08-31-2021, 08:54 PM | #23 |
Rep 1,353
Hey guys i have purchased the fluids and waiting them to arrive. I got 75w90 for the front and rear also 75w140 for the outer part. I am still trying to figure what is the difference between 75w85 carbon vs 75w140 other than viscosity. What carbon adds to that oil and makes it so special? I just wanna find out the purpose of the carbon feature. I dont mind to order 75w85 carbon if it helps something special in the unit!
Here is additional information : Additionally i got 75W90 for the front diff as shown on real oem
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 08-31-2021 at 09:52 PM.. |
09-01-2021, 05:54 AM | #24 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
I believe the carbon in suspension acts as another form of lubricant…sort of like the stuff we used to squirt into home door locks when they got sticky. This was a powder in a squeeze tube…graphite I believe.
09-01-2021, 02:26 PM | #25 |
184
Rep 364
Drives: M2C X5M M4
Not sure but would imagine as said above it's additional lubrication
09-01-2021, 04:06 PM | #26 |
Rep 1,353
I have talked to ECS before items shipped out. They said you can use 75w140 since it is Limited Slip. I will just use it. If i have any issue i will swap to OEM.
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
09-02-2021, 10:49 AM | #27 |
Rep 1,035
Drives: BMW X5M, M3 ZCP, MB E63 AMG
I used 75W-140 in the entire diff. Although this is supposed to use on the left/right side only where the clutch packs are located. 75W-90 is supposed to be used in the center for the ring & pinion. But the forum ridiculed me for doing so, but after months and many miles, I haven't experienced any issues. At the end of the day the major differences between the two, is one has an friction additive added. So should you be worried.....no not in the slightest.
09-02-2021, 12:45 PM | #28 |
184
Rep 364
Drives: M2C X5M M4
I believe it was me who tried to help by saying it was the wrong fluid and level and wasn't aware I ridiculed you, I for my own vehicle would rather use the correct specification and amount and uploaded for everyone's benefit the correct instructions. We all make our choices and except any consequences but I wasn't aware of ridicule just information.
09-02-2021, 03:18 PM | #29 | |
Rep 1,353
09-02-2021, 03:45 PM | #30 |
184
Rep 364
Drives: M2C X5M M4
I'm pretty sure the friction modifier was added to the e46 m3 diff to stop the noises on tight turns so it must be a slip additive thinking about it. unsure about the e9x.
09-02-2021, 05:05 PM | #31 |
Rep 1,353
Castrol SAF-XJ PRODUCT DESCRIPTION
Castrol SAF-XJ is a full synthetic SAE 75W-140 final drive lubricant. Formulated with an optimal combination of frictional characteristics and viscosity profile, Castrol SAF-XJ has been developed to help overcome noise and “stick-slip” problems in limited slip differentials in a variety of different vehicles. Castrol SAF-XJ has excellent high temperature performance providing exceptional wear. PRODUCT APPLICATION Castrol SAF-XJ provides protection under high load and high temperature conditions. The superior cold flow properties of Castrol SAF-XJ allow for improved gear and bearing protection at start up, reduced torque loss and increased driveline efficiency. Castrol SAF-XJ has the ability to reduce final drive temperatures through reduced friction, contributing to extended oil and component life. Castrol SAF-XJ can be recommended for most passenger car and light commercial vehicle final drives with or without limited slip differentials, where API GL5 lubricants are required. Castrol SAF-XJ is approved by BMW for use in rear axles fitted with limited slip differentials. It should not be used in BMW rear axles without limited slip differentials. For these applications please refer to Castrol SAF-XO PRODUCT FEATURES & BENEFITS Features • Optimal combination of frictional characteristics and viscosity profile for excellent noise reduction, helping to avoid “stick slip” and improve differential performance. • Excellent antiwear properties over all temperature and load conditions for better final drive protection and enhanced component life. • Excellent cold flow properties for improved gear and bearing protection at start up, reduced torque loss and increasing drive line efficiency. • Excellent high temperature performance due to wide span viscosity for better start protection under high load/high temperature conditions. Benefits . • Shear stable viscosity for constant viscosity and performance during oil life • Good anti-pitting behaviour helps to protect components, extending driveline life. • Advanced synthetic and antioxidant formulation for good oxidative and thermal stability, providing enhanced component cleanliness and extended lubricant life. PERFORMANCE LEVELS • SAE 75W-140 • ZF TE-ML 05D, 12D, 16G • BMW approval for rear axles with a limited slip differential Satisfying.
///MCollection183.50 |
09-02-2021, 05:41 PM | #32 |
184
Rep 364
Drives: M2C X5M M4
Good explanation, well found!
09-02-2021, 07:39 PM | #33 |
Rep 1,035
I have 8K on the driveline, since I last changed the fluids. And zero issues, if anyone was interested.
SaNGRia996.50 |
09-02-2021, 07:56 PM | #34 |
Rep 1,353
Appreciated. Will use the 75w140 on outer part.
09-02-2021, 07:57 PM | #35 |
Rep 1,353
Yeah. I just wanted to make sure it meets all required oil tech. Seems like similar to Carbon. I also found this product which has been used on GM vehicles. And if you read the description it says Specially recommended for ZF limited slip differentials with carbon linings. So this must be the same thing without BMW logo on it!
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 09-02-2021 at 08:04 PM.. |
09-02-2021, 09:41 PM | #36 |
Rep 125
And here I put the non friction modifier redline fluid in my E92 M3 with no issues for over 30k miles and probably 3-4yrs.
I'd say it's easy to keep it safe and use the modifier in the F85, no point in making this more complicated than it should be. |
09-02-2021, 10:24 PM | #37 |
Rep 1,353
The point of the discussion is to find most compatible product and done with it. When i am done with the DIY and share here, i want no one to look bunch of different options while the one will work without an issue. I am glad everyone has some good input.
09-03-2021, 09:41 AM | #38 |
Rep 1,035
The one denominator is that you change your fluids. What fluids you use, is your personal choice, but change the fluids.
09-06-2021, 07:56 AM | #39 | |
Rep 417
What's your thoughts?
ACID.
09-06-2021, 09:44 AM | #40 | ||
Rep 1,035
09-06-2021, 11:35 AM | #41 | |||
Rep 417
ACID.
09-06-2021, 11:37 AM | #42 |
Rep 30
Sounds like old Porsche joke that if it’s not leaking oil it’s empty. Definitely BS.
Klienfeld303287.00 |
09-06-2021, 11:50 AM | #43 |
Rep 1,340
Newtis warns not to change oil in the left and right chambers, and only to do it in the middle chamber.
09-06-2021, 01:12 PM | #44 | |
Rep 1,035
Why do people fear changing their fluids in their vehicles. Forget what BMW is telling you and change the dam fluids, or don't. It's your choice.
