      01-27-2016, 05:35 PM   #2091
Neuera09
Drives: 2016 X5 Xline with MPPK
Originally Posted by motex View Post
Thanks a lot!
I found 2 options for the mirrors, do you know which one is the one that folds the mirrors after closing the car with the comfort access or key?
Option 1: Side mirror closing delay (line 49)
Option 2: Open/Close Side Mirror (line 50)
Option 2: folds the mirror with both CA/key.
Option 1: changes the (fold/unfold) delay time (line 52 not 49).
Personally, I only did option 2 (i think its line 53 not 50).
      01-27-2016, 08:50 PM   #2092
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
522
Drives: 2020 Mineral White 30d MSport
I just found that if I close the door with CA and hold my finger a few seconds, the mirrors fold, so I'm 50% done, what I really wanted is to fold them with just locking the car and not having to hold the key button or leave my finger until they fold
....Life is too short to drive boring cars
      01-28-2016, 03:08 AM   #2093
Neuera09
My mirrors un/fold when I press the un/lock button on my remote. I didn't need to hold the button or anything unlike CA. I actually prefer that CA setting.
      01-28-2016, 11:02 PM   #2094
IndyJer
Drives: '17 F15 MSport
'16 F15 XLine  [0.00]
'17 F15 MSport  [0.00]
Mine did the same. Haven't investigated yet, but I do have to recode since I had MPPK installed so will do some checking. I want the mirrors to fold whenever the vehicle is locked, no holding buttons nonsense. Lock and fold all the time.
      02-02-2016, 04:19 AM   #2095
igorsvrub
Drives: X5, 40d
internet
Hallo, checked coding sheet and did not find how to code "internet access"
I mean to see it in connected drive menu, I heard it is possible...
P.S. Car will be able to connect to internet via phone.
      02-02-2016, 07:39 PM   #2096
korben dallas
Drives: F15 35i MPPK
Has anyone figured out how to increase the ACC timeout from 3s to something higher? Looked around and didn't find anything, really hoping this is possible.
      02-03-2016, 05:08 PM   #2097
pcross71
Drives: 2016 X5 50
Has anyone found coding for the sensitivity of the radio volume knob? I find myself having to twirl it quite a bit to get a meaningful increase/decrease in volume compared to my old e39. I know the steering wheel buttons move it more with each click but tend to reach for the knob (probably because i'm used to the radio controls being on the left on my old one...).
thanks
      02-03-2016, 07:33 PM   #2098
MrTookies
MrTookies's Avatar
Drives: 2011 E90 328i, 2015 F15 35D
Have been looking for this as well...just a view second increase would be so nice! The only thing I found was the line that "determines" the 3 seconds. Changing that value by itself did not do anything though...
      02-11-2016, 09:04 PM   #2099
nszzya
Drive Different
nszzya's Avatar
Drives: '16 F15 '17 F87
Successfully coded BDC_ BODY, KOMBI and HU_NBT modules. After Read ECU, I do not see HKFM, KAFAS or ICM modules. Do I need to Read SVT instead or something else?
'17 F87 M2 DCT / '16 F15 X5 X35i / '09 E82 135i 6MT*
'10 E70 X5 35d* / '05 E60 M5 SMG* / '01 E53 X5 4.4i* / '76 2002* | '70 2002*
*Gone
      02-11-2016, 10:10 PM   #2100
Neuera09
Did u follow steps 12-20 on post #1 of this thread?
      02-11-2016, 10:15 PM   #2101
nszzya
Drive Different
nszzya's Avatar
Yes and I was able to code the modules mentioned. I don't see the other modules I mentioned.
      02-11-2016, 10:26 PM   #2102
Neuera09
Were the modules there before you coded the others? What features are you trying to code? Are you sure you have the options in your build?
      02-12-2016, 09:52 AM   #2103
nszzya
Drive Different
nszzya's Avatar
Screenshot attached of the modules I have. There were no others prior to coding. Trying to code Active Blind Spot at lower speed (have the option) and Close trunk via Keyfob/Inside button.
Of note, I had the driver door open during coding. The ignition was on, but the engine was not running.
*Gone
      02-12-2016, 09:54 AM   #2104
dsad1
Drives: car
You do need to read svt. But are you sure you are using the right car model when hitting connect on esys?
      02-12-2016, 09:57 AM   #2105
nszzya
Drive Different
nszzya's Avatar
Thanks. Will try that. I connected by VIN and selected F25 as the target.
*Gone
      02-12-2016, 10:28 AM   #2106
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
Can we Sticky this - I refer to it all the time as I am sure other do, would be nice to keep it on the first page.
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      02-12-2016, 11:27 AM   #2107
promtber
Drives: 2016 X5
No horn beep code for locking doors with car running
      02-14-2016, 11:44 AM   #2108
pcross71
Drives: 2016 X5 50
I'm having trouble getting my network connection. Apologies in advance as I'm a Mac guy and trying to get this sorted on an old windows xp laptop. When I connect the cable the Lan connection confirms connected. But ESys connect by VIN is greyed out. Did some searching online and believe this is a connection problem. Only think I can see is that the IP address for the connection is 192.xxx.x.x and the instructions I have indicate it should be 169.xxx.xxx.xxx. My IP address type notes it is Manually Configured. Thanks for any ideas.
      02-14-2016, 12:33 PM   #2109
athanyel
Drives: 2021 X5 xDrive45e
Assuming that you must have a 169.x.x.x address, it sounds like you need to clear out a manually configured IP address. As I can't remember the exact path to click through the UI, I'm going to include a shortcut.
1. Hold down the Windows key and press R
2. In the Run prompt type "ncpa.cpl" and press Enter (this should open the Network Connections window)
3. Right click on the network connection (often named "Local Area Connection") and click on Properties
4. Select "Internet Protocol Version 4" (TCP/IPv4) and click Properties beneath it
5. Select the "Obtain an IP address automatically" option then click OK
6. Click OK again to close the individual network connection's window
7. Wait a minute or so (a process on the laptop has to time out) then check your IP address again
That should get you on a 169.254.x.x address while you're not connected to any other networks.
      02-14-2016, 01:59 PM   #2110
pcross71
Drives: 2016 X5 50
Thank you! Worked perfectly. I vaguely think i used to know that stuff but it's been years since i made the jump to Macs...
With that sorted i completed my first batch of coding: m splash, seat belt chimes off, trailer rear view camera, radio off with door open, close hatch with fob/CA. Couldn't have done it without all of you guys - thanks!. All went smoothly (thank goodness).
One thing i still want to do is the folding mirror with fob. I've seen the cheat sheet and various posts here but want to confirm what's required if
a) i want the mirrors to fold only if i press and hold the lock button on fob (i.e., they don't fold immediately), or
b) i want them to fold immediately
I see these three items in cheat sheet
KOMFORT_SCHLIESSEN
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN
ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN
Thanks
Peter
      02-14-2016, 11:14 PM   #2111
MrTookies
MrTookies's Avatar
Originally Posted by akshay1234
Hi guys,
Did anyone figure out to finally code the angel eyes to not dim with the headlights or parking lights?
I had read some codes somewhere and done it on a friends X5, but yesterday another friend wanted me to code his and I just couldn't get the angel eyes to not dim.
Any help?
The X5 had LED headlights.
I added it to the cheat sheet hope that helps. Line 135-137 works on cars 06/15 and later (FLE ECU)
https://docs.google.com/spreadsheets...p=docslist_api
      02-15-2016, 06:24 AM   #2112
Manatee
Drives: X5 30d MSport (F15)
Originally Posted by shawnsheridan View Post
PM sent.
Hi Shawn,
Could you send me a link to the latest SW pls.
Cheers
Andrew
Search this Thread:
Advanced Search
