      05-27-2014, 09:01 PM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Post 2014 BMW X5 Recall: Faulty Child Safety Locks
BIMMERPOST NEWS
8
COMMENTS
NHTSA press release:
Manufacturer: BMW of North America, LLC
SUMMARY:
BMW of North America, LLC (BMW) is recalling certain model year 2014 X5 SAV vehicles manufactured December 12, 2013, through March 10, 2014, and equipped with the Soft Close Automatic (SCA) option. The rear side door lock mechanisms may not have been manufactured to correct tolerances and when the inside door handle is pulled, the previously engaged child safety lock can disengage.
CONSEQUENCE:
A disengaged child safety lock would allow the rear seat occupant to pull the door handle twice and open the door while the vehicle is parked or in motion, increasing the risk of injury.
REMEDY:
BMW will notify owners, and dealers will inspect the rear side door locks and any affected door locks will be replaced, free of charge. The recall is expected to begin in May 2014. Owners may contact BMW customer service at 1-800-525-7417.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
      05-27-2014, 09:21 PM   #2
sirajkas
32
Drives: BMW X5 2014
They changed this on mine while it was in the service center.
      05-27-2014, 09:30 PM   #3
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
So they got it right for 3 or 4 months, then wrong for 3, then fixed it again? Anyone else confused as to why it wouldn't affect cars built from the start of production through March 10, 2014 instead of only from 12/12/2013..? Mine was built before the issue, so I guess I'm lucky. I'll check them anyway..
      05-28-2014, 09:52 AM   #4
mashimarho
BMW GENIUS
mashimarho's Avatar
2108
Drives: E92 M3 & F80 M3 & G82 M4
Good info to know
Mashimarho.com /// Instagram /// Facebook /// Youtube /// sales@mashimarho.com /// (425) 582-7939
      05-28-2014, 09:53 AM   #5
stewy604
stewy604's Avatar
290
Good info to know. Thanks for sharing. Fortunately, I didn't go with the soft-close door option.
2007 Suzuki GSX-R 750
      05-28-2014, 09:57 AM   #6
E90Fleet
South Africa
1312
Drives: BMW
Probably tooling or parts change at the lock manufacturer, which BMW then later found caused problems not seen in the original batches.
They would have been making the locks much longer than 4 months, as they would have been making locks for pre-production test models, then launch and press car locks for months before the customer production started.
Its not out of the ordinary for a supplier to BMW to change something in the
design or manufacturing process and for problems to then arise.
BMW will then work with the supplier to rectify the problem and get the solution onto the factory floor before issuing a recall to replace the defective parts already delivered.
Car not yet delivered will also be put on hold to have the parts fixed before they may be delivered.
BMW if you are reading, I need a job, Please.
      05-28-2014, 09:59 AM   #7
bradleyland
TIM YOYO
Drives: 2013 M3
Here's your answer:
"The rear side door lock mechanisms may not have been manufactured to correct tolerances "
It's a manufacturing tolerance issue, which can happen for a myriad of reasons. I worked for an aircraft manufacturer for a while. Usually, tolerance issues are due to incorrect use/manufacture of tooling or jigs. You get a new guy on the line, and they do something incorrect that no one catches because it doesn't affect normal use, or the issue is intermittent/inconsistent. Or you get a new tool, and it's not made to specifications because someone screwed up a CAD/CAM drawing.
Given the nature of door lock mechanisms, it's probable that this issue doesn't affect 100% of the cars (specified by the time range) 100% of the time. Hypothetically, there's some little cog in there that has to block some other little cog, and sometimes, if you don't engage the child safety just right, the one cog doesn't block the other cog, and bam! Safety recall.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      05-28-2014, 12:09 PM   #8
GeloCH
Switzerland
19
Drives: X5 30d M Sport, Space Grey
Anyone in Europe affected? I have 2 kids... Thanks!
      05-28-2014, 12:16 PM   #9
parm
Drives: 2014 X5 M50d
Good question GeloCH I too have the soft close doors and two very active boys!!
