-pins from what I understand, but they wouldn't budge for me. So, this took 1 minute each. Drill out the rivet. Easy money. If they spin do this: Pretty soon you'll be here Rear Elec mount install. I removed the stock self-tappers and used some machine screws with a torq head. It's more secure than I thought it would be! Fitment around the bumper on the Curt hitch was pretty impressive for $260 to my door. Rear Subframe Bushings - These really cleaned up the "saggy butt" feeling that modern BMWs have developed. The hollow bushing are installed bc run-flats are rough and the shame of it is they don't allow the shocks and springs to do their job all that well. This leads to hysteresis and secondary motions that can't be damped. I also think they're there to give a greater gap in performance between the M cars, but that's my cynical side. No NVH change that I can tell with these. I'm typically more sensitive than most for NVH. After I installed them I went for a ride and I heard more noise... turned out I forgot to re-install the L & R rear interior panels :-). Putting them back in brought the noise back dow to what I was used to. - Make sure you unplug the ride height sensors and chassis control modules before you lower the subframe. - Keep an eye on the rubber brake hoses - don't want to stretch them! You'll need to remove the underbody panels. This is how I dealt with these. Didn't break a single one. Shocker. Give a twist and then pull it straight down in one quick motion. Drop that whole thing from the rear pumpkin and you'll have this. Then just button them up and you'll be good to go. Compressor and Bags - Ditch these, they're garbage. Refitting the stock rubber hat is probably the hardest part. Love the push-pin style airline connectors on the Arnotts! Put in the new hotness. 250r head with a fresh play port in the background. Weird flex, I know :-) Pull your compressor. My desiccant beads were fine. Replaced bc I was in there. Don't buy 1-3mm. Buy slightly larger 2-4 - just my opinion, but I feel like I went wrong here. No biggie tho. Stock beads New beads Last edited by tlow98; 07-12-2021 at 12:07 PM.. |
11-11-2021, 02:31 AM | #25 |
Rep 5,002
Installed the following:
- Front Bilstein B4s - New OE bump stops - Lemforder front control arms - Lemforder lower control arms So, all four front control arms. The handling is incredible now. Everything was tired at 74k miles. I was debating how big of an improvement this would be. Rather shocked how much better it handles. It no longer falls into holes and squeaks on big undulations. Very happy I did it in the end. |
11-11-2021, 09:20 AM | #26 | |
175
Rep 303
saphire24051.00 |
11-16-2021, 12:01 PM | #27 | |
Rep 5,002
The control arms you just have to manage the weight of the spindle + rotor assembly at times. It would be nice to have 6 arms at those times, but completely doable on jack stands in the garage. Getting the chassis mount bolt on the front control arm requires some finesse and a crow bar at times. |
11-29-2021, 10:07 PM | #30 |
Rep 5,002
Recalibrated the transfer case. Foxwell NT530 made it very easy.
Great success. |
sukhk5272169.50 M302_imola842.50 |
04-22-2022, 06:15 AM | #31 |
Rep 5,002
Ok more maintenance love for the f15 @ 82k miles.
- transmission filter and fluid change. - front diff fluid - rear diff fluid - rear pads and rotors - engine oil and filter The fluids all looked surprisingly good at this mileage as many others have experienced. You can use a Carly unit to track trans temp in order to get the fill level correct. No change in driving characteristics that I could tell. I take that as a good thing as none of the fluids were too far gone to detect any change. View post on imgur.com View post on imgur.com Last edited by tlow98; 04-27-2022 at 12:14 AM.. |
04-22-2022, 09:59 AM | #32 | |
Bimmer Nut + Software Dev
553
Rep 802
Drives: 2018 Audi S3 IE Stage 1
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
04-22-2022, 10:05 AM | #33 |
Rep 5,002
whoismorggan553.00 |
04-22-2022, 10:07 AM | #34 |
553
Rep 802
Testforce4.50 |
04-27-2022, 12:28 AM | #35 |
Rep 5,002
Started getting an odd rattle in drive and reverse while parked.
First assumption belt tensioner and idler pulleys. Replaced both the tensioner and the idler pulley plus the belt. Noise still persists. Glad I replaced them - the tensioner had a lot of axial play and was mostly worn out. Pretty easy to do these without removing the fan. Just tie back the AC lines like such. View post on imgur.com Old garbage out! View post on imgur.com Then when you forget to put the dust cap on the idler after you reassemble everything. So, you need to McGyver a crow bar with some tape and it snaps back on. Great success! View post on imgur.com |
04-27-2022, 12:31 AM | #36 |
Rep 5,002
The noise I’m getting at idle in drive or reverse is not rpm dependent. Not sure what to think. When I put it in park it disappears.
Happy to hear some suggestions. Last edited by tlow98; 04-27-2022 at 12:50 AM.. |
04-27-2022, 09:42 AM | #37 |
Rep 42
Love all the maintenance updates! How did you decide what to tackle first? We have a new to us '15 X5 xdrive35i with 38k on it so far and all the records from the dealer but I want to make sure I'm keeping up with the stuff that will be coming up. Anyone have a link to a good list of recommended services at key mileage points?
tlow982188.00 |
04-27-2022, 10:33 AM | #38 | ||
20
Rep 13
04-27-2022, 12:49 PM | #39 | |
Rep 5,002
At your age I would be more attuned to rubbers that are aging out - serpentine belt or air suspension if you have it. Otherwise, I'd say just enjoy it! |
05-05-2022, 10:21 PM | #40 |
Rep 5,002
Rattle at idle in gear persists. Can't seem to find it. Annoyed.
Tried checking everything I have every touched. Tried looking for loose bolts everywhere that were in sight and easy. Tried zip-tying some hoses and cables down. Next up - check to make sure the spark plugs are tight. Not looking forward to it, but seems prudent. |
05-07-2022, 11:16 PM | #41 | |
Rep 55
05-08-2022, 06:57 AM | #42 | |
Rep 2,635
https://www.jdpower.com/Cars/Shoppin...e-when-at-idle |
05-09-2022, 01:51 AM | #43 | |
Rep 5,002
I also hear at low speeds on certain bumps or rough pavement. I have a few other places I want to investigate (steering rack, etc.), but it’s definitely most noticeable in the cabin. Like something ticking against the firewall. It’s start to make itself heard while in park at certain times. Always while stationary in drive or reverse tho. Seems louder from drivers seat than from the passenger seat. Similar for you? Last edited by tlow98; 05-09-2022 at 02:08 AM.. |
05-09-2022, 10:52 PM | #44 |
Rep 55
I have't noticed it while driving yet. I also did not have anyone else to stay in driver seat, since mine is mainly heard while parked and probably most when i engage reverse and just let the car roll. But it seems like we're having the same issue.
