07-12-2016, 10:28 PM | #1 |
Rep 815
Drives: G05 X5,G20 M340,Infiniti Q50RS
Wheel Guru's--help needed.
So i have an almost brand new set of Vossen CV4 22" sitting in my garage that was on my 2014 Pathfinder. Specs 22 x10.5 et42. HB 66.1, 5x114.3.
I wanna run these wheels on my F15, using a wheel conversion adapters. There's a company online that can make the wheel adapter, but i wanna give them correct specs. I'm thinking 25mm Rear and 15mm front for adapter size, but need the conversion specs. And yes i will take my chances running the wheel adapters. APPRECIATE ANY INPUT. [IMG][/IMG]
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
07-13-2016, 03:32 AM | #2 |
Rep 3,990
Wheel Specs for all 4 wheels:
Center Bore = 74.1mm Bolt Pattern = 5x120 The offset for most people's 22x10.5 front wheels including mine are ET 30. My wheels are all 22x10.5 ET 30. Use this as reference for how much it will stick out: http://f15.bimmerpost.com/forums/sho...postcount=2700
07-13-2016, 09:30 PM | #3 |
Rep 815
^^ Thx for the info.
07-13-2016, 10:17 PM | #4 |
Rep 8,801
My wheels are 22x10.5 ET38F and 22x11.5 ET40.
I'm rocking a 20mm spacer in the back which effectively makes the wheels ET20 in the back and its flush with the flares. Up front i could use a 10mm spacer so ET28 would be perfect. Here's a pic with the 20mm in the back and no spacer up front Alan
07-14-2016, 06:37 AM | #5 |
Rep 1,363
My wheels are 22x10.5/ 30 offset all around also.
front is flush. Real flush......Your 15mm adapter will stick out 3mm more, which isn't a lot but my wheels come out far enough for my own liking. On my rear wheels I have 20mm spacer in the rear (essentially 10mm offset). Wheels could easily come out another 5mm or so. Your 25mm adapter could probably go as high as 35 |
