10-28-2017, 05:32 PM | #3807 | |||
Rep 176
Is there a guide out there, i've never done this before I don't want to mess up. |
10-28-2017, 05:44 PM | #3808 |
Rep 8,364
10-28-2017, 06:29 PM | #3809 |
Rep 176
10-29-2017, 05:12 AM | #3813 |
Rep 103
Hi guys. Could you help me identify what must be coded to disable the easy access for the F15? Specifically, steering column adjustment. I found it for the E70, it is:
Module : IHKA ELSV_EH_LAENGE -> aktiv -> nicht_aktiv ELSV_EH_NEIGUNG -> aktiv -> nicht_aktiv But this option is not there for the F15. My steering wheel got stuck recently, and i would like to disable this option. |
10-30-2017, 09:23 PM | #3814 |
Rep 40
@opasha - tried shooting you a PM but inbox is full.
I'm looking to code my f15 x5 and noticed opasha can provide the tokens that are required for the e-sys application. Can you please provide these? I am also looking for a good source to download ESYS, psdzdata and ISTA+. Is anyone can provide that I would greatly appreciate it. Thanks! |
10-31-2017, 03:21 AM | #3815 | |
Rep 8,364
Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links You will find Sticky to ISTA+ links over there as well. Alternatively, you can find in F30 Coding Section. |
11-07-2017, 10:05 PM | #3819 |
Rep 8,364
11-25-2017, 04:34 PM | #3820 |
23
Rep 303
**Help with 2017 X5 trailer coding. CC msg Trailer Hitch: Stop Carefully
To start, I've added the VO code of 3AC, and I followed this procedure:
"Connect => Read FA (VO) => Activate FA (VO) => Read ECU (VCM) => Left-Click on AHM ECU => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on AHM(AAG for mine) (the ECU itself not the underlying CAFD) => Select CODE. " However, during the process I noticed that the CAFD selection did not show my Istep version. I choose the latest version available 503, and coded that. However, the the Trailer Hitch warning message started flashing afterwards. 1) Do I need different files to fix this issue? 2) If so can someone link me the latest files I need to do this? 3) Could this be a VO coding issue? Not sure which ECU's need to be VO coded, as it seems that every other post on the question has users flashing ECU names that I do not have. For example my unit is labeled AAG not AHM. Thanks for your help!!! Last edited by C4sF80M3; 11-25-2017 at 04:42 PM.. |
11-27-2017, 07:44 AM | #3821 |
Rep 3
Can anybody advise please how to change Number of Soft Turn Signal Blinks to 5? at the cheat sheet there is BDC_BODY, 3068, BLINKZYKLEN_ANZAHL_TIPP. But there is no such function in section 3068.
11-27-2017, 09:41 AM | #3822 |
Rep 8,364
11-27-2017, 01:02 PM | #3823 | |
Rep 1,181
http://f15.bimmerpost.com/forums/sho...&postcount=461
11-27-2017, 11:20 PM | #3826 |
Rep 968
Hi Shawn,
Picked up 2018 X5 40e over the weekend. Wanted to code few things e.g. trunk close with fob, mirror close etc. Could you pm the link to latest s/w and cheat sheets with all modules, functions and new value for F15? Found this xls on pg1 which put together by Opasha, not sure if it has been updated. https://docs.google.com/spreadsheets...9s4/edit#gid=0 TIA!! |
11-27-2017, 11:24 PM | #3827 | |
Rep 40,793
leasehackr465.00 |
11-28-2017, 12:58 AM | #3828 | |
Rep 103
