      03-23-2017, 03:43 PM   #221
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by PeanutButterJellyTime View Post
Thanks for the info. I will take a look to see if it all matches later. I checked out the high beams again last night and noticed it to be working. I just can't determine if my lowest variable lights are functioning. After seeing how the high beam assistant works I wish the LEDs were separate individual ones like the mercedes one. Good enough I guess.
VLD:
View post on imgur.com
NGHB:
      03-22-2018, 04:45 PM   #222
wordsworth03
Drives: na
Hey guys, so I just coded GFHB and when driving around in regular low beam mode, I feel like that my lights are lighting up people’s rear license plate more than normal. Has anyone else noticed this? I don’t have a good way to follow someone else at night to get feedback if they are too high or not.
      03-23-2018, 12:00 AM   #223
Almaretto
Almaretto's Avatar
2374
Low beams will still work. It will not be complete blackout of car in front of you if you are close enough to project on them.
      03-23-2018, 07:46 AM   #224
Duke I
Drives: X5
Any changes to the coding for 2018 F15 or do the Jan 2016 PDF instructions still work?
Duke
2018 X5 50i
2015 911 C2S
2017 X4 M40i (gone); 2010 X5 (last of the NAs); 2007 550i (still missed, except in the snow); 1991 525i manual (great 17-year run)
      03-23-2018, 10:41 AM   #225
wordsworth03
Drives: na
Sorry, I should have clarified a bit. When I drive around town in the dark on regular low beam mode, it seems like the low beams are aimed higher than before I coded the GFHB. I haven’t even had a chance yet to test the GFHB yet.
      03-23-2018, 02:18 PM   #226
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
Originally Posted by Doanster View Post
Confirmed... you do not need DA+. I don't have it and GFHB works like a charm.
I need someone to remotely code this
      03-23-2018, 06:16 PM   #227
Almaretto
Almaretto's Avatar
2374
Interesting. Most people complain that lights seem lower than from factory. It is actually designed for drivers side to be lower so as to not glare opposing traffic.
      04-02-2018, 03:38 PM   #228
eggyacid
eggyacid's Avatar
Drives: BMW X5 F15
Me too... can someone remote code this only? i have Bimmercode App and got all the coding I need done except for this one.
Jeff
Current Ride
- 2016 Toyota RAV4 Hybrid
- 2014 X5 xDrive35 M
- 2013 ML-350 (Gone)
- 2012 Audi Q7 TDI (Gone)
      04-04-2018, 12:55 AM   #229
Almaretto
Almaretto's Avatar
2374
It can be done on own with E-sys or Bimmercode. It is the most work doing on own with Bimmercode. With E-sys, there are scripts written to quickly apply all necessary changes.
      06-23-2018, 05:49 PM   #230
Sergey193
Drives: F15 3.5i
Is it necessary to delete 5ap and 8s4?
Will it be sufficient to change the parameters via fdl and werte?
      06-25-2018, 02:20 AM   #231
Almaretto
Almaretto's Avatar
2374
If you are using my Launcher Cheat Codes, you must load modified FA to do part of the work through VO coding.
      06-26-2018, 06:33 PM   #232
Sergey193
Drives: F15 3.5i
reworked everything according to the instructions (deleted 5ap and 8s4), then encoded bdc, kafas, lhm, tms.
After doing fdl encoding also according to the instructions.
The distribution of light works, but it is completely incorrect (
      06-26-2018, 06:39 PM   #233
Sergey193
Drives: F15 3.5i
      06-26-2018, 10:59 PM   #234
masterfung
Drives: 2018 X5 50i
I realize this has been going on for a few years now but if I'm driving a 2018 X5 with Adaptive Full LED lights and Assistant High Beam.. am I getting anti-dazzle or do I still ned to code it?
I'm driving X5 50i, M-Sport with Exec tier. Just picked it up a couple of weeks ago...
Also, I have Bimmercode so if coding is needed on my F15, can someone post a link to the thread with the correct codings?
Thanks very much!
      06-26-2018, 11:50 PM   #235
Almaretto
Almaretto's Avatar
2374
Thanks very much!
North American F15 get 2-stage HBA. Rest of the World gets NGHB.
      06-27-2018, 02:17 AM   #236
Sergey193
Drives: F15 3.5i
icm should I encode after removing 5ap and 8s4?
      06-27-2018, 04:56 PM   #237
Sergey193
Drives: F15 3.5i
encoded icm, nothing has changed (
in parameter LUT_FLC_FORWARDLIGHTING_Y
there is no value F015_mit_AFS (9C 9C 9C), but even if you enter the values "9c 9c 9c", the lights still do not work correctly on high beams
      06-27-2018, 09:24 PM   #238
Almaretto
Almaretto's Avatar
2374
9C 9C 9C is for low beams and cornering lamps.
      06-28-2018, 01:22 AM   #239
Sergey193
Drives: F15 3.5i
Please tell me why the distribution of high light rays does not work correctly?
Maybe because of low firmware? (52.3)
Did everything according to the instructions, deleted 5ap, 8s4, then "code" bdc, kafas, icm, lhm, tms.
Then I changed 16 functions according to the instructions.
Errors erased.
High beams work, but tonnel is not made either for passing cars or for oncoming vehicles (
for oncoming cars, the left-hand headlight diminishes its brightness, but the toner does not move.
The right headlight chaotically moves its rays, blinding the passing cars.
And the tonnel is formed for 1-3 seconds at a time when the passing car disappears from the visibility of the kafas camera.
      06-29-2018, 05:38 PM   #240
Sergey193
Drives: F15 3.5i
the tunnel is formed chaotically, it is visible at 30-35 seconds
      07-02-2018, 11:03 PM   #241
Almaretto
Almaretto's Avatar
2374
Errors erased.
It is possible that there is a mismatch in firmware and settings.
Have you run analysis on your firmware level to check if more settings are different in LHM?
      12-10-2018, 08:22 AM   #242
Duke I
Drives: X5
Anyone successfully do the anti-dazzle coding -- NGHB and VLD -- on a 2018?
Duke
2018 X5 50i
2015 911 C2S
