12-18-2023, 11:36 PM | #1 |
167
Rep 599
X5 original M Power brake kit. Compromise nothing!
If you've been looking for a way to inject some M power into your ride, this may be a good way to start.
The X5M retrofit brake system uses a 6 Pot caliper in the front, paired with a larger, semi-floating 395mm disc, and a 1 Pot caliper for the rear, on a 385mm disc respectively. Braking performance, shortened braking distance and smooth stopping force (mainly due to the pistons, arranged in order, by size). There are the things you're looking at, after making the switch. Here's more info on this product: https://icarmix.com/product/genuine-...f15-x5-f16-x6/ And here's what to look forward to: |
Tags |
f15 x5, hong kong, icarmix, m power, x5m brakes |
