12-22-2014, 02:36 PM | #68 | |
Rep 3,990
1) hit it once, lock your car with remote or comfort access 2) hit it twice 3) code it to only hit it once so that radio and gps turn off (from what everyone says, this is a complete shut down)
12-23-2014, 12:32 AM | #70 |
Rep 1,806
I'm not addressing any of the points in particular, but because countries have different regulations or laws, sometimes they may look inconvenient. As an example the remote on/off is not allowed in Europe so you can't leave your car with on engine unattended for more than few minutes, etc.
I presume that other items come to play as well... |
12-23-2014, 03:57 AM | #71 |
Rep 450
That's a different issue to mine where the engine kept running sometimes even after pressing the on/off button multiple times. If it is a 30 mins delay it sounds like it has something to do with the car going to sleep after 30 mins. Where are you powering the detector from? 12v socket or hard wired somewhere else.
12-23-2014, 06:24 AM | #72 | |
Rep 1,448
Not only do the detectors stay in after pushing stop/start two times but if I go to the garage and simply open the door (when it is unlocked) or more importantly even when I lock the car at my office parking lot.
2019 BMW X5 xDrive 50i M Sport: ZD8/ZLS/ZMP/ZP2/ZPK/ZPX/337/ZX7/2NH
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
12-26-2014, 12:13 PM | #73 |
173
Rep 391
I only have 1500 miles on my F15, so I'm sure I'll get used to some of these things, but:
Lots of things to really like about the F15, but there are quite a few annoyances and surprises that make me wonder what BMW was thinking. When I leased my E70, I thought it was just about the perfect car at the time. Maybe they raised the bar too high with the E70. Despite the good (engine, suspension, transmission) and all the advances and cool stuff, the F15 falls flat in quite a few places. |
12-26-2014, 02:21 PM | #74 |
Rep 188
Okay, I've got two more:
1. I feel like the car is really laggy in reverse. Especially on a steep hill like the one in front of my house. The gas pedal would take a big hit before the car even moves an inch.. And as soon as it starts moving it will be in a speed much bigger than anticipated. It's particularly irritating when you are trying to park on a snowy hill backwards. None of my previous BMWs acted like that. 2. The right side of the HUD is barely seen from my sitting position. That's where the navi usually is. I've tried hight and rotation adjustments to no avail. Again, this behavior was not observed on my F10. Although I know (2) will not be solved, I hope at least I can solve (1) with racechip or an alternative.
On order - 2017 F15 X5 40d M-sport Individual
Current - 2016 Porsche 991 911 Turbo S w/ Aero Kit Retired - 2015 F15 X5 50i, Mocha Nappa, M Sport Wheel, Night Vision w/ human recognition, Harman Kardon Retired - 2011 F10 550i xDrive |
02-22-2015, 12:24 AM | #75 | |
117
Rep 324
02-22-2015, 12:36 AM | #76 |
Rep 3,990
-Why do I have to turn off the car 2 times to make radio etc, be silent?
Codeable (in cheat sheet). -Why cant the high beam assistant work under 50 km/h? Codeable (JUST FOUND IT) for all you LED folks who want their auto high beam activated sooner . Below speeds are in HEX VALUE: 00—> 0, 08—> 8, 1F—> 31, 32—> 50, 64—> 100, FF—> 255 BDC_Body / C_HBA_ENA_V_HI / default value = 46 (43 mph) - this is the speed when the HBA enables BDC_Body / C_HBA_ENA_V_LO / default value = 3C (37 mph)- this is the speed when HBA disables
02-22-2015, 06:01 PM | #77 | |
Rep 450
To clear it I have to enter another destination and then cancel navigation which isn't very good. |
02-22-2015, 06:02 PM | #78 |
Rep 450
02-22-2015, 08:52 PM | #79 |
Rep 265
I have found that during the day Like when the sun is directly overhead, the HUD compartment reflection is distracting on the windshield. That's probably my biggest annoyance so far.
02-22-2015, 10:44 PM | #80 | |
Rep 1,756
I think it would nice if it does that if you arrive and stay at your destination exactly there for a while or shut off engine, otherwise maybe it should keep the directions in case you just drove past and still want to see where it was, or if you found the place, you are too early, you decide to roll away and see what else is in the neighborhood, and then be able to easily come back to the same spot. (Happens to me all the time, I go to a meeting somewhere, I see that I am 40 minutes early, instead of walking in like I have nothing else to do, I just keep driving and explore the neighborhood)
02-23-2015, 02:17 AM | #81 |
Rep 424
Warning. If you read number 1 on my list you will likely get annoyed at this design flaw which you are currently oblivious to. Do yourself a favor and skip it...ignorance is bliss, after all.
The only gripes I have so far are: 1. Blinker stalk has a seam on the bottom, right in the middle. I should not be able to feel a seam on a lux car. 2. Like many others, audio controls on right side of steering. 3. Lack of space to put cell phone. WTF is the squarish hole below idrive for?? Everything else that a few others do not like, are great IMO (ie music plays until locking car). Last edited by Snow-Kidney; 02-23-2015 at 02:33 AM.. |
02-23-2015, 03:41 AM | #82 |
Rep 198
Theres one thing that I really miss from my E53 and its the button on the steering wheel that allows you to instantly switch the airflow to internal circulation only. I know that there is a button on the dash that allows you to do it, i just feel like the one on the steering wheel is much more convenient.
02-23-2015, 06:52 AM | #83 | |
Rep 450
It's odd because it isn't like you drove past your destination and it is still giving you turn by turn driving directions, it just indicates the overall direction back to the last destination when you are driving away from it. |
02-23-2015, 07:53 AM | #84 |
Rep 2,712
steering wheel moving when leaving the car
Each time I leave the car outside I put a wheel strip on the car. It is a good one and somewhat unique for the car. After my E70 was stolen, I took advice from a friend and got one for my E71, they tried to steal the car (right after it came back from the service and that's the only thing they could not take off, every compartment was opened). Anyways, an sure it is not perfect, but it is better than having nothing. What it sure is IT IS IMPRACTICAL! It does not help that after I close the door, the steering wheel changes position so I have to open the door (unlock) to adjust the setting again (otherwise it might damage the steering wheel). On E71 as soon as you adjust it once it would go away, here I have to play with until it sets itself. I tried ticking off the option of automatic seat adjustment (not sure what's it called), but the steering wheel keeps moving in auto mode.
I must say that this is annoying for me, but if I would not have to put the wheel strap on, I must say that it would be a nice touch. |
02-23-2015, 09:47 AM | #85 | |
Rep 1,756
What kind of lock are you using? Also, steering moves only after you completely turn off the vehicle, so just hit the start/stop button twice with your foot off brake pedal, and the steering wheel will move into it's normal position, then you can lock it.
02-23-2015, 10:55 AM | #86 |
Rep 19
I've had mine for a couple months now, and can mention a few I've found. Apologies if any of these are elsewhere in this thread.
Music needs a "back" option, to go back a directory level, kinda like "cd.." in the old dos days. I have music in directories, and if I decide to change directory, i have to start all over again at the very top, via the search function. Top of each directory should be 'back', or even better, knob left. The rain sensor logic is awful. There's some kind of delay in there. I know it's the logic, because the autowipers in my Audi work great. Sometimes I'm at a light, the setting one notch below full-sensitivity, and the windshield is completely covered with rain. Days where the rain comes and goes, completely befuddle it. Dipstick. Yes I know it adds $1 to the cost of each vehicle. I prefer to have one. At least they put in a way to check level via the computer. M-sport steering wheel controls are awful. They clearly chose form over function. Same for the leather on there. Its really slippery...just what you want on a steering wheel. Sunglass compartment sucks. It's small, glasses sometimes jam on the release button, and there's no felt in there. Basically Kia quality. Probably a last minute design for the US market or something. The throttle is way too sensitive. They could engineer any feel they want, since it all goes through the computer. Marketing probably told them that people associate touchy with lots of power. But they overdid it. It's impossible to go slowly over a small bump, like a curb or the lip of a garage without lurching. Eco mode is better, but then you get all the other eco crap. Dehumidifier. This time of year, I don't run the AC. The AC button is off. However if it's a little humid, the compressor will come on. So I'm driving along, comfortable, nice 68 dergee fresh air coming in, and all of a sudden, the temp drops to like 45. For a minute, then goes back. Everyone shivers, and I can't do anything about it. I live in Houston. It's always humid. So the AC is in there, lurking all the time, ready to pounce and freeze me without notice. The steering is a little overboosted at slow speeds too, which I guess might be good, with the steering wheel coated in teflon-tanned leather. |
02-23-2015, 11:00 AM | #87 |
Rep 441
Drives: BMW M135i & 911 GTS
I find the new M Sport steering wheel an improvement over the old one. Not as thick and the change from left to right with controls easy to work with.
02-23-2015, 11:21 AM | #88 | |
261
Rep 733
