      04-03-2024, 09:45 PM   #1
RATED_M
RATED_M's Avatar
Drives: E92 M3 Comp
No air blowing through AC vents
Something weird is going on with the AC system in my F86. I'm not getting any air flow through any vents (from what I can tell) but when I adjust the fan speed I can hear the fans. It just sounds like the air is stuck in the dashboard.
The only thing I did recently was install CarPlay MMI - I have a 2016. I had to disconnect both batteries and unplug everything in the console. Could I have done something wrong here?
Current:
2011 Jet Black ///E92 M3 Comp DCT
Previous:
2017 Yas Marina Blue ///M3 | Silverstone | DCT
2018 Citrin Black 340xi | Dakota Black | 8-Speed Auto
      04-04-2024, 12:10 AM   #2
X5guyinRI
X5guyinRI's Avatar
Drives: 2016 BMW X5 xdrive50i
2016 BMW X5 50i  [0.00]
Yep. Did the same thing. Need to pull dash apart again and reconnect all the wires. You missed one.
      04-04-2024, 09:22 AM   #3
RATED_M
RATED_M's Avatar
Drives: E92 M3 Comp
Weird it started working again? Perhaps the mechanism that opens/closes the vents was having a moment
Current:
Previous:
      04-04-2024, 09:24 AM   #4
X5guyinRI
X5guyinRI's Avatar
If it stops again, you probably have a loose connection you didn’t quite tighten…hopefully it’s good to go!
RATED_M43.00
      04-04-2024, 10:08 AM   #5
stocktree
Drives: x5
Did you just install the mmi? Sometimes a deep sleep resets the modules.
      04-24-2024, 08:49 PM   #6
RATED_M
RATED_M's Avatar
Drives: E92 M3 Comp
I did install the MMI. Whatever this issue is is intermittent. Sometimes it works, sometimes it doesn’t.
I can hear the fans blowing at full speed, but its as if the flaps in the vents aren’t opening.
I don’t see how installing the MMI would have done anything. The head unit doesn’t control the AC
Current:
Previous:
      04-26-2024, 05:18 PM   #7
Maryan425
Drives: F15 35d
RATED_M I had a similar issue with codes appearing for the stratification flap motors. If these are not functioning properly or getting stuck you might get the issue of it not blowing air. An easy fix could be to reset these motors through a procedure on a Autel or similar software. Only takes a few minutes. This worked for mine and they have been working perfectly ever since.
