01-13-2015, 05:06 PM | #23 | |
Rep 420
The best car ever: E34 M5 3.8l daytonaviolettmetallic hos Mälardalens Ventilationsceneter
01-13-2015, 05:13 PM | #24 |
Rep 420
opasha seems to be something wrong whit:
0-60 info: RaceChip CR Ultimate for F15 X5 30d When you hit the link you get a posting page.
01-13-2015, 05:50 PM | #25 |
Rep 3,990
Thanks, buddy. I fixed it .
01-13-2015, 06:02 PM | #26 |
Rep 4,106
Opasha, You have become a true value to this board. I smiled when I saw this thread.
Here is mine: 1) 2014 x5 x35d 2) racechip ultimate 3) s1= 3, s2=E 4) Pulls like a freight train and still gets 28 mpg mix. Most of the torque added down low. 1. 2013 M5 2. BMS stage 1 3. +3 psi across the board, no map changes 4. 640 whp...enough said.
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
01-13-2015, 06:07 PM | #27 | |
Rep 3,990
01-14-2015, 01:18 AM | #29 |
83
Rep 346
1) F15 X5 M50d 2014
2) AC Schnitzer (430 HP, 840 Nm) 3) Uploaded installation manual here 4) Already shared my impressions on this solution in the M50d thread of mine. You can also check Autobild measurements/etc. in German here or in English here. I.e. 0-60 time is confirmed @ 4.9 sec. |
01-14-2015, 02:26 AM | #30 |
Rep 160
Great thread
E70 30D (8 speed) 2012 MSport RC Pro2 - default setting from RC (previous used for my F25 20D and settings changed based on RC recommendation - will add around 20%. Can't recall actual settings. No error messages (X3 + X5) HP: app 290 NM: +600 Fuel: A bit improved - just did a 3500km round trip in Europe whereof 2800km on German Autobahns. Averaged 8.4L / 100km 0-100km/h: Have not measured but match friends X6 40D spot on (BMW claim 6.6 sec for the 40D) - this is 1.0 sec down from factory 30D Pulls pretty hard JensM |
01-14-2015, 04:02 AM | #31 |
Rep 265
Still driving on S2=3. Pulls very hard between 2000-3500 RPM. Can definitely hear the turbos working, something that's not real audible on the lower settings. If this week goes well, I will up it to 4 on Saturday.
01-14-2015, 05:43 PM | #32 |
Rep 159
Here's mine. F15 50i BMS N63tu Stage1.
Just installed a couple of weeks ago. Was concerned about living at over 9000ft, if it would affect the tune or throw a code. It has not. I cannot test it fully yet because of the snowpacked roads and whenever I try to slam the pedal to the metal it just overwhelms the traction control and DSC and all 4 wheels are spinning! I know it is going to be insane when I can unleash it! |
01-14-2015, 06:21 PM | #33 | |
Rep 4,106
http://www.amazon.com/12010-Racing-F.../dp/B000HBIA1I
01-15-2015, 04:46 AM | #34 | |
Rep 265
01-15-2015, 09:48 AM | #35 | |
Rep 4,106
http://en.wikipedia.org/wiki/Methylc...se_tricarbonyl
01-15-2015, 10:09 AM | #36 |
Rep 53
1.) 2014 X5 50i now ACS5 5.0i
2.) AC Schnitzer DME Software Programming for 50i 3.) No individual settings 4.) 525 hp, 750 Nm, max speed 282 km/h or 175 mi/h See the following post: http://f15.bimmerpost.com/forums/sho....php?t=1069671 Best regards Marcus |
01-15-2015, 10:22 AM | #38 | |
Rep 420
01-15-2015, 10:31 AM | #39 |
Rep 4,106
I don't feel comfortable with a 4, but I have been in E/3 for couple weeks already.
01-15-2015, 01:35 PM | #40 | |
Rep 525
01-15-2015, 02:30 PM | #41 | |
265
Rep 345
Drives: 2019 X5 40i M
Thanks
2019 X5 X40iM
01-15-2015, 04:14 PM | #42 |
Rep 51
opasha your post and help to the community are awesome!!
I'm sorting through the tune and code posts in the coming weeks. For the 50i is the consensus to go BMS or Race chip for best performance? |
01-15-2015, 04:19 PM | #43 |
Rep 3,990
Thanks . RaceChip is the more popular on the forum lately because of its solid feedback. BMS is still good and will give pretty similar performance to the RaceChip for the 50i (however, nothing will ever be better noted than test driving two F15s side by side and of course a dyno end result). I recommend BMS only because of the ease of install (takes 1-3 minutes literally) since it plugs into the MAF sensors - no disassembling required to get access to them. This will be very useful for you when you are taking your car in for service. You must remove the piggyback. For the RaceChip, because it uses the MAP sensors, it is very tedious to install (takes 20-30 minutes for the experienced user). Just take a look at my OP for the installation differences.
01-15-2015, 04:36 PM | #44 | |
Rep 41
These forums are depressing |
