01-16-2022, 05:36 PM | #45 |
Rep 1,497
I'm in the market to replace my main battery as my HUD has started working intermittently which is a telltale sign my battery is on the way out. I don't have adaptive steering so I'm pretty sure I don't have an aux battery. Anyhow, what are my options for a non-BMW branded main battery?
01-16-2022, 10:08 PM | #46 | |
Rep 7,488
If you have a 105AH or 110AH battery, then you’ll need to shop for a 95R/H9 AGM replacement battery.
M302_imola842.50 |
01-17-2022, 03:25 PM | #47 | |
Rep 1,497
01-17-2022, 03:29 PM | #48 | |
Rep 19
M302_imola842.50 |
01-17-2022, 03:57 PM | #49 | |
Rep 1,497
01-29-2022, 03:45 PM | #50 | ||||
Rep 152
Lastly, do I need the bimmerlink app to code/register new battery? I'm thinking of buying a 49/H8 from local auto zone.
Jeff
Current Ride - 2016 Toyota RAV4 Hybrid - 2014 X5 xDrive35 M - 2013 ML-350 (Gone) - 2012 Audi Q7 TDI (Gone) |
01-29-2022, 07:51 PM | #51 |
Rep 97
Once you take the battery cover out, it will be easy to see if you have 1 or 2 batteries. If you replace it with same size one, there is no need for coding. However registering is needed regardless of battery type. You will need ISTA or other app to do this.
2018 X5 35i
01-30-2022, 12:53 PM | #52 | |
Rep 7,488
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-30-2022 at 01:08 PM.. |
przybylski0.00 |
01-31-2022, 07:42 AM | #53 |
Rep 270
01-31-2022, 09:35 AM | #54 | |
Rep 7,488
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-17-2022 at 10:13 AM.. |
01-31-2022, 02:04 PM | #55 |
Rep 270
Wow, thanks - that's interesting info. I do have rear heated seats but not the other items listed. Seems a pretty common option (rear heated seats) but not that common to have the aux. battery. I'm going to look again at the build sheet for my F15 to see if there are any clues about this. Thanks again!
06-15-2022, 01:11 PM | #56 |
Rep 35
Hi all, just replaced the aux battery using the ln1agm from Rock Auto. Wasn’t experiencing any issues, just wanted to replace a 7 year old battery to be ahead of the game.
Anyways, the ln1agm is 520cca, and the oem bmw battery is 570cca. Does the lower 520cca matter? It seems that it might, which is why the oem battery is over $400 still. I do not have access to ista anymore, but it seems it is not necessary to register the battery. I’ve read through every forum post here, and no one has ever actually confirmed to register the aux battery. Any update thoughts are welcome. Cheers |
06-15-2022, 09:45 PM | #57 |
Insta~ f10_sapphire
158
Rep 412
My shop registered the aux battery aswell with acel. I got the 520cca from gm dealership as it's for a Chevy bolt 2018. I was wondering the same as the above comment. Any feedback helps.
Insta ~ f10_shapphire
07-10-2022, 11:19 PM | #60 |
Insta~ f10_sapphire
158
Rep 412
Only difference I've seen is after the car is off and you have music and electronics on the car powers off sooner than the oem would. Not by much by a little sooner. Guessing the voltage drops earlier to power off.
patrocle6.50 |
07-16-2022, 11:31 PM | #61 |
Rep 23
How much was the battery? from Chevy? Years Warranty?
2017 Bmw X5 F15
07-16-2022, 11:32 PM | #62 |
Rep 23
Thanks for that info!
2017 Bmw X5 F15
07-16-2022, 11:34 PM | #63 | |
Rep 23
2017 Bmw X5 F15
07-17-2022, 10:06 AM | #64 | |
Rep 7,488
Engine displacement is usually expressed in cubic centimeters (CC) or liters (L), which is the total cylinder volume of the engine…1L is about 61 cubic inches (CID) Doing the math...the N63/N63TU iteration engines are 4.4L engines…so:And since the smaller LN1 aux battery is NOT the main battery…it is just used to help with extended electrical needs like ASS (auto stop/start)…a 520 CCA rating should be more than enough to handle the needs of our engines. (Just an opinion based on simple math).
patrocle6.50 |
07-17-2022, 02:29 PM | #66 |
Rep 23
Was at sams club yesterday and they said that they have the 48 570 cca battery but not in stock, see attached. I don't think they have it. Curious when they will stock it back to have a look. See attached picture , is not for the 2017 x5 f15, but older model x5 witch he said it should be the one..hmm interesting
They have duracell platinum agm batteries from what i saw.
2017 Bmw X5 F15
