07-26-2019, 07:05 PM | #1 |
Rep 2,680
RPM, Engine Temp, and Fuel gauge not working after battery change
anyone had this experience. never retrofitted the digital gauge. its fully stock. the RPM, Engine temp and Fuel gauge reading stopped working. Only thing that does reading is the speed. bottom reading for time still works. what to do? car is out of warranty (2014 x5).
much help appreciated!! thanks in advance! it says "instrument cluster update needed"? is this a coding issue? tried to reset the cluster but didn't seem to resolve the issue, checked the fuses for the cluster and seems to be fine. |
07-26-2019, 09:26 PM | #2 |
1642
Rep 2,995
I'd drive the vehicle for a bit and see if it goes away on next startups.
If nothing changes I'd disconnect and reconnect the battery cable. If those don't work, then I'm not sure... |
07-26-2019, 10:16 PM | #4 |
Rep 2,680
Yes I did drive the car for a bit and it seems like it’s still the same, I will try to disconnect the battery.
07-26-2019, 10:18 PM | #5 |
Rep 2,680
So I got the battery install the battery at an independent shop, and had the battery registered at the dealer. Was thinking the register would cure the car but it didn’t. The cluster update shows on both the idrive and the cluster.
07-26-2019, 10:23 PM | #6 |
Rep 2,518
Did you check fuses? You have the 6WA cluster?
07-26-2019, 10:25 PM | #7 |
1642
Rep 2,995
So the dealer didn't bother to tell you what the issue could be?
07-26-2019, 10:25 PM | #8 |
Rep 2,680
07-26-2019, 10:27 PM | #9 |
Rep 2,680
They wouldn’t be able to help me look into it at the moment because it has a bimmertech back up camera installed. They said the camera would need to be fully taken out before they can spend x amount of hours looking into it. Trying to find solutions before breaking the wallet
07-26-2019, 10:41 PM | #12 | |
Rep 2,680
Bimmertech did the coding remotely. Told me everything looked “fine” Not sure if I should do another hard reset on the battery. |
07-26-2019, 10:57 PM | #14 | |
Rep 2,680
Asking because I’m planning on trading in the car after this. |
07-26-2019, 11:28 PM | #15 | |
1642
Rep 2,995
Maybe some coding guys can chime in with some help. |
07-27-2019, 11:51 AM | #16 |
Rep 2,680
01-07-2023, 12:33 AM | #17 |
Rep 2
Hi I know this is an old post but I'm having a similar issue but didn't change battery just came on in f10 Just wondering what the outcome was or any additional advice thanks
