03-24-2020, 10:43 AM | #1 |
Rep 74
Maintenance Questions
Hey guys my bmw is at 108,000 KM 2015 X5 35i
I was recently getting an oil change and they were trying to sell me on a few services a) fuel injector flush ... is this such a thing? I've never heard of this ... but then again this is my first bmw ... does the n55 have fuel injection? b) coolant flush ... front desk said it was black should be blue ... does coolant even go bad? These were quoted at $189/199 + applicable taxes (CAD) Also should I be doing any transmission flush/diff flush? is that more preventative or required Also at what Kms should i do my spark plugs? Car runs flawlessly right now and would like to keep it this way FYI 108,000 Kms is roughly 67000 miles i hardly drive anymore since i got a job thats a 20 minute walk ... i dnt beat on the car hardly carries more then 2 people now adays |
03-24-2020, 11:34 AM | #2 |
Rep 159
Yes, coolant goes bad, it breaks down just like oil and it gets contaminants just like oil. Coolant flush is legit. Injector flush? Just buy yourself some Techron and drop it in the tank every oil change.
There is a BMW injector cleaner but it is made for use when pulling the injectors and using an injector cleaning machine. I can guarantee you that is not what they are talking about doing. They are just going to drop some Techron in your tank. It;s early to do tranny flush but at 67K I would do the plugs. |
03-24-2020, 12:36 PM | #3 |
1636
Rep 2,995
Waste of money.
Coolant lasts a long time. Just wait until you have to change any coolant system parts to do so. And just use techron or similar in tank cleaner every so often. But even that is not necessary. |
03-24-2020, 01:41 PM | #4 |
Rep 159
Not a waste of money. A very prudent thing to do and something that can easily be done by any shade-tree mechanic. 2 Gallons of Zerex G-48 $36 2-3 Gallons of distilled water $3. That's $40 for piece of mind. And no special tools. Good strong, coolant inhibits corrosion and prevents overheating.
That is cheap protection for a very expensive engine. Last edited by Chicane_S54; 03-24-2020 at 02:58 PM.. |
03-24-2020, 02:38 PM | #5 |
Rep 1,168
03-24-2020, 03:35 PM | #7 |
Rep 7,484
BMW USED TO recommend changing the coolant on a 2-4 year interval. You can also have it tested to check if it is up to par.
Currently, it looks like BMW has put the coolant on the same “lifetime” schedule as transmission fluid. See TIS info: https://www.newtis.info/tisv2/a/en/f...enance/1DUJMrq
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-24-2020 at 03:47 PM.. |
03-24-2020, 05:31 PM | #8 | |
Rep 159
03-24-2020, 05:58 PM | #9 | |
1636
Rep 2,995
You can't compare lifetime coolant to lifetime trans fluid. Totally different. Coolant isn't like transmission fluid that gets burnt and dirty. There's no parts that wear in the coolant system. Coolant doesn't get burnt. Coolant circulates in a closed system and just transfers heat. |
03-24-2020, 06:28 PM | #10 | |
Rep 159
As far as replacing the coolant itself, you clearly have no idea what you are talking about get yourself an education: https://www.cbac.com/clermont/media-...-a-coolant-fl/ And stop spreading false information. |
12-13-2023, 12:58 AM | #11 | |
Rep 5,002
12-13-2023, 06:55 AM | #12 |
Rep 805
Drives: BMW X5 XDrive35i
100% need to flush coolant every 2 years or 20k miles. No question. Same goes for brake fluid.
ZF recommends gearbox service as early as 40-50k miles which is what I follow. I’m at 72k and have already done the trans service twice and all driveline fluids are due again at 80k. Plugs every 30k on a stock tune car.
12-13-2023, 01:35 PM | #13 | |
Rep 5,002
Plugs on the n55 are called for only every 60k. Is you car the v8? |
12-13-2023, 08:17 PM | #14 |
Rep 805
Nah it’s the N55. I started getting cold start misfires around 35k miles on my own car so ended up replacing them at that time. But agree, I’ve gone a bit further in the name of reliability and longevity.
