      05-02-2021, 07:21 AM   #1
XxBBVTMxX
XxBBVTMxX's Avatar
NOTE: This is just to put out information. I searched around everywhere and could not find a concrete answer on how to do this, other than you need to retrofit to euro tail lights (not true on an F15). Shout out to @RED_Y_ for guiding me in the right direction and telling me that it will work on a 2014.
I have a MY14, F15, with Night Vision. On ESYS, go to..
*BDC_Body
*3064 LceLampMapping3
MAPPING_NEBELSCHLUSSL_L_OUTPUT
change to: nsl_l
MAPPING_NEBELSCHLUSSL_R_OUTPUT
change to: nsl_r
*3068 LceMaster
NSL_Verbaut
change to: Verbaut
3063: Is for your front fog lights on an F15
3064: Activates the lights to be used as rear fog lights
3068: Activates the button on your Light Control Switch, and the cluster light when pressed
BTW.. you should be able to do this with Bimmercode, but it will take longer because it is not as fast as finding and coding as ESYS.
Picture of the switch I installed below. It is all you need to make this work, or you can try to shave the tabs on your original light switch and see it that'll work.
Also, I did this out of boredom just to learn more coding for my F15. I have no need for rear fog lights but I know there's interest out there for people whom want to do it, so there you go.
      05-02-2021, 11:26 AM   #2
RED_Y_
Drives: 2014 X5 3.5d
Looking good, man good job! The CF cluster trim-is that a wrap or it is a true carbon fiber?
      05-02-2021, 11:31 AM   #3
XxBBVTMxX
XxBBVTMxX's Avatar
Thanks.
It's real Carbon Fiber. I sent all my interior trim pieces to the UK to a guy who does CF Skinning. He does a great job. You can find him if you Google "ABCarbon"
