      06-12-2014, 08:45 PM   #89
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
First post on this board. Please be patient if I don't know your acronyms, or those about cars.
Can you Kindly tell me where/how on the amber blinking, ECE spec taillights? I am in the SF Bay Area, and if you have local source and/or installer for the lights, I'd much appreciate the information.
      06-13-2014, 01:29 AM   #90
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
You need to buy tail lights from Europe. Wiring is significant and time consuming and requires advanced coding. I would not recommend this mod. I only followed through with it because I couldn't return the lights.
I did the work myself with a BMW master tech friend.
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP
      06-13-2014, 10:28 AM   #91
MattBianco
MattBianco's Avatar
Thank you for the swift turn around.
I have to do the lights modification.
1) Red turn signals in the back are ugly
2) Red turn signals are not as safe
As I am ordering mine and not buying off the lot, I am trying to convince the dealer to have the factory install these as the US factory exports these globally.
"Wiring is significant and time consuming and requires advanced coding" is a huge deterrent. I can find people to wire, but the coding part will be challenge.
I have never had a car whose blinkers were red. I don't want this car I am ordering this weekend to change that.
      06-13-2014, 01:10 PM   #92
wdimagineer
Drives: 2015 X5 M
The factory won't do it as the RoW lighting isn't compliant with DOT FMVSS lighting regulations.
The wiring and coding would likely void your warranty. The coding could also reset when your car is updated during routine service, leaving you without some rear lighting functionality.
If red signals are an issue, don't buy the X5.
      06-13-2014, 02:15 PM   #93
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
You can install them yourself. It is a little tricky though for one of the sides due to the a large tank I believe? Read this thread for more details: http://f15.bimmerpost.com/forums/sho...oduct_id%3D294
      06-13-2014, 02:39 PM   #94
MattBianco
MattBianco's Avatar
Well, she was just ordered, and should be delivered in 6-8 weeks.
I have to figure out a workaround as you have for the amber indicators/turn signals.
Sonnen BMW in San Rafael, CA made no mention of a warranty void, but said they have no one that can address the coding issue, but they could wire it. That is the bottle neck for now, coding.
They also recommended Canadian tail lights, which should be easier to source. Not sure if anyone has experience with this.
They warned from a quality standpoint against eBay sourced lights that are made in China.
If anyone has access to a coding specialist, would much appreciate it. I am willing to spend the time/effort to learn it if I have to periodically tamper with the firmware.
@Opasha....unless I missed it, I think your thread link was just for bumper install.
Thank you.
      06-13-2014, 03:07 PM   #95
MattBianco
MattBianco's Avatar
Cries of desperation....
Since you have opened up and seen all the guts of the rear lighting housing, wiring and fixtures, can one theoretically put yellow film over the LEDs in the inside? That would be yellow+red=orange.
      06-13-2014, 04:07 PM   #96
opasha
opasha's Avatar
1329
Thank you.
Oh wow (face palm)!! Somehow my quote got put in the wrong thread! I must have copied and pasted into the wrong thread when replying to help. My apologies. I replied this for someone asking for the bumper splitter installs.
      06-13-2014, 08:52 PM   #97
wdimagineer
Drives: 2015 X5 M
Canadian lights are the same as those in the US.
Yellow film would likely have a negligible impact. It would also make your brake lights orange as well since turn and brake indicators are combined.
The F15 is the first BMW I've seen that has different lamp behavior in various markets. It's been my experience that they've typically been plug and play. Had I known what was involved in the retrofit I would've skipped it.
I was just at Sonnen earlier. I'm quite surprised they'd offer to do the wiring that could void your warranty. During my install we bricked the BDC ECU. We were able to recover it but if the same thing were to happen to you warranty wouldn't cover it.
      06-13-2014, 11:12 PM   #98
MattBianco
MattBianco's Avatar
You have been very helpful. Dream-shattering, but helpful. Thank you.
At minimum, I had hoped that the indicators would be a separate set of LEDs than the break LEDs, even if red, (ala benz, cayenne, audi). To hear that they were so cheap with the US release as to use the same LED set to double up as both break and indicator, like a 70s Oldsmobile, is really disappointing after $75k.
      06-14-2014, 12:37 AM   #99
wdimagineer
Drives: 2015 X5 M
Actually, no. Everybody is doing it. Audi and Porsche have combined turn and brake indicators on most of their cars. Look at an A4 or A6. The entire lamp lights up or flashes. It looks dumb.
Mercedes typically is separate but they've gone red, too.
Blame our outdated rules and not BMW. A certain percentage or surface area of a lamp has to illuminate in braking conditions. Tail lights would be gigantic if the manufacturers didn't combine multiple functions into a single lens.
Example:
      06-14-2014, 02:54 AM   #100
MattBianco
MattBianco's Avatar
I thought GL class was separate, but the video link you sent clears it all about the direction at large. What a sad state of affairs.
I finally also understand the reason for the additional wiring.
My guess is DoT are just too scared to change rules, fearing backlash, and fearing liability as no one has done a $20mn study to show it would be an improvement over their 70 year old rules.
Would love to see a video of your taillights in action so I can stare enviously.
...that said, I have not given up. Sent an email to Nor Cal BMW Coding to see if they could do this.
Meanwhile, if you have a source for the lights themselves, would much appreciate posting it.
      06-18-2014, 01:12 PM   #101
Sassafras2
Drives: 2014 X5
Holy cow, look great. How do you think the carbon fiber mods would look on a darker car, like Carbon Black?
      06-18-2014, 02:07 PM   #102
Rob@StrasseWheels
Rob@StrasseWheels's Avatar
458
Drives: 2023 BMW G80 M3 Comp
Wow it looks amazing!!
@Strasse_Robert | (786)701-3649 | Robert@StrasseWheels.com | www.StrasseWheels.com
      06-21-2014, 09:48 PM   #103
wdimagineer
Drives: 2015 X5 M
Parm, quick pic for you. More coming soon after they're edited.
      06-21-2014, 10:14 PM   #104
loumckay
loumckay's Avatar
Drives: 2014 X5 M Sport
Hi everyone:
I'm a newbie to this site and to BMW. I just purchased a 2014 X35i Sapphire Black X5 M Sport, and love it.
I'm looking to increase my horse power, through I believe it's called "Dinan". The few inquiries I have made, indicates there would be nothing until the end of the year for this model, has anyone heard anything different?.
Also, the "M" Performance Brakes. The stock ones are great, but love the look of the "M" Blue, as well as the disc's. Its sounds pretty goofy to most, to purchase brakes based on the color and size, but my wife and I love the car. I think we are becoming car, better yet BMW enthusiasts.
Also, would like to upgrade the sound system, currently have the Harmon Kardon, but really like the other sound system that has the speakers come up through the dash.
Any thoughts, or advice?
      06-21-2014, 11:16 PM   #105
opasha
opasha's Avatar
1329
First of all, welcome and congratulations on your new X5!
1) To my knowledge, your info seems correct. Dinan seems like the best tune with warranty. You can try others, but I'd wait.
2) The brake upgrade is solid. I will be doing this soon. You can buy them here: http://www.getbmwparts.com/partlocat...catalogid=4462
3) I've inquired about upgrading the sound system. You are stuck with what you have ordered from the factory because the sound system cannot be changed from BMW; I've asked around regarding this and even checked with my service rep. So far, BAVSOUND (http://www.bavsound.com/) is the only company that can swap out the current sound system (plug and play) with a nicer system while maintaining warranty. They're exclusive to BMW and have really solid reviews. I have the standard HIFI 9 speaker system and will be upgrading when it becomes available. I'm almost 99% sure that the Bang&Olufsen (http://www.bang-olufsen.com/en/car-a...s/bmw/BMW,-,X5) can't be upgraded to from the Harmon Kardon, but since they are both 16 speaker systems, you might be able to see if they can do an install depending on the sizing of the speakers. Ask your service rep or PM wdimagineer for more info.
Good luck!
      06-22-2014, 02:08 AM   #106
Armen383
Armen383's Avatar
Cyprus
83
Drives: Mercedes-Benz E63S
Actually don't believe your BMW stealerships re: upgrades and retrofits. I am pretty sure there are a lot of good BMW tuners in the US that can retrofit B&O even from the 6 speaker system (it'll cost though because the trim would also be changed). Upgrading from 16HK to 16B&O solution is very easy for any professional installer. So if you're lucky to live in an advanced country/city and have the $ - it's not a problem whatsoever.
However at the price point BMW charges for B&O I'd strongly suggest you upgrade to an aftermarket custom system (Focals, etc.) - would probably end up paying less for more.
      06-22-2014, 09:36 AM   #107
Ninpo21
Drives: BMW X5
Was you on the triboro on Saturday night I think I was chasing a similar X5
      06-22-2014, 03:13 PM   #108
wdimagineer
Drives: 2015 X5 M
BavSound will likely have an upgrade soon. They're great. I highly recommend them.
      09-10-2014, 06:44 PM   #109
CaliE90
CaliE90's Avatar
354
Drives: BMW
2021 M550xi  [0.00]
would you mind posting a video or some pics of how the European taillights blink? I'm curious as to see what the differences are
Retired- '14 F10 535i -- 3 2 1 | '08 E90 335i -- 4 3 2 1 |
      10-03-2014, 05:32 AM   #110
Ibiza
Ibiza's Avatar
Drives: 22 G83 comp & 2024 X5 M60
Love the mods!
Would you mind measuring the width from the side panel/height above the side air curtain that the M badge is placed at? I will installing on my CB X5 50 M Sport soon.
Thanx
