03-07-2021, 01:21 PM | #155 | |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
It's f85, also I looked in FLE and there is nothing there that has parking lights or welcome lights.. seems like bc_body is where it should be
03-07-2021, 06:52 PM | #156 | |
Rep 2,635
- remote mirror lock/unlock - windows up and down with fob - tailgate open and close with fob - change inside lights - camera settings - HUD display settings - warning and chimes settings (I like the RR chime better LOL) - high beam and other light settings - Audio and video settings - turn signal settings - blind spot monitoring speed settings And so much more! I also can't believe why BMW won't provide the patch for CarPlay full screen when it works perfectly on the iDrive 6 system to all owners. It works flawlessly. I find iDrive 6 to be very stable. |
06-15-2021, 10:25 AM | #161 |
Rep 41
I am pretty sure I found the setting to prevent Ventilated seats from dropping back to a lower setting after 15 minutes or whatever it is. I will reply with a confirmation later today.
In Expert mode with BimmerCode: SMD/P --> 3008 SITZKLIMA --> SKL_ZEIT_ST3_NACH_ST2 Change from "werte_10" to "nicht_aktiv" Mark |
06-15-2021, 11:25 AM | #162 |
Rep 297
Thanks, does make you wonder why they made it lower the setting after however many minutes. My first thought is that they had concerns about durability of the fan motor.
Do any other markets keep the high setting indefinitely?. |
06-15-2021, 02:49 PM | #163 | |
Rep 41
Mark |
06-15-2021, 02:50 PM | #164 | |
Rep 41
Just a guess, but I would bet that is the reason. Mark |
06-16-2021, 02:30 PM | #165 |
Rep 41
r33_RGSport , is the google sheet you created still being maintained or expanded in any capacity. It would be great for a few folks to try to divide and conquer various sections to document as many options as possible. Example, in the sheet, the seat ventilation parameters I believe are not quite right. I think they should actually be fan speed, not temp. So the lower numbers result in lower performance. I am guessing a bit, but I could try to bite off this section and test and document. Would love to see perhaps some others do the same.
Another example, in idrive 6, the seat ventilation and heat params show up under climate settings so you can customize how the climate functions are set when you start the car, based on outside ambient temp. A very slick idea, but not available currently in idrive 6-lite. I bet it is programmable though. Thoughts on how to perhaps bring the google sheet up to date? Mark |
06-19-2021, 02:20 AM | #166 | |
Rep 8,364
06-21-2021, 10:18 AM | #167 | |
Rep 41
Mark |
06-26-2021, 03:19 AM | #168 |
Rep 8,364
07-06-2021, 05:03 PM | #169 |
Rep 41
Sorry about that!
Other items on my list: 1. Make the Auto Hold settings "sticky" 2. Check and measure the wheel/tire circumference / diameter settings. I recently moved to a 275/40R20 and 315/35R20, but the vehicle was originally shipped with 19s, so I want to see if there is anything I need to do there to make sure the spedo and odo stay accurate. Mark |
07-09-2021, 02:50 AM | #170 | |
Rep 8,364
07-23-2021, 06:32 PM | #171 |
Rep 16
Hi. Can anyone help with coding turn signals ? On my 2015 x5 I have turn signals integrated in eyebrows and there's no side turn signals in the headlights, now I got '18, and I got side turn signals . Can I code eyebrows to work as turn signals with these side turn signals , and after I turn off turn signal that they stay on if the headlights are on? And can I do it with Bimmercode in expert mode? Thanks
07-23-2021, 08:14 PM | #172 |
Rep 1,687
Drives: 2014 428i and 2018 X5
No
07-24-2021, 03:38 AM | #175 | |
Rep 8,364
07-24-2021, 06:14 AM | #176 |
Rep 16
Tags |
2014, coding f15, f15, f15 coding |
