      06-15-2018, 11:59 AM   #243
Katsumoto
Katsumoto's Avatar
126
Drives: MBB F95 Comp
going today at 4pm CST to dynojet . i use to have subaru STI and P&L are the best in the Subaru world . I will post the results today after i am back home .... finger crossing for good numbers
https://www.pandlmotorsports.com/services/dyno-tuning/
DuSh2113.50
      06-15-2018, 12:11 PM   #244
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
I'm not going to remind about silly things you know better than me - like turning off DSC etc. Vlado did you flash it with BPC proprietary cable? What I'm saying is that in theory you can probably flash it back and forth between stock oem flash and BPC Stage 1 - so we can see the real gains and put yet another mystery to an end.
However, I do realize this isn't realistic as you need time for DME to adapt, besides no one is going to wait for you on dyno while you'll be flashing car back and forth. Don't mind me - I'm just thinking loudly
      06-15-2018, 12:13 PM   #245
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Oh Vlado, I almost forgot - if they can read boost (like some dynos can provide that value as well on the graph - like max boost that was achieved during dyno runs) - that would be great! We'll have a reference point for the future plans.
      06-15-2018, 12:20 PM   #246
Katsumoto
Katsumoto's Avatar
126
I will be honest with you ... I did flashed the DME myself with BPC cable obdII ... it is about 25 minutes to go stock and then another 25 to get tuned again to stage 1. In Chicago area i was not able to find dyno that they are open on Saturday's. they are all off weekends . Most of the tuners are till 5pm . P&L are till 6... i highly doubt i will have time to do that , but i will try get as much information as possible
DuSh2113.50
      06-15-2018, 12:28 PM   #247
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Vlado, don't worry about it man. Your dyno result and graph is already very much appreciated!
Still if you get a chance to find out about msx boost recorded during dyno run - that would be awesome!
      06-15-2018, 07:01 PM   #248
frenchie1013
frenchie1013's Avatar
78
Drives: sedan
Can't wait to find out numbers !
2010 335i Rwd 6spd
MHD Wedge tune, VRSF Exhaust,FMIC, DP and CP, PR Inlets
2014 X5 50i
BMS stage 1, Dinan intake, F85 Knee Bolsters
DuSh2113.50
      06-15-2018, 07:06 PM   #249
CT335xi
CT335xi's Avatar
684
Drives: 2022 x5 m50i, 2005 evo 8
In for the results too!
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno
Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr,
04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp
2014 x5 50i msport
DuSh2113.50
      06-15-2018, 08:14 PM   #250
Katsumoto
Katsumoto's Avatar
126
Well , here is. I will have to contact BPC. Not sure how to explain but when AC is on after 4.5k RPM car start shaking a bit. Its like not enough airflow or too much. When AC is off nothing is wrong and there is torque increase. Hp are all the same with AC ON-OFF. So i guess is about a little adjustment. There is no more details unfortunately. No boost pressure, No temperature etc ... after all happy with the numbers and hope will help you too
      06-15-2018, 08:18 PM   #251
CT335xi
CT335xi's Avatar
684
Nice numbers got to get some runs done stock like Dush mentioned so we can see the gains.
2014 x5 50i msport
      06-15-2018, 08:29 PM   #252
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Nice numbers.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      06-15-2018, 08:33 PM   #253
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Well - 485awhp and 602awtq! Stock X5M F85 puts down 517whp and 543wtq. You are basically at the X5M level right now! Just a bit under with hp, but above with torque.
Vlado what fuel you were using? Do you have X5M air filters installed? So close breaking 500awhp with just a tune on regular pump fuel.
P.S. So the good thing is that in the future if you'll feel like it - you can just update your tune with Bob for much less money. That's what I'm going to do in August. Going to push for 20psi or 21psi. 21psi can be achieved with our stock tmap sensor - so no need to change anything. I'll do Dynojet this time too. I'll probably add meth kit for cooling and octane boost purpose.
      06-15-2018, 08:33 PM   #254
Katsumoto
Katsumoto's Avatar
126
Forgot to mention BP 93 octane and about 80 F degrees, but numbers won't change lot
DuSh2113.50
      06-15-2018, 10:41 PM   #255
frenchie1013
78
Drives: sedan
Can't wait to get my tune from BPC!
2010 335i Rwd 6spd
2014 X5 50i
      06-15-2018, 10:42 PM   #256
frenchie1013
78
Drives: sedan
Heard that the Dinan filters may flow a little more then the ones
2010 335i Rwd 6spd
2014 X5 50i
      06-15-2018, 11:29 PM   #257
Katsumoto
Katsumoto's Avatar
126
I actually have OEM x5M air filters. Do you think that might be just a bit more airflow ?!? :
      06-16-2018, 06:33 AM   #258
CT335xi
CT335xi's Avatar
684
Got to hit the strip or get vbox numbers , curious to see how it does compare to a stock x5m, those numbers are crazy!!
2014 x5 50i msport
      06-16-2018, 07:27 AM   #259
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Considering he has more torque - he would be faster from the dig and have faster 60' time on 1/4 slip. Then X5M may start to catch up as hp is a bit more with X5M. This could be a draw on 1/4.
He can also add a bit more higher octane fuel (for 1/4 run) or booster and tune will adjust timing a bit more - so I'm sure he can be at 500awhp either with a octane booster added to the tank or maybe a gallon of race gas (100 octane) added. I remember times when 500whp was holy grail that few could reach. Now it's doable with almost just a tune lol. Amazing.
P.S. This is why I'm going to try meth kit - as it raises even 91 octane to up to 100 octane easily. It also cools IATs and cleans valves and pistons - basically never need to do a walnut blast. Tho I have no idea how true it is - I'm just speculating on what is written on n54tech forum.
CT335xi684.00
      06-16-2018, 11:48 AM   #260
CT335xi
CT335xi's Avatar
684
Yes meth should help, I run it on my evo 8 to keep intake temps cooler. My evo is extremely modded as the x5 is stock for now but definitely want to do a tune, wife’s car so can’t modify it like my evo she would flip. Though I do enjoy it every opportunity I get to drive the x5. If your interested do a search I actually had the x5 on the dyno along with my evo 8 as it was getting the tune touched up. Dyno was a mustang and the x5 put down some pretty good torque stock actually more then my evo 8!!
2014 x5 50i msport
DuSh2113.50
      06-16-2018, 03:24 PM   #261
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
The M filters are larger on the front that the stock 50i filters so yes. But they're smaller than dinan. Not sure which you're referring too.
'06 C55 AMG (sold)
      06-17-2018, 09:18 AM   #262
frenchie1013
78
Drives: sedan
Question for everyone regarding the numbers...bpc's website shows 474whp and 514wtq .... Vlado's was is roughly the same who but TQ is so much more, what would be the reason for that's? It can't be just the x5m filters
2010 335i Rwd 6spd
2014 X5 50i
      06-17-2018, 09:34 AM   #263
CT335xi
CT335xi's Avatar
684
It could be the way the dyno is calibrated, but yeah does seem a little high even for a dynojet which do read the highest of most dyno’s. On a awd vehicle putting down 600 awtrq to the wheels would be over 700 lb-ft of torque at the flywheel which is over 200 more then stock
2014 x5 50i msport
      06-17-2018, 09:43 AM   #264
CT335xi
CT335xi's Avatar
684
I just looked at BPC posted dyno graph for the n63tu 347/399 and those seem pretty low for dynojet , considering the flywheel rating is 445/480 and probably under rated estimate at best from bmw. Also if the test vehicle was rwd they should of been even high because of less drive train loss 2 vs 4.
2014 x5 50i msport
