09-25-2015, 08:20 AM | #133 | |
Rep 18,723
09-25-2015, 11:55 AM | #134 |
Rep 1,124
09-25-2015, 12:35 PM | #135 | |
Rep 18,723
It just didn't work as it supposed to be. Instead of creating a tunnel, it just kill one side of the highbeam.
09-28-2015, 01:45 PM | #136 |
Rep 1,124
That's exactly what happened to me. L headlight off....but also headlight malfunction message. I had also included LHM 43 and LHM 44 to have the full European effect...guess not?
09-28-2015, 01:55 PM | #137 |
Rep 18,723
Hmm, you might've coded something else that causing that error.
12-20-2015, 09:55 AM | #138 |
Rep 69
GFHB has finally been solved for the US F15's (and a bunch of other models). Check out this thread over on Bimmerfest, there is a reference guide for the F15 with the specific coding instructions. The final piece of the puzzle was figuring out that we needed to decode the cornering light variables since the US cars don't have those. I've tried it out on our car and it is definitely working now. Kudos to everyone who has been working on this for months and didn't give up! I'm still not sure how they isolated the individual bytes in the LHM module that control the cornering lights, but they did it.
Check it out! http://www.bimmerfest.com/forums/showpost.php?p=9430612 |
07-31-2016, 01:30 PM | #139 | |
Rep 15
11-19-2016, 11:55 PM | #140 |
Rep 591
Same here, I made those changes on my F15 but the brightness didn't stay at 100% when I switched the low beams on. Help please.
11-20-2016, 08:43 PM | #141 | |
Rep 8,364
11-20-2016, 09:08 PM | #142 | ||
Rep 591
12-21-2016, 01:25 AM | #143 |
Rep 8,364
3005 Leuchtmittelmatrix 1, F8
HZX540e373.50 |
12-21-2016, 06:47 PM | #144 |
1152
Rep 2,426
From what I've seen, I think people should realize the DRL angel eye rings are designs to have a little bit of glare so they function properly as DRL since there is the sun out. When you have headlights on, at 100% brightness you're introducing glare to oncoming drivers which isn't nice especially at night.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
12-21-2016, 06:54 PM | #145 | |
Rep 8,364
12-21-2016, 08:25 PM | #146 | |
Rep 108
Almaretto2374.00 |
12-22-2016, 08:04 AM | #149 |
Rep 591
The lights are brighter, the area closest to the car is better lit. Doesn't make a difference on the highway or well lit streets. But on side streets and completely dark ones I love it. Also during my short drive yesterday I didn't get flashed by oncoming traffic, something that used to happen a lot in MB E400 with adaptive LED.
Almaretto2374.00 |
12-22-2016, 08:54 AM | #150 |
Rep 108
The way I tested: I drove the oncoming car at night on a rural 2 lane local road (40 mph speed limit). IMHO it's very bright, dazzling and annoying. Not as bad as HBs but not inconsequential.
As the oncoming driver, I've also noticed that even properly adjusted LED low beams are noticeably brighter, whiter and more glaring than both halogens and HID/xenon. Especially when the taller X5 crests a hill or hits a bump. After coding VLD and GFHB I've since manually lowered the drivers side headlight assembly a degree because it's really quite bright to oncoming traffic. |
HZX540e373.50 |
01-17-2021, 03:07 AM | #151 |
Rep 4
Thread bump - hi everyone thanks for the cheat sheet and all the useful info!
I am trying to do the US headlight sidmarkers through BimmerCode but having trouble finding the option LM_ID_LT04, can this be found in expert mode or do I need laptop coding? |
03-07-2021, 12:56 PM | #152 | |
Rep 2,717
Drives: M3
I tried setting left and right to 100% and it doesn't work
03-07-2021, 01:07 PM | #153 |
Rep 8,364
03-07-2021, 01:10 PM | #154 |
Rep 2,717
Drives: M3
I have the adaptive LEDs, FLE modules, I recently coded anti dazzle feature and that's working correctly. Do you know which ones in FLE?
Tags |
2014, coding f15, f15, f15 coding |
