07-03-2016, 03:03 AM | #2531 |
Rep 8,364
Which ECU's did you VO Code? There are TPMS FDL's in DSC, BDC, KOMBI, and HU_NBT.
07-03-2016, 05:34 AM | #2532 | |
Rep 458
Which ECU's did you VO Code? I can try to VO code DSC and BDC as well to see if that works. Thanks. |
07-03-2016, 12:42 PM | #2533 |
Rep 3,990
Once you do this, make sure you drive for a while. Some older F15s (mine is 2014) take longer to reset than others. Once the tires turn green, that is a good sign. You just have to drive for quite some time. They will eventually reset.
07-03-2016, 03:03 PM | #2534 |
Rep 458
Thanks for everyone's help. It worked once I VO coded DSC and BDC. Once I started driving I saw the %s increase, tires turned green and about 2min later tire pressure and temperature show up.
For those that don't have TPMS and want to code it (Canada) - add 2VB to FA and VO code DSC, BDC, KOMBI, and HU_NBT. I am not sure if all of them are needed but at least this is the combo that worked for me. |
07-03-2016, 03:22 PM | #2535 | |
Rep 8,364
07-03-2016, 03:36 PM | #2536 | ||
Rep 458
Thanks. |
07-03-2016, 03:59 PM | #2537 | |
Rep 2,404
07-04-2016, 11:16 AM | #2539 |
Rep 480
That would be exactly what I'm looking for!
07-04-2016, 04:34 PM | #2540 |
Rep 2,404
I messed with it for a bit today, but not getting the results I expected.
The codes I am looking at are below. They are both in ICM and BDC body. I will look into it more later today. FesGwsKopplung FesGwsSportMode FesGwsStdMode FesGwsControl |
07-04-2016, 09:44 PM | #2541 |
Rep 3,990
For those of you discussing the shift lever and sport mode, you need to read this thread: http://www.2addicts.com/forums/showt...1017977&page=2. RPM90 explained it as such:
"For my part I'm not guessing, I'm going from experience and reading tech info on how ZF designed this trans. It's a very high tech torque converter trans. The best AT I've ever driven, and I'm an MT driver who got caught up in the high tech-ness of it all. But I think my next BMW will be back to MT. Regarding the trans and shift lever position, we've covered what it does. What you are experiencing is how it is designed to work. In any driver mode, moving the lever to the left puts the trans in DS mode, which is sport mode for the trans shift programming, where it holds gear longer waiting to shift at higher rpm for better acceleration, because you're accelerating in the lower gear longer. Anytime you select DS by moving the lever over the trans will drop one gear, because it thinks you want faster/sportier acceleration. If you are in sport mode, with chassis+drivetrain selected, keeping the lever in the normal right side position also puts the trans in "sport" mode, meaning it will hold gear longer. Moving the DS mode will drop a gear, but will retain the sport shift programming. IOW, when in sport mode the trans shift program is the same whether the lever is in standard position or the the left/DS position. Even though it downshifts 1 gear it will still upshift fairly quickly to where it was and then continue to shift under the same programming. You can test that by keeping the throttle steady while in the standard lever position, then move it to the left/DS position, it'll downshift 1 gear but as lnog as you don't push the throttle for acceleration the trans will shift back up. It's an odd thing that BMW thought would be cool I guess. You can get the same effect by leaving the lever in default position and pressing on the throttle to activate a downshift like for passing. You may have discovered this already, if you press the throttle down it will down shift a gear. But if you push ALL the way down past that little resistance point, it will activate a multi gear downshift for RIGHT NOW passing." Now...if you want to code your vehicle to begin in Sport Mode, djsaad1 tested this earlier for a few modes. It's somewhere in this thread. Mine is currently coded to do this whenever the car shuts down in Sport mode. It will turn on in Sport mode.
07-04-2016, 10:01 PM | #2542 | |
Rep 592
Nice write up Opasha. Below is djsaad1's post on the last driver's mode memory code.
07-05-2016, 07:03 AM | #2543 |
Rep 480
Very nice! If it works, we can add this to the cheat sheet.
07-05-2016, 01:47 PM | #2545 |
Rep 2,404
Fes is the rocker switch, gws is the gear lever.
I tried a few combinations but nothing seemed to change. The descriptions make it seem like that is exactly what it's supposed to do. Now I barely ever drive this car, so I don't really know how it typically feels. It is possible it is turning on sport mode without actually stating it in the cluster, though I doubt it. I would turn on the codes in icm and see if you feel a difference with chasis. I wouldn't worry about the bdc body codes. |
07-05-2016, 07:02 PM | #2547 |
Rep 40,786
PM sent.
07-06-2016, 08:16 AM | #2548 |
Rep 5,483
I would like to have my 2016 X5 coded. Can someone do it remotely?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
07-06-2016, 10:18 AM | #2549 |
Rep 3,990
I can do it Saturday evening. Send me a PM if that works for you. Make sure you have an ENET cable, software from shawnsheridan, and a laptop with TeamViewer installed.
07-06-2016, 03:25 PM | #2550 | |
Rep 480
I've played with the fesgwscontrol parameter. When set to nicht/nicht, I can no longer switch to sport or sport+ mode. Only comfort or eco can be used, allthough sport and sport+ are both still visible. I couldn't find any other info on the internet regarding these parameters. How did you find them? |
07-07-2016, 01:31 PM | #2551 | |
Rep 2,404
The icm in the f15 has a lot more codes in it, compared to the f10 or f12. |
