12-12-2021, 01:45 PM | #1 |
Rep 108
CEL s 0751
Hi I have a 2018 40e and got a cel with so called permanent SAE fault codes. Any clues?
I've attached ISTA+ screen shots. This instructions aren't that specific. Thanks! S 0751 (this triggered CEL) S 8411 (no warning light for this but including here for completeness) |
12-12-2021, 07:14 PM | #2 |
Rep 9
The two faults are not related. S 8411 just means that a call to a ConnectedDrive service couldn't be completed (e.g. because the car didn't have a good cellular connection or, way more likely, because some failure server side). S 0751 is a generic ISTA code for any permanent SAE fault, just calculate the measures plan and follow the instructions. The SAE fault clears after certain conditions are met within 3 driving cycles. The exception is if you clear the fault memory (i.e. S 0751) before the permanent SAE fault is healed, in that case the conditions to heal the fault have to be met in a single driving cycle. The first or second step in the measures plan for S 0751 should show you the specific SAE fault, search that in ISTA and it will point you to a specific support document with a specific list of healing conditions. A driving cycle for a combustion engine looks something like this:
1. awake control units (i.e. unlock the car or open the driver's door) 2. turn on ignition 3. run combustion engine, drive for at least 10 minutes, of which 5 have to be at 25 mph or more, and make sure the engine spends at least 30 seconds idling without interruption 4. stop the engine 5. let control units fall asleep (i.e. car entering rest state) There may be other steps involved in the case of a 40e, so you may want to look up "driving cycle" in ISTA. |
12-12-2021, 08:48 PM | #3 |
Rep 108
Many thanks gabep for the detailed instructions. The warning light went away after a couple 'normal' trips, so I didn't really get a chance to check measures plan.
12-17-2021, 11:42 AM | #4 |
Rep 108
The light is now intermittent. It went off, on, then off again over a number of drive cycles. Can I still calculate measures when the light is off? (I haven't got a chance to try it)
Thanks |
12-18-2021, 07:57 AM | #5 |
Rep 9
You need the fault to be present in ISTA to calculate measures, but there isn't a direct correlation between the fault being present and it triggering a CEL light (i.e. the fault is likely there, even if the light isn't on). I would just connect ISTA and see what shows up.
