      04-11-2014, 07:32 PM   #1
S1OOORR
Drives: 2014 F15 X5
What Fuel grade do you use and why 89 or 91
Would you use 89 grade im thinking about it
      04-11-2014, 08:33 PM   #2
atomic80
Drives: 997TT
I'd stick with what's recommended by BMW. These engines are high performance and the last thing you'd want is to muck it up with lower octane grade gas.
      04-11-2014, 08:48 PM   #3
MJM
BMW CCA Boston Chapter - Member
MJM's Avatar
Drives: 2011 E90 M3, ZCP
Whichever grade you choose, choose it from one of these companies: http://www.toptiergas.com/
      04-11-2014, 08:52 PM   #4
S1OOORR
Drives: 2014 F15 X5
Yes I am aware of the recommended fuel octane but once you open your gas tank cover it says minimum 89 just curious if anyone put 89 in
      04-11-2014, 09:40 PM   #5
atomic80
Drives: 997TT
If it says it's ok then no harm in doing so.
      04-11-2014, 09:46 PM   #6
Zipforia
Zipforia's Avatar
98
Drives: 2016 BMW i8
89 and up. Some countries have maximum octane of 89.
Z.
      04-11-2014, 11:20 PM   #7
brissim
Drives: X3 30d (2011 F25) - now sold
Also just be aware that various countries use a different octane rating for their fuel. The "octane rating" on US pumps is not the same as the RON rating used in Europe and elsewhere (including Australia). 89 octane in the US is - I understand - equivalent to about 92-93 RON. Here in Australia our petrol (gas) is generally available in 3 RON specs - 91, 95 & 98. Which is why our recommended minimum fuel RON is 95.
Tony
      04-11-2014, 11:56 PM   #8
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
I stick with 93. 92 when it's not available. 91 is rare to find around me and when it's there, it's not much of a price difference so I'm willing to just pay the extra couple bucks a week. I say no to 89...
      04-12-2014, 12:36 AM   #9
S1OOORR
Drives: 2014 F15 X5
Ok all I been using is 93
91 is hard to find I dont think I will use 89 neither
      04-12-2014, 01:09 AM   #10
opasha
opasha's Avatar
1318
Drives: 2014 BMW X5 50i
Mine will probably only take 93 since it's a 5.0i.
      04-12-2014, 10:44 AM   #11
For what the price difference, it is not worth it to go lower than 91, as that's what we have here in smog free california.
Unless if it was back in the day where it was 10% difference between 91/92 and 89. Now the difference is only about 3%.
I even don't shop around for gas station anymore, because price/distance wise doesn't make sense anymore.
March SALES!! Evolution Racewerks - Until 04/01 | PM for DEALS
      04-13-2014, 06:33 AM   #12
barcelona
barcelona's Avatar
Drives: X
In Canada, I use Shell V Power, octane 91 and ethanol free.
From Shell Canada:
Does a vehicle benefit from increased octane?
Different vehicles require different levels of octane. To determine the appropriate octane level for your vehicle, check your owner's manual for the manufacturer's recommendation.
Since, the F15 manual recommends 91, I would go above the stated min 89.
      04-13-2014, 07:11 AM   #13
MysticBlue
If the manual recommends 91, then stick with 91. Using less than 91 will not cause any harm because of the incredible engine management that modern cars are capable of. If an engine is designed for 91, due to it's higher compression ratio, then that's where it will get the best efficiency and performance. Less octane would cause knocking, but the engine management software dials back timing and other parameters to keep it from knocking, which is good... It will do no harm. But, if you are using lower octane because it is cheaper, you are probably losing any savings to lower gas mileage because of the engine management software dialing back the performance. Plus you aren't getting the full potential performance you paid a premium for... More than likely one of the reasons you bought a BMW.
On the flip side, putting higher octane in a car than what it was designed for will do absolutely nothing to improve performance or efficiency and is a complete waste of money.
      04-13-2014, 08:48 AM   #14
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
This assumes 91 is actually available, which it isn't in many places... Even then, not sure I agree, but I'm no expert and 91 isn't readily available where I live, so I stick with 93 and waste $2 a week
      04-13-2014, 09:20 AM   #15
MysticBlue
Well, under the circumstances, yes, you are doing the right thing. If 91 is the recommended minimum, and your only choice is 89 or 93, then yes, 93 is the right choice. Higher octane than needed certainly won't do any harm and you will get the same added benefit that you would get from 91. Just don't think that since 91 is good, 93 is even better. It doesn't work like that. If the design and compression ratio of an engine call for 91, 93 won't make it any better, in any way, than 91. It would perform exactly the same. But it's better than 89.
      04-14-2014, 12:10 PM   #16
Richard181
Drives: 2014 X5 5.0
It the engine doesn't ping with 87 go with that.
      04-14-2014, 01:08 PM   #17
AnthonyL88
Drives: 2014 BMW X5 35d M Sport
I haven't seen 91 anywhere in NY State. So you always need to fill up using Super or Ultra.
      04-14-2014, 01:11 PM   #18
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
Exactly. I think Sunoco used to have 91 back when "ultra" meant 94. Don't think I've seen either in a few years now.
      04-14-2014, 02:03 PM   #19
someguy
someguy's Avatar
Drives: 2014 X5 3.5d
I just use the green one (diesel) and there aren't any options for grade.
thanks,
someguy
      04-14-2014, 03:14 PM   #20
Kzang
Kzang's Avatar
3222
Drives: 2015 X5 35i Msport SG
I agree with what Mysticblue said..
It is amazing how people think... If people had the option to use gas octane rating from 91 to 99.. people will always choose higher thinking the higher the number the better the gas for your high performance engine
I've used 87 and 89 octane with no problems... for few weeks most people here in NJ / NY had no choice but to use regular unleaded due to Hurricane Sandy's aftermath..
My X5 is running pretty damn good...
      04-14-2014, 03:32 PM   #21
phantomac2
Germany
Drives: BMW F15 (KS81)
In Europe, there are.
      04-14-2014, 03:35 PM   #22
E90Fleet
South Africa
1311
Drives: BMW
And many other parts of the world
BMW if you are reading, I need a job, Please.
Search this Thread:
Advanced Search
