04-05-2016, 10:42 PM | #133 |
Rep 251
bolts
Just gearing up for my summer wheels with 20mm spacers.
Which bolts go with the 20mm spacers for the rear? And what about the wheel locks if you replace the bolts? Do you need to buy new ones? Thanks |
04-05-2016, 10:51 PM | #134 | |
Rep 18,751
Unfortunately, I don't think there is any wheel locks available in 20mm longer than stock.
04-06-2016, 09:41 AM | #135 |
Rep 1,547
Does anyone even run wheel locks anymore? I haven't bothered...maybe its where I park, or don't park I guess.
04-06-2016, 10:08 AM | #136 | |
Rep 18,751
Especially those who park on the street overnight.
04-07-2016, 10:09 AM | #137 |
Rep 251
Thanks Ben.
My vehicle came with wheel locks so I kept them. The only time it caused an issue was when i brought my car in to swap to my winter setup and the dealer forgot to put the wheel lock key in the car.
2018 M3
2017 X5 35d xdrive Msport Sold: 2014 X5 35i xdrive Msport |
04-07-2016, 10:31 AM | #138 | |
Rep 18,751
But yea, forgetting the key is not fun.
04-07-2016, 11:27 AM | #139 |
Rep 984
For my 25 mm rear spacers, they came with short bolts to attach the spacer to the hub, then use stock bolts to attach wheel to spacer. So in this case you could use stock length wheel locks if I desired.
04-07-2016, 12:03 PM | #140 | |
Rep 18,751
04-07-2016, 01:01 PM | #141 |
Rep 1,547
I'd only run those adapters if you're changing bolt patterns to run a different wheel. If the bolt pattern isn't changing, that's some unnecessary weakness IMO. Just my .02.
04-20-2016, 09:26 PM | #142 |
Rep 16
04-20-2016, 09:28 PM | #143 |
Rep 18,751
PM'ed
09-12-2016, 08:43 PM | #144 |
Self-Deprecating Narcissist
7266
Rep 6,561
on the oem 21" wheel what is the recommended spacer set up?
09-12-2016, 09:11 PM | #145 | |
Rep 18,751
09-13-2016, 07:46 AM | #146 |
7266
Rep 6,561
Extended bolts need on the 5mm set up or does the 8mm+ rule hold with this vehicle as well?
09-13-2016, 09:07 AM | #147 | |
Rep 18,751
09-13-2016, 07:14 PM | #148 |
Rep 1,547
15/20 IMO...but to each their own.
I would still run longer lug bolts for 5mm+
09-13-2016, 08:52 PM | #149 | |
Rep 18,751
iconoclast7265.50 |
09-13-2016, 09:05 PM | #150 |
7266
Rep 6,561
let's take this to PM. sent over a message.
09-14-2016, 09:40 AM | #151 |
Rep 1,547
My buddy is running them on his 2016 X5 M Sport without issue.
09-14-2016, 11:07 AM | #152 | |
Rep 18,751
Take off the front wheel again and see.
12-13-2016, 03:40 PM | #153 |
Rep 103
Hi, I'm on your site trying to order the spacers for a 17 X6M. I haven't read the entire thread but I'm assuming you're still recommending 5mm front and 15mm rear? And there are two lug options for the 5mm and I don't understand what the difference is ... could you tell me which one I want? Thanks.
12-13-2016, 04:41 PM | #154 | |
Rep 18,751
The lug bolt thread for all the F chassis BMW is 14x1.25.
