09-18-2014, 05:14 AM | #67 |
Rep 55
I've installed mine today, they look great! and yes it does flicker at start up and every 2 to 3 min or so... but i think i can live with that..thank you Opasha for opening this post
09-18-2014, 05:24 AM | #68 |
Rep 3,990
09-18-2014, 10:07 AM | #69 | |
Rep 1,744
I wonder if someone can catch these "flickers" in video or is the flicker rate is too fast to catch on camera but visible to naked eye. |
09-18-2014, 01:27 PM | #70 |
Rep 3,990
It's fast, but it should be able to be caught on video easily.
09-21-2014, 08:34 PM | #73 |
Rep 3,990
Thanks for the video post. It blinks like this 3 times very fast at each engine start-up without the coding.
Haha, good analogy.
09-25-2014, 10:56 AM | #74 | |
Rep 146
Been reading this post and I plan to do some coding with my X5 (adaptive headlights, remote open/close tailgate). I don't use ebay to buy, but I want to purchase that ethernet cable to connect the X5. I found this cable http://www.amazon.com/Interface-Ethe.../dp/B00BFRW6FO on amazon and was wondering if its the same or similar to the one you use. Also, what other common coding modifications can be done that are popular with the F15? Thanks. |
09-25-2014, 11:32 AM | #75 |
Rep 92
That looks like the correct cable. Best wait for somebody else to confirm though!
Regarding coding - see Opasha's very helpful coding thread: http://f15.bimmerpost.com/forums/sho....php?t=1033991 |
09-25-2014, 11:51 AM | #76 | |
Rep 146
09-25-2014, 12:44 PM | #77 | ||
Rep 3,990
09-26-2014, 12:00 AM | #78 |
Rep 18,703
Or you guys can always buy the cable from me.
09-26-2014, 12:04 AM | #79 |
Rep 3,990
Oh awesome. I didn't know you carried OBD2 cables, so I just referred everyone to where I bought mine originally and was satisfied with it. I'm a creature of habit .
09-26-2014, 12:28 AM | #80 | |
Rep 18,703
I try not to solicite much. But I personally build the cable and test them 1 by 1.
10-28-2014, 02:03 PM | #81 | |
Rep 1,744
Now, I think we can also use this cable for other OBDII diagnostics, right? Do you know if there is a software for the PC that we can use?
10-28-2014, 04:07 PM | #82 | |
Rep 18,703
Unfortunately no. The pin-out for OBDII diagnostics would be different as they are usually using serial port / USB.
10-28-2014, 07:10 PM | #83 | |
Rep 1,744
I see. Thanks. Edit: ScanGaugeII uses RJ45. Does it also work as diagnostics or strictly stats? I think $200 for just stats is too much. http://www.amazon.com/ScanGauge-Auto...dp/B000AAMY86/
10-28-2014, 10:49 PM | #84 | |
Rep 18,703
They use the RJ45 type connector, but not the same configuration as the Coding cable. For that price, if you have 35i with N55, the JB4 Stage 2 can also run diagnostics and clear codes since it is connected to the CAN Bus.
10-28-2014, 10:55 PM | #85 | |
Rep 3,990
10-28-2014, 11:11 PM | #86 | ||
Rep 1,744
Thanks for the information both of you, I am not interested in clearing codes but just wanted see if I can use the coding cable for other situations like decoding the CEL when it's not giving me information on the iDrive.
10-28-2014, 11:20 PM | #87 | |
Rep 18,703
If you are using other OBDII software, it uses different port. I thought you were talking about using the E-Sys cable for different diagnostics software.
10-29-2014, 12:26 AM | #88 | ||
Rep 3,990
